Australia
Old 11-21-2013, 10:16 PM   #1
DatBimmer
My Ride: 330ci
Question E46 belts and pulley check
Recently my car started making a squealing noise and I narrowed it to the front of the car where my belts are.
pouring a little bit of water made the noise go very quiet but still noticeable.
I removed my serpentine belt and played around with the pulleys to make sure they were smooth and quiet...they weren't
My idler pulley and belt tensioner pulley were noisy- Ill replace those as well as my AC belt and Serpentine belt.
I checked my water pump,alternator and power steering pulleys too but Im not sure that they are functioning correctly...they make some noise and dont move as smooth.
Is this normal for those pulleys?
check my video
[embed]
DatBimmer is offline   Reply With Quote
Old 11-22-2013, 06:47 AM   #2
tottitomo
My Ride: mora metallic 325ci
Need some new pulleys there
325ci individual in Mora metallic
tottitomo is offline   Reply With Quote
Old 11-22-2013, 07:16 AM   #3
cityjohn
My Ride: 2001 M3
+1
Bearings sound dry. They should turn smooth without spinning loosely.
cityjohn is offline   Reply With Quote
Old 11-23-2013, 10:42 PM   #4
DatBimmer
My Ride: 330ci
Do I need to change all my pulleys?
I ordered and idler pulley and pulley tensioner.
What about my waterpump and powersteering?
are they on their way out too?
Old 11-24-2013, 03:42 AM   #5
TurnersInOz
My Ride: 2004 325i
Also check the tensioner on your air conditioning belt.
Many feel that changing the pulley on the PS pump to an aluminum pulley is a good idea, since the stock pulley is composite and can fail. Personally I feel better with an aluminum pulley, so I changed mine.
The WP pulley should be fine.
The tensioner pulleys (the bearings really) are common failure items.
TurnersInOz is offline   Reply With Quote
Old 12-29-2014, 09:29 PM   #6
harrykoenig
My Ride: 325Ci
Did you end up replacing all of the pulleys? If not, which did you end up replacing?
I'm hearing the pulley-bearing whine when starting a '04 325ci and think it may be the same issue.
harrykoenig is offline   Reply With Quote
belt, e46, noise, pulley, squealing
