Old 11-16-2013, 08:01 PM   #1
gabriox
My Ride: 2002 bmw 325xi
angel eyes help.
ok, i just installed my angel eyes, but i have a problem, i can remove that plastic tab covering the positive terminal. and the relay has to be grounded too???
here is a pic, pulling it up is not working. it wont move even a bit. help
gabriox is offline   Reply With Quote
Old 11-16-2013, 08:16 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It will go up, pull harder but do it near the fender end so you don't have to take the entire piece out.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 11-16-2013, 09:11 PM   #3
gabriox
ok, I will try later, it was damn impossible. Does the relay have to be grounded? Or not. Mine didn't come with the blue taps. Now I have to go look for it.
Old 11-16-2013, 09:18 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
No, just the ground wire and that's it.
Old 11-16-2013, 10:08 PM   #5
gabriox
I wanna test the the angle eye with out tapping into the ecu. How do I do that that's and how do I avoid a short circuit? Thanks
Old 11-23-2013, 03:34 AM   #6
YYCZHP
My Ride: 2005 330ci zhp
angel eyes help.
Tap the wire that goes to the ecu to a 12 volt wire. Ie the + battery terminal. Honestly I was extremely nervous about tapping into the ecu wires as we'll but just go slow with it, I'm assuming you bought ones with the wire connector for the wire tap and just make sure you got the right wire. I detest wiring with a fiery passion but it's super easy!
YYCZHP is offline   Reply With Quote
Old 11-23-2013, 09:34 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
It's on the fastm diy. Touch the ground to a ground and positive/trigger wire to the positive terminal.
Old 01-27-2014, 04:00 PM   #8
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Do not place the ground under the mount of the relay. Put it on the 19mm bolt.
