Old 11-20-2013, 08:59 PM   #1
chadley90
My Ride: 2002 325i
Key Fob Problems. Please Help!
Hey guys. I am a new member here. I have been trying to research my problem but I haven't found a answer to my problem. Ok well here is my problem. I have a 2002 325I and the key fob pops the trunk, unlocks the doors. but it does not lock the car. I have to manually lock the car every time. Any solutions?
Thanks guys.
chadley90 is offline   Reply With Quote
Old 11-20-2013, 09:23 PM   #2
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
Could be the gm5 module.
More info at http://bmwgm5.com/.
Encryption76 is offline   Reply With Quote
Old 11-20-2013, 09:25 PM   #3
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Really??
Originally Posted by chadley90 View Post
... here is my problem. I have a 2002 325I and the key fob pops the trunk, unlocks the doors. but it does not lock the car.
To me it sounds like the button in the key fob is bad. They go bad all the time. Try this. Unlock the car and watch the interior lights turn on. Then press the lock button and the interior lights should immediately start to fade out. If it doesn't then the key is not sending the lock signal and it most likely is because the button is bad......unless the key has been cut open and a bunch of components off have been hacked off, which also happens all the time.
scottjoh is offline   Reply With Quote
Old 11-20-2013, 09:53 PM   #4
chadley90
My Ride: 2002 325i
Just went out in this shity Chicago weather. The lights did not dim after I hit the lock button.
