Old 11-14-2013, 01:59 AM   #1
Brownbryce
My Ride: E46 325ci
Cold start problems.
My e46 325ci automatic. has trouble starting when cold, it cuts out, then ticks over really low, so when you put it in drive it stalls. ???
Brownbryce is offline   Reply With Quote
Old 11-14-2013, 03:38 AM   #2
NumbaOneNewb
My Ride: 2003 330CI Silver
Try disconnecting maf sensor an starting it. See if that helps. If it doesn't you have a vacuum leak
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 11-14-2013, 06:17 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Read the 1st link below in my signature.
Unplugging the MAF sensor actually causes the engine to run a bit richer, so if unplugging the MAF sensor makes the engine run better you likely have vacuum leaks, but this test may be misleading anyway.
Suggest you purchase your own OBDII scan tool. For $30 USD or less you can have a tool that does what you need, read this - http://forum.e46fanatics.com/showthread.php?t=967204
Old 11-14-2013, 08:51 AM   #4
Brownbryce
My Ride: E46 325ci
Hi I have a eobd reader. The codes are 227 228. I've replaced the maf, both engine temp sensors, cyclone valve, fuel pump, idle valve, it's turning in to a money pit lol.
Old 11-14-2013, 09:19 AM   #5
lszlszx
My Ride: 1.8T, XC70
Does you code reader display fuel trims?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 11-14-2013, 10:14 AM   #6
jfoj
Intake boots and DISA O-ring at a minimum should be considered.
Cracked/leaking valve cover gasket.
Not sure why you replaced the MAF, hopefully you still have the orignal one, hold on to it!
$30 USD or less, you need to read this - http://forum.e46fanatics.com/showthread.php?t=967204
Old 11-14-2013, 11:53 AM   #7
Brownbryce
My Ride: E46 325ci
What does the disa valve do?
Old 11-14-2013, 11:55 AM   #8
Brownbryce
My Ride: E46 325ci
Intake pipes all good. It does have a flat spot, but I can't find an air leak.
Old 11-14-2013, 12:08 PM   #9
jfoj
Leak air around the large O-ring and -
Old 11-14-2013, 11:57 PM   #10
Brownbryce
My Ride: E46 325ci
Of the fuel tank leaked around the fuel pump seal could this be my problem? I filled the tank right up, and noticed petrol on the floor. Looked under the car and the tank is wet with fuel it's coming from the top of the tank. !
Old 11-14-2013, 11:58 PM   #11
Brownbryce
My Ride: E46 325ci
If the fuel !!!
Old 11-15-2013, 12:49 AM   #12
heechkass
My Ride: 323i Touring, 2000
Seems like a good starting point. So are you saying, fuel leaked out and onto the back seat and floor?
heechkass is offline   Reply With Quote
Old 11-15-2013, 01:58 AM   #13
Brownbryce
My Ride: E46 325ci
Yes.
Old 11-15-2013, 06:25 AM   #14
jfoj
Either the hose on the fuel sender is leaking or someone removed the fuel pump and did not reinstall the fuel pump/sender gasket correctly.
Old 11-15-2013, 07:19 AM   #15
Brownbryce
My Ride: E46 325ci
Will that effect the fuel pressure?
Old 11-15-2013, 07:31 AM   #16
jfoj
If the fuel line clamp is loose, it can impact fuel pressure.
Suggest you pull the rear seat bottom, very easy, no tools needed, pull up sharply on front corner of seat bottom.
The on the right rear (your drivers side) check the insulation to see if it is cut, this will give you and idea if someone has been under the seat to access the pump. You can then pick up the insulation and remove the 3-4 screws to access the fuel sender. On the access panel is removed you will be able to see the fuel hose and determine if this is leaking.
Old 11-15-2013, 07:40 AM   #17
Brownbryce
My Ride: E46 325ci
Ok many thanks will keep you posted.
Old 11-15-2013, 08:02 AM   #18
jfoj
Personally I think the fuel leak may not be the main cause of the cold start problems.
You really need an OBDII scan tool as I mentioned before so you can see more data and understand better what is going on.
Next read and follow the lead in the 1st link in my signature.
Fuel pump info is in the 2nd link in my signature.
You cannot see signatures on smartphones with Apps. Log on an use a computer to see the signatures.
Old 11-15-2013, 08:39 AM   #19
Brownbryce
My Ride: E46 325ci
Ok. Took seat out dry as a bone! Can't see where the fuel leaking From need to put car on a ramp. The fault codes says it could be up to 8 different things! Slowly working through them lol.
Old 11-15-2013, 08:41 AM   #20
David McMahon
My Ride: '99 E38 740iL
List! Then maybe clear codes then... LIST!! Please
David McMahon is offline   Reply With Quote
