The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 12-01-2013, 02:26 AM   #21
Flop
My Ride: '04 330Ci 6MT
Originally Posted by choxor View Post
Ever wonder why we have a showroom section?
Haters gonna hate...
But in all seriousness, I agree with you. Just requested that the mods move it for me.
Flop is offline   Reply With Quote
Old 12-01-2013, 12:32 PM   #22
thesixsins
My Ride: 2004 IMOLA 330i ZHP
Welcome fellow Portlander!
thesixsins is offline   Reply With Quote
Old 12-01-2013, 12:47 PM   #23
indoafro
My Ride: 325ci
Project "D-D/D" (daily driver/drifter) | 330Ci Build Thread
what exactly i want to do to my car! subscribe!
indoafro is offline   Reply With Quote
Old 12-01-2013, 01:04 PM   #24
.BLinK.
My Ride: 2005 325i
Subscribed
.BLinK. is offline   Reply With Quote
Old 12-01-2013, 08:04 PM   #25
Flop
Small update.
Finally got my ZHP shift knob on. I didn't believe changing the knob could make such a difference. Boy was I wrong. Shifts are crisper and just feel more "solid".
I can't imagine what shifting will be like once all of this goes on
Old 12-13-2013, 08:46 PM   #26
Flop
Time to start "solidifying" the rear end.
These will be going in later this month:
- AKG aluminum subframe bushings
- AKG 95a differential bushings (to hopefully tame diff whine)
- Turner subframe reinforcement kit
Stay tuned for install pics!
Old 12-13-2013, 08:52 PM   #27
Avetiso
My Ride: 2003 ZHP 6MT
Re: Project "D-D/D" (daily driver/drifter) | 330Ci Build Thread
Are solid bushings recommended for daily driving at all?
Sent from my SM-N900T using BimmerApp mobile app
Avetiso is offline   Reply With Quote
Old 12-13-2013, 08:57 PM   #28
Flop
Not really. But neither is a welded diff.
Old 12-13-2013, 09:09 PM   #29
wildirish317
My Ride: 2004 325Ci vert
Flop, meet Teddy7: http://forum.e46fanatics.com/showthr...0006&highlight=
I think you have a lot in common....
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 12-14-2013, 12:03 AM   #30
Yassrab
My Ride: 2004 BMW 325xi
Awesome car, love the colour !
Yassrab is offline   Reply With Quote
Old 12-14-2013, 12:41 PM   #31
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Mason Engineering makes a nice rear subframe support/rear strut bar that should be good for distributing the subframe loads since the rear floors are so weak. Will work well when combined with subframe reinforcement. Also I hope you're not doing solid motor/trans mounts, there is quite a bit of documentation of them causing a lot of things to vibrate/loosen. A good stiff poly or E9x M3 mounts should be sufficient for your purposes. Lastly...you might want to think about securing the OPN. Looking forward to seeing the build progress!
Chris
dreamdrivedrift is offline   Reply With Quote
Old 12-15-2013, 04:19 PM   #32
Flop
I plan on fabricating something very similar to the mason engineering unit, except it will be welded in.
And I have heard horror stories about solid motor/tranny mounts! I have the UUC (I think) isolated tranny mounts that will be going in shortly, which seem to have great reviews. Still undecided about motor mounts, but nothing too aggressive.
Securing the OPN? Please explain!
Old 12-16-2013, 08:47 AM   #33
Teddy7
My Ride: slides
lol, thanks irish
Teddy7 is offline   Reply With Quote
Old 12-16-2013, 09:06 AM   #34
Teddy7
My Ride: slides
In my opinion, they should be recommended on all e46's even though they aren't. The solid subframe bushings will help to not only provide a larger mating surface at each mount but also will aid in preventing deflection under acceleration/braking. I strongly believe this extra rigidity will extend the life of any e46 subframe especially when paired with a reinforcement. The best combo for lasting life of the subframe, in my opinion, would be solid subframe bushings with stock rubber diff bushings. That way your diff transmits the least force on the subframe and your subframe is mounted the best that it can be.
I personally have solid subframe and diff mounts, but looking back, OP's combo of solid subframe and 95A diff bushings is probably what I should have went with.
Old 12-16-2013, 09:07 AM   #35
Teddy7
My Ride: slides
I'm glad you are going with a welded unit. The mason product seems to be constructed very well, but for the money, you can basically cage the trunk area properly.
