Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 101 votes, 5.00 average. Display Modes
Old 12-22-2013, 02:11 AM   #41
nut
My Ride: 04 LSB M3 SMG
1. Google navigation app makes the unit reboot while running.
2. Pandora is background force-closing with internet connection.
3. Statics noticeable above volume 20ish when mute/not playing/pause. I'm running RCA connection to aftermarket amp.
#1 is a major issue for me, #2 and #3 being minor issue, I'd say.
ROM update would fix #1 & #2 bugs easily.
•Dinan CAI+Free Flow Exhaust w/ Stage 3 software
•KW V2
•Brembo GT 355mm 6pods + 345mm 4pods
•VMR VB3 19" + Ventus V12 EVO K110
•Headlamp retrofit: S2k projector + 85122cm + eas AE
•SCSL dual CF trunk
•E90 key retrofit w/ greater remote distance! + Start Engine button mod
•Auto-fold side mirror retrofit
_____________
For Sale:
•ZHP Alcantara steering wheel (Cond. 8.5/10)
nut is offline   Reply With Quote
Old 12-22-2013, 03:51 AM   #42
tommy@avinusa.com
AKA: M3Evolution
My Ride: 2003 M3 SMG
Google Maps issue seems to be common on many devices. It appears to be random but we are working on finding a solution for this. All other GPS navigation apps are working great and do not experience this issue. Please contact us directly and we will help everyone on a case by case basis.
http://www.androidpolice.com/2012/08...on-a-solution/
https://www.google.com/search?q=goog...m=122&ie=UTF-8
tommy@avinusa.com is offline   Reply With Quote
Old 12-22-2013, 03:56 AM   #43
Haug523
My Ride: Bmw E39 523
Is the google maps issue only affecting US Users or T-Mobile? i guess it won't be a big issue for me as i will be using Tomtom or Sygic
Haug523 is offline   Reply With Quote
Old 12-22-2013, 10:29 AM   #44
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Originally Posted by ReactiveShooter View Post
I will go ahead and say that the "static" is completely unnoticeable even when the engine is off unless you are somewhere very quiet such as the garage. For me it is a complete non-issue and I am a bit if an audiophile. I would not let the static issue effect your purchase decision.
Also, unless there is something I don't know about audio systems(I have built several), a line output converter would not effect this issue. A LOC could only lower the overall output of the head unit, which you can much more easily do buy turning the volume knob. The static is only noticeable at high volume levels, when you turn the volume below say 15 it is no longer detectable. adjusting the output down with a LOC would be just the same as turning the unit down. A LOC only becomes necessary when a source device has noticeable static/noise output even at low or no volume, such as an old, badly shielded source with internal static introduced after the amplification circuits. The static in the Avin unit is being introduced before the internal amplification, therefore a LOC will have no more effect than adjusting the volume of the head unit itself. If I'm making sense.
Correct, an LOC would not be relevant in your case. But turning up any stereo and pressing pause you are going to get some level of noise, in the case of the avin its going to depend on the app/feature, bluetooth for instance is going to have more noise than CD. But as you noted, its a non issue in regular use.
My LOC advice was for the guy having low level noise, he specifically noted volume levels of 0-1.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 12-23-2013, 04:54 PM   #45
Dr3wX5
My Ride: X5 3.0i
I got my X5 version head unit in today. I have no idea how to install this.
Can anyone throw some hints on where these connectors go? They do not seem to match my OEM connectors.
Dr3wX5 is offline   Reply With Quote
Old 12-23-2013, 04:56 PM   #46
Dr3wX5
My Ride: X5 3.0i
On my last post, I do not know where the connectors on the third image go. Any help will be greatly appreciated.
Thanks,
Andrew
Old 12-23-2013, 05:07 PM   #47
Haug523
You have Dsp, it says on Avin's site that the player isn't compatible with DSP, i guess you'll have to return it or buy some aftermarket amps and speakers.
Old 12-23-2013, 05:09 PM   #48
Dr3wX5
My Ride: X5 3.0i
No DSP
Uhh no. I do not have DSP. I have the standard sound system. I don't know why you assumed that.
