Old 11-16-2013, 06:23 AM   #1
Moe.Jo.Joe.jo
My Ride: 2001 325xi
Unhappy P0335 Crankshaft position sensor code wont go away!
Greetings, this is my first post so here we go. I have a 2001 325xi. I suspect the problem first started with my battery dying because that's about when I began to notice the loooong crank-times (not a good look), the lose of POWER (the absolute worst for the bimmer) and the RPM's tending to alternate up and down between 300-1000 rpm's ( like breathing). After refilling the battery with water and charging it, the long cranks remained. Checked the codes it threw P0335 crankshaft position sensor. I got a standard brand sensor from World auto replaced the BMW sensor. It didn't clear the code or restore power. Bought a new battery, changed the fuel filter, replaced the spark plugs, and got another sensor from the same place and replaced it. I must say the car rides nicer, but still has the long crank, not all the power back and the P0335 code returns immediately, I also notice a burning smell as I exited the car after I did the work, too tired now, will check after sleeeeeeppppp oh sorry. Please help!!! Dont wanna keep buying bad sensors or it could be something else? Thanks...
Moe.Jo.Joe.jo is offline   Reply With Quote
Old 11-16-2013, 11:00 AM   #2
NumbaOneNewb
My Ride: 2003 330CI Silver
Your ccv is probably clogged and vacuum leak. Intake boot ripped. Wait, disconnect your maf and try starting it. One last thing. If cranking takes long punch gas pedal when starting. If it helps you must've not plugged it in right
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 11-18-2013, 10:27 AM   #3
Moe.Jo.Joe.jo
My Ride: 2001 325xi
I checked and cleaned and re-crimped the connections to all the electrical plugs in the engine compartment including the connector to the crankshaft sensor. I also made sure the sensor was in tight and plugged in. While this did restore some of the power I was missing, the long crank and lack of power still remained. Is there any way I could test the sensor and the wiring harness without going to the Dealer?
Old 11-20-2013, 06:34 PM   #4
bigdave666
My Ride: 325ci auto
i have the same problem, i have replaced the lambda sensors, spark plugs, crankshaft sensor 3 times, injection loom (which covers the crankshaft sensor plug, all with oem spec parts, and then i spoke to a friend of mine i haven't seen for a very long time, years in fact who worked at a bmw main stealers for 15 years, he said every time they have a 325i or 330i with a m54 engine in, they did a dme re flash first and that sorted it in 95% of the problems he said just do a dme re flash and that will sort all problems, he is doing it saturday in his garage.
my car just before i bought it had a brand new fully rebuilt crate engine from bmw at the cost of 6500 only 3000 miles ago, so i am thinking he maybe right well i will find out soon and let you post the result,
check out dme re flash..... this my help quite common on the early e46 325i and 330i so he said
bigdave666 is offline   Reply With Quote
Old 11-21-2013, 04:11 AM   #5
Moe.Jo.Joe.jo
My Ride: 2001 325xi
Good looking out bigdave666, I will investigate how to do a re-flash. In the meantime I will check back after saturday and see if it solved your problems.
Old 07-02-2016, 10:17 PM   #6
Ryandowell
My Ride: 2001 325ci 2003 325i
Did you ever fix it? Having same problem have changed everything that could possibly be replaced
Ryandowell is offline   Reply With Quote
Old 07-05-2016, 08:58 AM   #7
Moe.Jo.Joe.jo
My Ride: 2001 325xi
Dme reflash flash
Yeah I did a dme reflash and sorted everything out.
Old 07-05-2016, 09:10 AM   #8
Ryandowell
Okay so what I'm wondering about that is I think the sensor I bought is not genuine bmw but If I'm getting ecu refreshed dose it matter and if it dose matter how do I know for sure if the original sensor is even bad. And where can I get that done at?
Old 07-05-2016, 09:23 AM   #9
cirrusblau
My Ride: 2001 330i
I'm having a similar problem with P0335. How did you do the DME reflash?
cirrusblau is offline   Reply With Quote
Old 07-05-2016, 03:42 PM   #10
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
If it threw a code, it's more than likely bad.
On a related topic: it seems like aftermarket sensors usually don't cut it; you might want to spend a little extra and get an OEM sensor.
Sicily1918 is online now   Reply With Quote
