Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 11-28-2013, 06:43 AM   #1
Nick325xiT 5spd
BMW Land Barge
My Ride: '04 M3 & '99 323i
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd
Oil Pump Failure
OK, so next question: SpecE46 has settled on the 330. Unfortunately, the M54B30 has that rather expensive oil pump shearing problem in race cars. Will there be a solution offered?
Nick325xiT 5spd is offline   Reply With Quote
Old 11-28-2013, 10:01 AM   #2
Evice
My Ride: Spec E46, 128i, 981
Take a look around a little bit more Here is James' take on it.
http://forum.e46fanatics.com/showpos...78&postcount=5
Evice is offline   Reply With Quote
Old 11-28-2013, 10:50 AM   #3
Lercs
My Ride: 00 328i, 00 323it
As per the rules, either weld the oil pump nut, or use safety wire to secure it.
Evice: that appears to be James' take on the problem with the harmonic balancer. At 8legs we haven't had a problem with our extremely well used ones (and we rev to 7500), but I have heard it can be a problem. A fresh balancer every year is a great preventative maintenance thing, but with the stock redline, I don't see a problem as long as you start with a good one.
Follow 8legsRacing on twitter and Facebook
@8legsracing
www.facebook.com/8legsracing
www.8legsracing.com
Lercs is offline   Reply With Quote
Old 11-28-2013, 10:57 AM   #4
Nick325xiT 5spd
BMW Land Barge
Welding and safety wire do nothing when the problem is that the shaft actually shears off. It's a problem specific to the M54B30 when raced.
Old 11-28-2013, 11:28 AM   #5
Spec E46
Moderator
can you point us to specific examples of that happening? who was racing it, and in what class? what other modifications had been done?
Spec E46 is offline   Reply With Quote
Old 11-28-2013, 11:58 AM   #6
Lercs
Our team has been racing e46s for a while, with M54B30s and the only time we had a failure was when a bolt loosened off.
Just for reference (more than one engine has been run), we have custom pistons and rods, 11.5:1/12.5:1 compression, ported and polished heads, custom ground cams, solid lifters, springs, lightweight flywheels/clutches, stock and aftermarket harmonic balancers, rev to 7500-7800 rpm and produce well over 300hp.
We have since changed to a different oil pump bolting system, but only because we really didn't want it to fall off again. (it puts a damper in your weekend! lol)
I don't think at the stock RPMs that the oil pump will be a problem, especially if safety wire is added.
@8legsracing
www.8legsracing.com
Old 11-28-2013, 11:59 AM   #7
Nick325xiT 5spd
BMW Land Barge
Talk to anyone who ran a 330 in GAC. Stock motors. TC Kline developed an oil pump that didn't fail, but that got discontinued LONG ago.
Old 11-28-2013, 12:10 PM   #8
Lercs
VAC makes a part
http://store.vacmotorsports.com/vac-...kit-p1077.aspx
We have it on one of our engines, works as advertised (we have used it for the last season)
@8legsracing
www.8legsracing.com
Old 11-28-2013, 12:44 PM   #9
Evice
Oil Pump Failure
Turner also have a BMW Motorsport kit.
http://www.turnermotorsport.com/p-18...eller-kit.aspx
- Ali #718 SE46.
Old 11-28-2013, 03:43 PM   #10
Nick325xiT 5spd
BMW Land Barge
VAC makes a part
I have the VAC kit, but it's still know to fail in 330s.
Old 11-28-2013, 04:19 PM   #11
Nick325xiT 5spd
BMW Land Barge
I don't think that that is in the spirit of the class either.
Old 11-28-2013, 06:46 PM   #12
Spec E46
Moderator
as long as it doesn't provide a performance advantage, optional items that improve durability or reliability are well within the spirit of the class. they just need to be petitioned and written into the rules.
Old 11-28-2013, 07:51 PM   #13
Nick325xiT 5spd
BMW Land Barge
You're kidding, right? A $3,000 oil setup? What about dry sumping?
Old 11-28-2013, 07:58 PM   #14
Evice
Oil Pump Failure
It is an example. Stop derailing from the main topic.
- Ali #718 SE46.
Old 11-28-2013, 08:07 PM   #15
Nick325xiT 5spd
BMW Land Barge
I started this topic. How exactly am I derailing it? And really, a $3,000 oiling system in a spec class is not a serious solution.
Old 11-28-2013, 08:22 PM   #16
Spec E46
Moderator
even if it were allowed, it would be OPTIONAL. relax.
Old 11-28-2013, 08:27 PM   #17
Nick325xiT 5spd
BMW Land Barge
Optional parts have the bad habit of becoming either mandatory or necessary...
Old 11-28-2013, 09:36 PM   #18
vaio76109
My Ride: Race Cars
I'm working on being able to source the modified 4 bolt pumps again, but no promises. Similar to the pump that TCKline used to sell, several people on this forum run it as well as in Grand-Am 330's back in the day. It and the $2700 motorsport part are the only bulletproof solutions, IMO.
It would not provide a "performance advantage", unless you consider being able to stay on track by not blowing motors a "performance advantage" .
vaio76109 is offline   Reply With Quote
Old 11-28-2013, 11:14 PM   #19
jtower
My Ride: spec e46
my own *personal* definition is:
performance advantage = lower lap times
competitive advantage = enhanced durability/reliability
in spec e46 any modification that provides a competitive advantage without a performance advantage is fine, and will generally be permitted provided it has no other negative impact. the current rules permit many parts to be replaced for this very reason. in other series like chumpcar (which i am also intimately familiar with) where races are much longer and durability plays a larger role, such a modification may not be allowed or will affect your valuation. however, a modification that increases both performance and competitiveness is far less certain and will be rigorously scrutinized by the rules committee.
jtower is offline   Reply With Quote
Old 11-28-2014, 10:28 AM   #20
Raypratojr
My Ride: 2001 330ci
I'm currently shopping for a fix for this potential oil pump issue. What is the consensus on what is necessary or what is over kill. Many options in the $200-300 range.
Ray
Raypratojr is offline   Reply With Quote
