Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Pacific Northwest
Pacific Northwest
AK HI ID OR WA
Old 11-25-2013, 02:56 PM   #1
JDUTHIE
My Ride: 2003 325xi
Fs... Lots... All obo
http://seattle.craigslist.org/est/pts/4201521167.html
For sale:
-All part picture gladly upon request.
-Will have a phone tommorow # two oh six. three 7 five. 0 five 7 four.
e46: all parts removed @50k
-A/c compressor and all associated hoses -250 obo
-Washer fluid tank - 25
-Washer fluid pump- 20
-Water pump- 30 (will include core box for lifetime warranty)
- 325xi front tie rods, inner and outer. (both outers good, aswell as the passenger inner. driver inner is loose) 100 very obo
-m54b25 DISA valve (2X)- 50
-Auto shift knob- 15
-DSC control unit with HDC, missing front cover- 80
-A/c condenser fan- 100 obo
-Front air ducts for radiator- 30
-Front skid plate for 325-330xi- 75 obo
-A/c compressor mounting bracket with all hardware- 25 obo
-A/c hydraulic belt tensioner- 80 obo
-Fan clutch- 50 obo
-Headlight lenses scratched- 10 obo for both
-Fan shroud- 40 obo
-Square airbag- 150obo
-Passenger airbag- 150obo
-GM 5L40e @ 87k- 750 obo (fluid/filter changed @60k)
-rear storage trays (one with hole cut in back for REQ)- 10
-JVC radio harness adapter- 15 obo
-front ashtray- 10 obo
-Single din radio plate-10
-ignition switch (unopened)-50
-TMS solid differential mounts (never installed) 150 obo
-Front air duct for intake. 10 obo
-Spare wheel cover- 10
-325 intake manifold-75
-Idle control valve-50$
-Vacuum purge valve x2- 20$
-blown TCkline adjustable rear KONI struts (1 is good, one needs new seals) 100$ obo
-ccv- 10$
-purple and black injectors-50$ for 6x
-m54 fuel rail- 10$
-325 throttle body-50$
-chopped m54b30 harness (good for spare connections) 10$
-1 clear corner- 5$
B5 s4: (or any other 5x120 audi)
ECS 1 inch spacers with extended lugs- 120 obo (will seperate, only on car for 3k. turbos went after first oil change, s4 parted now )
Generic parts:
2 12'" sub-woofer enclosure 50 obo
pol audio DXI 12in sub- 50 obo
JDUTHIE is offline   Reply With Quote
Old 11-25-2013, 04:05 PM   #2
JDUTHIE
My Ride: 2003 325xi
e46XI cardone axles-35$
Old 12-06-2013, 02:34 PM   #3
JDUTHIE
My Ride: 2003 325xi
BUMP
-e46/xi 5 speed with coupler >80k 800 obo
-e46 supersprint headers. 600+ your stock manifolds
-longtube intake with k&n filter 50 obo + stock box
_beyern mesh 18x8.5 (rashed)600 (refinished) 800
Old 12-06-2013, 02:44 PM   #4
JDUTHIE
My Ride: 2003 325xi
red label 413 ecu- 100 obo
rubber trunk liner OEM- 75 obo
-halogen headlight housing (perfect) 250 obo for both. will seperate (entire housing, including bulb holders)
-e46 xi, exhaust, Res delete, and 2 ar20s (LOL LOUD) free+ stock exhaust.
-4 willwood SL3's (4 piston X 1.25 cups) radial mount. Selling as cores, one has tabs broken, the rest just need a blast and powder coat. 3/4 are usable, and comes with brackets. 150 obo.
-EBAY strut bar, 15 obo
-E90 upper spring perches (good for a .5in drop on RWD) 25 obo (BNIB)
Old 12-06-2013, 03:40 PM   #5
JDUTHIE
My Ride: 2003 325xi
m54b30 throttle, ported & polished (lumpy idle, needs a custom plate) 20 obo
Old 12-06-2013, 11:12 PM   #6
clayfosterr
My Ride: 2003.5 SilverGrey M3
What color is rubber trunk liner?
clayfosterr is offline   Reply With Quote
Old 12-06-2013, 11:17 PM   #7
GuiltySpark
My Ride: 02 325xi
Ugh, you're on the other side if the country
GuiltySpark is offline   Reply With Quote
Old 12-06-2013, 11:18 PM   #8
GuiltySpark
My Ride: 02 325xi
Of*
Old 12-06-2013, 11:18 PM   #9
Dbills
My Ride: 99' 328i
Got a radiator?
Dbills is offline   Reply With Quote
Old 12-06-2013, 11:20 PM   #10
GuiltySpark
My Ride: 02 325xi
Sorry for the triple post but what about your transfer case?
Old 12-10-2013, 12:11 PM   #11
JDUTHIE
My Ride: 2003 325xi
@GUILTY will ship
@clayfoster its black
Old 12-10-2013, 12:12 PM   #12
JDUTHIE
My Ride: 2003 325xi
t-case is not available. Im not parting my car Ive just been into e46's for almost 7 years now so ive amassed a huge quantity of parts. Im selling everything I had planned to put into my e46 and getting an e30, so what ever is on the list is what i have (for the most part)
Old 12-10-2013, 12:35 PM   #13
clayfosterr
PM'd
Old 12-10-2013, 04:22 PM   #14
JDUTHIE
My Ride: 2003 325xi
bump
Old 12-11-2013, 02:52 PM   #15
JDUTHIE
My Ride: 2003 325xi
Buy my parts!!!! Must get e30!!!
Old 12-11-2013, 02:54 PM   #16
JDUTHIE
My Ride: 2003 325xi
Ahhahah open to trades for e30?
Old 12-11-2013, 05:28 PM   #17
JDUTHIE
My Ride: 2003 325xi
e36 M3 H&R rear springs (race)-$120 obo
Old 12-17-2013, 12:49 PM   #18
JDUTHIE
My Ride: 2003 325xi
bump
Old 12-17-2013, 06:48 PM   #19
JDUTHIE
My Ride: 2003 325xi
Obo!! Will accept low ball offers.. My tranny blew today : (
Old 01-07-2014, 11:13 AM   #20
JDUTHIE
My Ride: 2003 325xi
-97 m3 clutch flywheel and pressure plate. 150 (<5k) will measure disk if interested.
-m54b30 crank- 200 obo
-5 m54b30 rods and pistons- 80 each/ all 5 for 150
-m54 head- (1 bent valve) 100 obo
-m54 oil pump- 75 obo
-vanos cover- 50 obo
- crank sensors- 15 obo
- 2x vanos solenoids- 20 each.