As for the tranny/motor mount discussion, I simply went with oem M3 trans and motor mounts. I thought about going poly, but also heard the horror stories as well. The M3 mounts are great. Very firm with no unnecessary noise increase.
Subscribed and excited to watch your progress. Good luck!.
Old 12-17-2013, 11:29 AM   #36
Flop
Those are my thoughts exactly. I was STRONGLY advised by AKG to not go with solid subframe bushings on a DD. However, I think if done right (reinforced subframe and integrated rear strut bar), it is the best option. The front subframe and one of the suspension mounting points are solidly mounted to the chassis, why shouldn't the rear? And like you said, if vibrations are an issue, I can always pop in OEM diff bushings.
Thanks! I'm sure I will have some build/drift questions for you later down the line!
Old 12-27-2013, 01:33 PM   #37
Flop
Christmas Update!
I have been working on the car for about 2.5 days solid now.
Completed so far:
- All subframe and differential bushings replaced with AKG units
- Turner subframe plates are in (more on this below)
- Rear strut tower bar with integrated subframe reinforcement has been fabbed (just needs to be painted and welded in).
- Picked up a 3.38 differential and welded her up
- Rebuilt shifter with all new bushings and components (shifts like a DREAM!)
- Replaced transmission mounts with UUC isolated units
Still to do:
- Stainless brake lines
- Clutch delay valve delete
- Put everything back together!
More on the subframe plates:
For multiple reasons, I have decided to JB Weld the front plates to the unibody. The first reason is that they are in very close proximity to the gas tank, and welding in that area scares the crap out of me. Second, I believe that JB welding the front plates in creates a MORE structurally sound and strong subframe mounting point versus welding. Reason being is that the entire mounting surface is bonded to the plate, rather than just one plug weld and around the edge.
I would not recommend JB Welding the rear plates in, though. The mounting surface is not flat and would not work as well with JB Weld like the fronts. The reason the front plates work so well with JB Weld is that the mounting surface is very flat and they can be clamped TIGHT with the subframe stud, creating a very strong bond.
Alright, onto the pics.
Jacked up nice and tall (this was quite the process to do)
First thing out, exhaust.
Subframe out.
Easiest way to deal with the hand-brake cables is to disconnect them front center-console area.
Getting the subframe bushings out was easier than I expected. Get a strong drill and start drilling out the rubber portion, hammer out the center aluminum piece, and then use a flat chisel to start crumpling the bushing into itself.
All out!
The large rear diff bushing was a bit harder. I tried the subframe bushing method, but the outer sleeve is steel, not aluminum, and wouldn't crumple. As a result, I ended up making up a puller real quick and pulled the bushing out. That thing was in there TIGHT.
I inspected the subframe mounts... No Cracks!! I was very happy to see this.
Use thermal expansion to your advantage. Subframe bushings go in the freezer, and the receiving holes het heated. The bushings slipped in with minimal pounding. Make sure to use a block of wood or equivalent, as to not dent the aluminum. You can also see I lined the holes with anti-sieze, just incase I ever want to remove them.
Note about the AKG bushings. The rear lower bushings were VERY loose in the bushing holes. So loose that I had to make 3 dimples on each side of the steel to keep them from vibrating around. Because of this, I would not recommend AKG aluminum bushings. I have not heard of other aluminum bushings from different vendors having this problem.
New diff bushings installed.
Rear plates welded in. Not my best work, but it will do.
Front plates bonded.
No cracks!
A common upgrade for the E46 is to use the E60 shifter. I couldn't find definitive evidence on this board whether or not it would work with 6 speed transmissions, so I gave it a shot. The E60 shifter is IDENTICAL in length (below and above the shift ball) to the stock 6 speed shifter.
New bushings and components.
Starting the rear reinforcement bar. These plates will get welded to the strut tower, and those holes will be plug welded.
Mocked up.
All fabbed up. Just needs to be painted and welded in.
More updates to come in the next few days
Old 12-27-2013, 01:55 PM   #38
Zatarain
My Ride: 2000 323Ci
When you put in the spacers, did you use the same lug bolts or did you have to buy longer ones?
Zatarain is offline   Reply With Quote
Old 12-27-2013, 02:30 PM   #39
Flop
Longer ones definitely. The stock ones won't even reach the threads with the spacers!
I bought the ECS spacer kits, which came with lug bolts.
Old 12-27-2013, 02:35 PM   #40
Zatarain
My Ride: 2000 323Ci
Oh nice, thanks for the info man. Real nice car by the way.
