E46 Xi Forum
Old 11-11-2013, 11:28 PM   #1
clinton902295
My Ride: e46 330xi
2001 330xi instrumnt cluster issue.
So what happened was, i changed the blower resistor on my car but had the battery unplugged, wasn't sure so as safety, when i replugged in after the job and started the car the cluster wasn't working. But an ABS light came on, nothing else, my rpm, temp, speedometer, the digital nothing works but when the car starts up abs come one stays and the airbag light goes on then off. Does anyone know or have any idea of what could be the cause? I checked the fuses they are all set im just lost.
clinton902295 is offline   Reply With Quote
Old 11-15-2013, 07:14 AM   #2
basketthis
My Ride: state to state
Re: 2001 330xi instrumnt cluster issue.
"see, what had happened was... "
I've never removed the cluster personally. I know there is communication between it and the computer and other components. Even when the car is off. Not sure why you are having an issue when the battery was unhooked.
My suggestion is to call BMW, talk to a technician (if that's possible), or call a local BMW-specific shop, talk to someone knowledgeable and get your answer. Those guys mess with that stuff all the time. Not to take anything from anyone, but most of us here are regular and preventative maintenance guys.
basketthis is offline   Reply With Quote
Old 11-17-2013, 01:46 PM   #3
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Just a silly question at this point; you "unplugged the battery"? Which cable did you remove?
tomoyer is offline   Reply With Quote
Old 11-17-2013, 06:06 PM   #4
clinton902295
My Ride: e46 330xi
i called the dealer they havent herd of this issue but want, 300 to reprogram the system including diagnostic cost
Old 11-17-2013, 06:08 PM   #5
clinton902295
My Ride: e46 330xi
To the otther guy im not sure but i usually unplug the negative first, what are affects of unplugging positive first? @ tomoyer
Old 11-17-2013, 07:52 PM   #6
tomoyer
All you should have to do is remove the Ground/Negative cable from the battery post and isolate it so that it can not contact any metal part of the body. As long the Negative Cable is completely isolated from the body and battery, you have an "open circuit". Sounds as though you had a surge of power to the Central Control Module thru which all things on the dash and a few other systems, such as interior lights, trunk lights and others runs thru. Depending on how bad it is, they may be able to re-program the car, maybe not, diagnostics will tell them if the Module is bad or partly toasted. If the Module needs to be replaced, it alone costs about $400.00 plus the hour to install and about 2 hours of programming.
