Old 11-18-2013, 02:38 PM   #1
speed12
My Ride: E46 M3 HPF, E36 M3
HPF Stage 1 - Methanol question!
Hi guys,
I wonder if I install HPF Methanol kit on my car should it work fine with HPF AEM EMS? It should detect the methanol automatically when I turn it on and there is no need for remapping, am I right on that?!
Any ideas about this?
E36 M3 1997 Dakar Yellow
E46 M3 2005 Carbon Black (HPF)
E46 M3 2006 Imola Red..(Memories)
Instagram @mqh12
speed12 is offline   Reply With Quote
Old 11-18-2013, 03:00 PM   #2
InDiGlOM3
My Ride: HPF M3 stg 2.5
Re: HPF Stage 1 - Methanol question!
As long as tune is there for it
Old 11-18-2013, 03:10 PM   #3
speed12
I made some searches and found this HPF quote from an old post:
"Our methanol system is automatic. No flipping switches or uploading maps is required. When methanol is detected, our system automatically allows the turbo to provide more boost, increases timing to benefit from the higher effective octane, and drops fuel to the injectors to compensate for the methanol fuel creating a very safe A:F ratio."
does this mean that anyone who has HPF stage 1 and want to upgrade to stage 2 no needs for uploading maps just installing the Methanol kit?!
Instagram @mqh12
Old 11-18-2013, 04:15 PM   #4
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
does this mean that anyone who has HPF stage 1 and want to upgrade to stage 2 no needs for uploading maps just installing the Methanol kti?!
U should be ok.. But for peace of mind I would unlock ur Aem and take a peak... I would be happy to tell u if its setup correctly.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 11-19-2013, 01:29 AM   #5
speed12
Thanks bro for that, I appreciate it.
It seems that is ok for installing HPF Methanol kit on my car. First I have to buy one , then I will see how the car is running.
For sure I would like to unlock my AEM and see if it is setup correctly will contact you on that when the time come for it.
Till now my car runing fine on pump gas and race fuel also.
Sent from my GT-I9300 using BimmerApp mobile app
Instagram @mqh12
Old 11-19-2013, 10:47 AM   #6
nek0
My Ride: e85 turbo m3
id recommend you go away from the methanol since everyone that runs it always runs into problems
nek0 is offline   Reply With Quote
Old 11-19-2013, 11:09 AM   #7
Commanderwiggin
My Ride: 1000rwhp Turbo M3
If you're looking for a full HPF Meth System let me know as I have one with a brand new unused meth pump that I would sell for $500...but as mentioned earlier I wouldn't recommend a 100% meth system...now if you were to set it up like Being3 and use a 50/50 mixture and only use it for cooling...then it would be a more reliable setup.
Old 11-19-2013, 12:54 PM   #8
speed12
PM sent.
Instagram @mqh12
Old 11-19-2013, 08:45 PM   #9
InDiGlOM3
When they said its automatic that means it'd automatic, if the tune is there for it, after a certain date all hpf stage 1 and 2 kits had the tune. But what they meant about no uploading different maps was just that it would switch to what is already there automatically.
Sent from BimmerApp mobile ap
Old 11-20-2013, 01:37 AM   #10
speed12
Thanks for explanation. What was the date when they had the meth tune for all HPF stage 1 and 2? I Bought my HPF turbo kit since April 2011!
Instagram @mqh12
Old 11-20-2013, 09:50 AM   #11
InDiGlOM3
You should be good then.
Old 02-02-2014, 02:01 AM   #12
speed12
Thanks guys for the help. I just finish my HPF meth kit installation..it is true that I faced some leaking issue but at the end I work it out.
Results: the car has already the maps for meth due to the latest production date of HPF AEM. The car runs fine no issues at all. I know the other issues that might occur from the meth but I'll try to manage it.
Will keep this setup for a while tell the next upgrade:cool:
Instagram @mqh12
