Rear Diff Bushing Question/thought - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-20-2013, 10:27 PM   #1
pistonhead76
My Ride: 2000 323i
I was wondering since the rear diff bushing is such a pain in the arse to replace, has anybody come out with a pop-in replacement? I mean, keep the diff in the car or remove the rear cover, drill out the rubber and slide in a poly or hard rubber insert. Am I missing something?
pistonhead76 is offline   Reply With Quote
Old 11-20-2013, 10:29 PM   #2
JapanRot325ci
My Ride: 04 E46
do you know how heavy those rear diff are? even if it's possible the new bushing wouldn't fit snug in therefore damaging the rear diff more.
JapanRot325ci is offline   Reply With Quote
Old 11-20-2013, 10:29 PM   #3
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
no. but there's two bushings in the front. so the diff kinda has to come out if you're doing all 3.
but yes, poly just slides in. i wouldn't use poly though. the diff bushings is going to be taking most of the knocking and vibration. so putting poly there will have the harshest consequences.
Sponsored Links
Advertisement
Old 11-20-2013, 11:03 PM   #4
mitch5
My Ride: nothing
Re: Rear Diff Bushing Question/thought
Rear diff bushings are bitch but don't replace till u need to. My main was bad but the fronts were good. I replaced all three and the fronts are the worst. U can't fit an air hammer in there
mitch5 is offline   Reply With Quote
Old 11-20-2013, 11:45 PM   #5
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
I didn't find the diff bushings to be too bad. Having the right tools will make or break you on it though and the diff itself wasn't as heavy as I thought it was going to be but still a good idea to support it with a jack when you take it out.
Encryption76 is offline   Reply With Quote
Old 11-21-2013, 09:23 AM   #6
pistonhead76
My Ride: 2000 323i
So poly bushings do slide into the old rubber bearing's outer metal shell?
Old 11-21-2013, 09:32 AM   #7
GuidoK
My Ride: Z4 3.0i ESS TS2+
No, you have to remove the complete old bushing, including the metal shell of the old bushing.
E85 Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Custom Brembo BBK front/rear | Schrick cams | Schmiedmann headers/cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
GuidoK is offline   Reply With Quote
Old 11-21-2013, 12:41 PM   #8
Alex323Ci
My Ride: M3 & 323Ci (sold)
It's only hard to do if you don't have the right tools. Kinda like the rtabs. It's still time consuming but there are so many more technical and tedious jobs out there.
They do make some poly ones but as mentioned its an area that would transmit harshness on that bushing. Meyle HD makes a heavy duty version that's rubber and exact design as stock. I noticed no issues using that one years ago on my previous Coupe.