Old 12-23-2013, 05:10 PM   #49
nut
I haven't seen left one but can tell you about right one. Maybe X5 version is different from E46 one?(I have short memory...
You just connect the wire-end to another connector, not the black plastic housing one. You can leave the black housing side as it is.
•KW V2
•SCSL dual CF trunk
_____________
For Sale:
Old 12-23-2013, 05:17 PM   #50
Dr3wX5
My Ride: X5 3.0i
I also have this connector.
The end next to the head unit plugs straight into the head unit and the other end goes into the long extension cable. I am guessing those two other connectors in my previous post (image three) are not needed for my case?
Old 12-23-2013, 05:27 PM   #51
nut
I needed all the cables to be connected to each other(or headunit). Check the labels attached to the wires and refer to the diagram. It will help you understand the system little bit more.
•KW V2
•SCSL dual CF trunk
_____________
For Sale:
Old 12-23-2013, 05:29 PM   #52
nut
Once again, it's for X5 so I might be wrong...
•KW V2
•SCSL dual CF trunk
_____________
For Sale:
Old 12-23-2013, 05:59 PM   #53
J&T Distributing
My Ride: BMW
Like all BMWs with Nav the radio module in your X5 is in the trunk, under the floor, next to the battery and spare tire under a plastic cover. Thats why you go the extension harness, to run all the wiring back there.
Everything only plugs in one way, lay it out on the table like you have done and plug everything in until it makes sense.
Old 12-23-2013, 06:00 PM   #54
Dr3wX5
My Ride: X5 3.0i
I figured it out. one of the connectors on post 45 (image 3) was used. It was flat pin connector type that was originally connected to the OEM radio tuner. I did a test install and it works! The audio quality is amazing! I had the BSW package installed over 5 years ago and with this new head unit you can really hear the difference. Haven't tested other stuff yet, but I will after I do the install.
Also does anyone know where I wire the park and illumination wires to?
Old 12-23-2013, 06:09 PM   #55
J&T Distributing
My Ride: BMW
you wont use the park wire but the illumination wire needs to go to a dash illumination circuit wire.....there is one in the plugs that were originally plugged into the oem screen.....
Old 12-23-2013, 06:12 PM   #56
Haug523
Because this user had troubble installing a Hualigan into his X5 because of DSP, he have the excact connections as in your car:
http://forums.bimmerforums.com/forum...ew-Info/page48
There's also a workaround, should work with the Avin aswell:
http://www.xoutpost.com/bmw-sav-foru...rough-diy.html
I see you solved it
Old 12-23-2013, 06:40 PM   #57
Dr3wX5
My Ride: X5 3.0i
Yeah I did, thanks everyone for the suggestions. Just need to route all the wires which I am in the process of doing. This is the boring part. I am routing it under the door sills. I will show my install once I am done.
Jeff, do you happen to know which wire the illumination one is, in the blue plug? Should I be looking for an orange wire since the supplied illumination wire is orange?
Thanks,
Andrew
Old 12-24-2013, 03:15 PM   #58
J&T Distributing
My Ride: BMW
no, the wire colors will be different, the AVIN uses standard industry color codes (orange is illumination). Car manufacturers all use their own proprietary color codes. I dont recall off the top of my head what the wire is you need to tap into but its easy to figure out with a multimeter or test light.
Old 12-24-2013, 06:50 PM   #59
Dr3wX5
My Ride: X5 3.0i
Hey Jeff, I figured it out, the wire that needs to be tapped for illumination is a gray/red wire which is on the blue OEM plug. This applies for the X5 with factory navigation. The light is on regardless of the dimmer dial. It is on only when headlights/parking lights are on.
The problem I am having now is routing the extension cable. I originally routed it under the door sills and through the B-column but it is just too thick. I cannot put the trim pieces back on. Jeff do you happen to know any alternative locations where I can route the cable?
Old 12-24-2013, 07:26 PM   #60
J&T Distributing
My Ride: BMW
Don't put it directly under the sills, put it under the adjacent carpet, the carpet and pad is a lot more flexible and forgiving than plastic trim parts.
