Old 11-19-2013, 05:44 PM   #1
tlester
My Ride: 2001 330i
OS version?
Hi all -
How do I determine my OS level of my e46?
tlester is offline   Reply With Quote
Old 11-19-2013, 05:55 PM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
OS version?
What do you mean by OS level?
Old 11-19-2013, 05:56 PM   #3
haurelio
My Ride: 2001 bmw 325i
OS level?
Contact me if you need to unlock your phone.
Also can code your car
Old 11-19-2013, 05:56 PM   #4
bry330i
My Ride: 2002 330i
OS level
bry330i is offline   Reply With Quote
Old 11-19-2013, 06:06 PM   #5
tlester
My Ride: 2001 330i
Seriously... you guys don't know that one? Operating System. The Operating System version of the DME?
Old 11-19-2013, 07:40 PM   #6
choxor
My Ride: JDM
Windows Server 2008 R2
Pretty sure INPA can tell you the software version.
choxor is online now   Reply With Quote
Old 11-19-2013, 07:55 PM   #7
JapanRot325ci
My Ride: 04 E46
i'm sure you're running windows 330i (I for Idiot)
wot?
not srs
JapanRot325ci is offline   Reply With Quote
Old 11-19-2013, 08:41 PM   #8
tlester
My Ride: 2001 330i
What a bunch of smart asses. So, what you are saying is that you have no idea. I get it. Smart assed responses only make it obvious that you don't understand.
Old 11-19-2013, 08:57 PM   #9
choxor
My Ride: JDM
We understand perfectly.
Old 11-19-2013, 09:27 PM   #10
wildirish317
My Ride: 2004 325Ci vert
Hi all -
Plug it into a computer, right click on "computer", then click "properties".
Seriously, you need a scanner, such as BMW Scanner 1.4. Then you can scan your car and get a report that reveals something like this:
I had my DME reflashed in March, and you can see how the "Assembly" and "Software" values changed. As far as what they actually mean, you'll have to find TerraPhantm and ask him.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 11-19-2013, 10:21 PM   #11
tlester
My Ride: 2001 330i
Thanks!
As for the rest of you, you are amusing. Why? Well... you guys all think it's cute that I use the term OS (which is the proper term) and think I'm an idiot. It's amusing that you don't even know me. Or know the fact that I am a very senior engineer and systems architect for the biggest software and hardware company in the world and have been doing it for almost 20 years. It's cute that you think the term OS would only relate to your personal computers, when in fact most devices have an OS of some sort. My refrigerator has an OS. It's cute how you think you know so much, but... well you wouldn't understand.
Old 11-19-2013, 10:42 PM   #12
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
Software that drives our cars is very low level code that drives embedded hardware. Think of it more like firmware.
Encryption76 is offline   Reply With Quote
Old 11-19-2013, 11:51 PM   #13
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
E46 Coupe is offline   Reply With Quote
Old 11-20-2013, 12:24 AM   #14
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
OS version?
Thanks!
Knows software better than anyone and is the best when it comes to all things computers.
Asks forum what operating system is inside his carputer that we have no access to through our screens.
Ok
Old 11-20-2013, 01:34 AM   #15
scarede46er
My Ride: 2001 BMW 325i ZSP
Ok
Old 11-20-2013, 07:25 AM   #16
tlester
My Ride: 2001 330i
Yes.... but I had already gone out and read the engineering spec's on the computer in our cars before I asked the question. There are several ASIC chips that are function specific. These ASIC's mostly read sensor input or are controllers for functions like injector specific fuel control. According to the engineering specs, these chips are hardcoded. I.e. these don't get updated. Then there is the operating system that the ASIC's speak to. Yes... this is held in NVRAM (i.e. firmware), but just because it's firmware, doesn't mean that it's not an operating system. All it means when we call something an operating system is that it's software that centrally controls a set of independent functions. There doesn't need to be a screen, a human interface, etc.
There is a lookup table (think small database) that has a set of parameters that BMW codes in that represent how BMW wants the car to run. The OS pull the sensor data from the ASIC's and puts them into RAM, then it makes comparisons to the lookup table. Then, it coordinates with the controller ASIC's to make adjustments. For example... if a sensor reports back a certain number of "non-fires" from spark plug #3, then the OS will coordinate with the fuel injector ASIC to shut off fuel to that cylinder.
The answer that I was looking for was simple. You need to look it up on OBD. I figured that was the case, but wasn't sure if there was one of the menus on the odometer that would allow me to see the version number. I was hoping it was on the odometer, because my OBD software doesn't show the version number.
So, thanks to those who answered... as for the rest of you, you just look foolish.
Old 11-20-2013, 08:12 AM   #17
wildirish317
Seems like you've done your research. I assume you've come across this? http://forum.e46fanatics.com/showpos...80&postcount=2
I'm no computer expert, but 1.5 and/or 1.7 may have what you're seeking. Good luck!
Edit: You might also try this site: http://www.bmwcoding.com/
Old 11-20-2013, 09:52 AM   #18
choxor
My Ride: JDM
No one refers to it as the "operating system". No one. Ever. Anywhere. Then you post this passive-aggressive know-it-all crap:
"Seriously... you guys don't know that one? Operating System. The Operating System version of the DME?"
Boasting on the internet is a pretty surefire way to look foolish. You got your answer. Now have spectacular day. And try not to get butthurt so easily. When someone can't take a joke and resorts to belittling other members and calling them names then posting a paragraph long list of "qualifications" there's a 100% chance that person is a douche.
Old 11-20-2013, 10:02 AM   #19
tlester
My Ride: 2001 330i
I did search, moron. how do you think I found the engineering specs?
Old 11-20-2013, 10:07 AM   #20
choxor
My Ride: JDM
Wow. Your jimmies are rustled. What's with all the name calling? Are you that insecure? Now it's time to let this sink into the abyss. Like I said, have a spectacular day.
