Old 11-15-2013, 11:37 AM   #1
KCHPFM3
My Ride: HPF 2.5 M3
Question Oil leak in HPF 2.5 from timing chain cover
It's a long story but after a year of finally sorting out my 2.5 by discovering I needed to replace the dual vanos...I have a small oil leak that is apparently coming from the timing chain cover.
After trying to seal it a couple times with a liquid sealent it still leaks after wot runs. I know the main reason is the bolts aren't made to be torqued more than 15lbs or so on the cover and that the cover is also not built to handle 600+ horsepower.
The leak is more annoying than a real problem and the only thing that is "off" on the car (knock on wood), and only ends up leaving a small drop on the floor after it makes it's way down the next day. But as you all know we like to have our cars running perfect.
I'm just wondering if anyone else has had this problem or can possibly offer a solution?
Thanks for any thoughts on this!
2003 HPF 2.5 M3
KCHPFM3 is offline   Reply With Quote
Old 11-15-2013, 07:27 PM   #2
coinage
My Ride: 02 M3
Which part of the cover is it leaking from? If it's the top (head to t-cover), I'm dealing with that and my intial thoughts are head lift as I seem to be getting some excessive cooling system pressure after a few pulls. I'm a stock block though w/ e85 and 15psi. Planning on L19's and OE headgasket this winter with a worked over head I have on the shelf. I bought ray's (yellowssm) car last month for anyone wondering lol.
coinage is offline   Reply With Quote
Old 11-15-2013, 11:50 PM   #3
KCHPFM3
My Ride: HPF 2.5 M3
Not exactly sure where leak is originating from but the top would make sense as the shop I take the car to suggested the head gasket be replaced. I question the diagnosis as there hasn't been any coolant leaking in. As you can imagine.. not super excited about replacing head gasket.
2003 HPF 2.5 M3
Old 11-16-2013, 12:34 AM   #4
GRK///M3
My Ride: LSB M3
Did you check the timing chain bolt on the right side of the timing chain cover. Its near the oil filter housing. It loosens over time which will give you a small oil leak.
GRK///M3 is offline   Reply With Quote
Old 11-16-2013, 11:51 AM   #5
KCHPFM3
My Ride: HPF 2.5 M3
Thanks for the tip, I will check it and see if that's the case.
2003 HPF 2.5 M3
Old 11-16-2013, 05:38 PM   #6
GRK///M3
My Ride: LSB M3
Did you find it?
Old 11-16-2013, 10:23 PM   #7
KCHPFM3
My Ride: HPF 2.5 M3
I didn't have a chance to get under there today. A couple of weeks ago I had it in the shop to check the leak again and I would think they would have checked that. If I don't have time tomorrow I will call the them on Monday to check.
This was a different place than the shop that did the vanos replacement. The vanos shop thinks I need to replace the head gasket while the other shop says it's the timing chain cover and probably not worth the time to try and seal it again.
2003 HPF 2.5 M3
Old 11-18-2013, 11:14 AM   #8
InDiGlOM3
My Ride: HPF M3 stg 2.5
Re: Oil leak in HPF 2.5 from timing chain cover
The side gaskets are one use. once front cover is tighten and remove you have to replace them. same goes with head gasket that goes around top of front cover. At the bottom its connecting to pan which has a rubber seal which stays good for awhile even after removing cover or pan a few times..as long as its not damaged or just to old. You need new side gaskets. They are five bucks each. and the top needs to be seals with black rtv. to put it on so it seals the pan needs to be lowered by loosening all the pan bolts and side power steering bolt. Also remove front main seal to install cover otherwise it'll make it harder to put on to make sure top os sealed right. Install seal afterwards with plastic sleeve on crank. Seal press also best but I've done it with two inch punch and hammer before haha. Anyways there is really not a lot of pressure there so wot won't effect it to much, check Vanos sealing plate, did you use beisan o rings?
Old 11-18-2013, 04:17 PM   #9
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Great info
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 11-18-2013, 08:00 PM   #10
KCHPFM3
My Ride: HPF 2.5 M3
Very good info indeed! I forwarded this info to the tuning shop that replaced the vanos to see that all of this was done. I typically am not comfortable doing this type of work on my own. Thanks!
2003 HPF 2.5 M3
Old 11-19-2013, 08:48 PM   #11
InDiGlOM3
Where are you located?
Old 11-20-2013, 05:17 AM   #12
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
His Location says Kansas city.. thats about an 8 hr drive to you jesse
he can ship it to you and have you go over the whole kit/engine?
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 11-20-2013, 10:03 AM   #13
KCHPFM3
My Ride: HPF 2.5 M3
Yes, I'm in Kansas City. The whole kit was actually sorted during the year it was in the shop. It was running very rich so we followed the hpf trouble shooting guide ended up sending almost everything back to hpf to test under their recommendations. Turned out nothing was wrong with the kit and we needed to replace the vanos. We unlocked the AEM and re-tuned the car and it's running perfectly (585 whp w/o meth, 690whp, w/meth). The only issue is really the small oil leak. Thanks again for your thoughts guys!
And I haven't heard back from the shop yet...
2003 HPF 2.5 M3
