Australia
Old 11-24-2013, 06:02 AM   #1
nibiru
My Ride: bmw 325ci
Best OEM shocks for 325ci
Hey guys im after recommendations on which OEM shocks i should buy? Im after comfort and keeping the car as stock as possible any input would be very much appreciated, cheers guys
nibiru is offline   Reply With Quote
Old 11-24-2013, 06:10 AM   #2
Jall
My Ride: 328Ci
.....Probably OEM then?
Jall is offline   Reply With Quote
Old 11-24-2013, 06:42 AM   #3
2J-SCREAMER
My Ride: 323Ci
Clickable automotive sell Bilstein B4's for $345 for a pair of fronts, and $105 each for rears, they are rated as a OEM replacement.
Excellent value imo
2J-SCREAMER is offline   Reply With Quote
Old 11-24-2013, 10:25 AM   #4
sihyonkim
My Ride: E46 325i
Can you installed lowered springs on the B4 shocks?
sihyonkim is offline   Reply With Quote
Old 11-24-2013, 10:28 AM   #5
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
Lol. This.
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 11-24-2013, 04:11 PM   #6
Davconelectric
My Ride: 2 dog powered sled
Lol
Davconelectric is offline   Reply With Quote
Old 11-24-2013, 06:56 PM   #7
2J-SCREAMER
My Ride: 323Ci
Yes, lowering springs can be used, however, these shocks are a OEM equivalent, so if you're planning to slam your car, these will not be ideal as they are simply not designed with lowering in mind, Bilstein produce a shock specifically designed to be used with lowering springs. Regarding the B4's though, mild lowering will be fine as it won't compromise the shocks range of travel too badly.
Old 11-24-2013, 07:06 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Sachs/Boge shocks
Old 11-24-2013, 07:28 PM   #9
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Originally Posted by Solidjake View Post
Sachs/Boge shocks
Why move this out of Aus forums? Availability of some brands in Aus would be very relevant to OP's question.
E46 Coupe is offline   Reply With Quote
Old 11-24-2013, 07:37 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
so be it
Old 11-25-2013, 12:49 AM   #11
dsio
My Ride: E46 328i / 330ci
Just changed mine to Eibach Pro Kit springs / Koni FSD shocks and they've been brilliant, the ride quality and smoothness is amazing, if comfort is what you're after its well worth a look.
2000 330CI Sienna Red 5sp Manual
dsio is offline   Reply With Quote
Old 11-25-2013, 01:39 AM   #12
brett05
My Ride: 325Ci
I rang Brisbane BMW for a quote on OEM rear shocks and old mate said that they used a number of manufacturers at the time. He said for the price the dealer charges, he wouldn't bother... just use a good quality shock.
brett05 is offline   Reply With Quote
Old 11-25-2013, 02:27 AM   #13
JS330
My Ride: '01 330Ci 3 Pedals
so be it
good. good.
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 11-27-2013, 10:23 PM   #14
Ballistic325
My Ride: slow and steady
Remember that when replacing the shocks it's a good idea to change other associated hardware... if you're changing shocks the other components have probably expired as well. Some stuff that comes to mind:
- front strut mounts
- sway bar links and bushings
- rear shock mounts
When you add it all up it may be more worthwhile to go for a basic coilover kit that includes the mounts etc. Just a thought....
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-30-2013, 04:46 AM   #15
sprintman
My Ride: Ex 325CI owner
That's the combo I had and it was a revelation. Comfort and control when pushed.
sprintman is offline   Reply With Quote
Old 11-30-2013, 04:47 AM   #16
sprintman
The OEM shocks are junk. Look elsewhere.
Old 11-30-2013, 04:52 AM   #17
dsio
Exactly, those steel checkerplate speedbumps that used to crunch the undercarriage, the potholes it used to crash into and even my crap driveway entrance are smooth as, but then you change lanes rapidly at high speed or take a corner near the limit and its nice and stiff, wish I'd done it years ago.
Old 11-30-2013, 08:38 PM   #18
sihyonkim
My Ride: E46 325i
Wheres the best place to buy the Eibach Pro Kit springs / Koni FSD shocks combo? From the states?
Old 11-30-2013, 08:40 PM   #19
dsio
I got mine from a local shop, Koni/Eibach is fairly widely sold here so they're not too hard to find, its probably better to buy local for warranty reasons too.
Its also a heavy thing to ship and above the $1k threshold as a set so you're going to have less hassle locally.
Old 12-01-2013, 01:15 AM   #20
sprintman
Got mine locally. Warranty will be tough if ordered overseas.
