///M3 Forum
Old 11-13-2013, 12:50 AM   #1
Sammysaba
My Ride: 2006 E46 M3- Sold
Not really sure what's going on here
I live in New York it's currently 29 degrees outside. I haven't started my car in alittle over 4 hours and this is what I come to. The engine had not over heated. Checked my antifreeze levels already and my fan is working. Anybody have any ideas why it is that my gauge reads well over normal temp?
2002 E46 325Cic- For sale!
2006 M3 Convertible Jet Black on Dove Grey Scorpion exhaust Macht Shcnell Intake- Sold
2013 F10 M5!!!
Sammysaba is offline   Reply With Quote
Old 11-13-2013, 01:40 AM   #2
ToMuchFun
Banned User
My Ride: E46 325i
Originally Posted by Sammysaba View Post
Attachment 534601
Looks like your car overheated alot
ToMuchFun is offline   Reply With Quote
Old 11-13-2013, 02:00 AM   #3
frostbytez
My Ride: '04 M3
faulty temp sensor at a guess, think there is one in the lower coolant hose
frostbytez is offline   Reply With Quote
Old 11-13-2013, 03:11 AM   #4
Slyde
My Ride: 2001 M3 TiAg
"gauge reads well over normal temp?"... that thing is pegged against the side of the housing. Would the needle spin if not blocked?
So, you started the car cold (4 hours not running) and it immediately reads explosion temperatures? I think if that gauge is showing actual temperatures then you would have other obvious indications.
If from a cold start, then surely it is a sensor or the gauge. There must be another way to check reported temperatures other than that gauge. What sort of OBDII reader might you have? Maybe the gauge got messed up when whoever was making its border red? The BMW manual states about the temperature gauge that "If the lamp comes on while operating the vehicle, the engine has overheated. Switch the engine off immediately and allow it to cool down." This seems to say that it will illuminate (I presume the thermometer icon in the middle of the gauge), which does not seem lighted in your picture, so maybe just the gauge itself?
That's my first guess. Although those fist ones are often off target...
Slyde is offline   Reply With Quote
Old 11-13-2013, 05:59 AM   #5
Sammysaba
I assume it's a sensor as well I put the red border in about 3 weeks ago now I'd assume if something was wrong with the gauge it would have stopped working a whole ago.
But the red light on the temp gauge was not lit up and my car has not exploded. I'm going to get it on a lift today to find out the problem.
2013 F10 M5!!!
Old 11-13-2013, 09:17 AM   #6
Sammysaba
Mechanic said everything looks fine but my gauge cluster needs to be replaced the motor is seized in that position
2013 F10 M5!!!
Old 11-29-2013, 05:50 PM   #7
skelzy
My Ride: 2005 M3 Coupe
Could be whom ever did the work to put in those color gauge rings might have damaged the whole cluster...
2005 AW/BLK,SMG,Loaded
skelzy is offline   Reply With Quote
Old 11-30-2013, 12:39 PM   #8
Alex323Ci
My Ride: M3 & 323Ci (sold)
yep I doubt it's a coincidence that gauge rings put on and temp gauge/needle are now broken.
Use the cluster test and see if you can reset the needles with the test. It'll swing all the needles to full and back to zero again. You don't even need a scanner-tool to do it. Search "Cluster Test".
Never know..
