Old 01-02-2014, 01:08 PM   #21
zaharias
My Ride: M3 E46 6MT 3/2005
I think the cost off an ESS TS2+ is almost the same as the TT stage 2..
The TT stage 2 produces at the wheels what the TS2+ at the crank..
Iam between these 2 also.. i ve sent an email to Nick..
I believe the TT kit would be more fun..
Any info on the longevity of the TT kit? Anyone? How many millage before and after the kit installation?
zaharias is offline   Reply With Quote
Old 01-02-2014, 03:50 PM   #22
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
I can't provide you a comparison, but I do just want to chime in and mention (not directed at the OP or anyone in particular, but good to know up front), that at the power levels we're talking about with either kit, I can't recommend installation without a pretty comprehensive upgrade to the suspension, brakes, and the wheels/tires.
Running double the factory output or more on stock suspension and brakes is a bad idea, they simply cannot cope with the tremendous increase in power. The problem is that most people see a single number, the cost of the kit, and don't realize that the true cost is something like kit + $3-6k suspension + $800-3k brakes... A quality LSD is highly recommended as well.
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 01-02-2014, 07:53 PM   #23
pokeybritches
My Ride: G-Power Z4M, VF Z4
ESS TS2 Supercharger VS TT Stage 1 Turbo
Agreed. You're also going to want gauges and maybe a new clutch ($$). Parts will need to be replaced during the install. Then there's that whole labor thing regarding the install... removal of the head for the MLS head gasket for the TT Stage 2.
Installs rarely go as smoothly as planned for the inexperienced.
G Power Z4M and VF Engineering Z4 3.0i
pokeybritches is offline   Reply With Quote
Old 01-03-2014, 12:35 AM   #24
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Maybe I missed this, What side of your Bimmer is your steering wheel on ?
If right side, doesn't your steering shaft interfere with things like exhaust headers ? This would make a TT install difficult.
SUMMIT POINT WV 1:24:229 SCCA
Old 01-03-2014, 04:00 AM   #25
zaharias
Hi Rob! Happy New Year!!
You got confused because my car was originally a 2.0L (LHD) but then i got a M54B30 swap from a RHD vert from UK.. i just have the RHD head with less bolts/studs.. compared to the LHD.. (maybe you remember something from the thread with the M52/M3 E36 headers to M54)
Old 01-05-2014, 03:07 PM   #26
baz11
My Ride: 05 ZHP TTStg1
have a 330i with 110.5k, TT Stg 1 w/ boost controller was installed around 71k. Compression check was done ~108.5k:
#1 - 180 psi
#2 - 192
#3 - 180
#4 - 185
#5 - 180
#6 - 190
This was after approximately 50k with the kit installed.
baz11 is offline   Reply With Quote
Old 01-05-2014, 05:25 PM   #27
zaharias
Smile
Originally Posted by baz11 View Post
have a 330i with 110.5k, TT Stg 1 w/ boost controller was installed around 79k. Compression check was done ~108.5k:
#1 - 180 psi
#2 - 192
#3 - 180
#4 - 185
#5 - 180
#6 - 190
This was after approximately 40k with the kit installed.
Thank you my friend!!
Old 01-05-2014, 07:42 PM   #28
baz11
Correction - The kit was installed @ 71k. So closer to 50k on the kit now and no issues to report
Old 01-06-2014, 02:38 AM   #29
nleksan
38k since engine build and pseduo-TS3+ install, of which between 1/4 and 1/3 were on the track (so between 5k and 8k rpm, whichiItthink would be about a 2-3:1 compared to Street miles?).
Did a full teardown and inspection (well, my friend and retired BMW Master Mechanic did) at the 20k mark post build, and there weren't even any marks on the cam lobes! The engine was clean as a whistle and looked like the day it was firstassembled.
I ggive credit to the combination of the Swain Tech coatings and WPC treatments (the entire engine pretty much), and just as much to Redline oil. I can't recommend these enough!
I don't have any compression test numbers, my friend just said the delta was no more than 3, and when compared to first built, no more than5. I bbelieve they were around 198-201?
(Temporary Sig)
GARAGE:
Old 01-06-2014, 05:29 AM   #30
zaharias
Originally Posted by pokeybritches View Post
What about the single O2 sensor conversion that isn't quite as smooth as OEM?
Can someone give more info on this?
I understand why it has to be done this way.. why it isn't smooth as oem?
Old 01-06-2014, 05:50 AM   #31
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
It potentially can be less smooth if it's not done well, but aside from that, I don't understand the comment.
The TT kit idles just like stock, and has smooth part throttle transitioning as long as all the hardware is in good running order. If your OEM O2 sensor is bad, there's nothing any kit can do about it.
Old 01-06-2014, 06:14 AM   #32
Davew
My Ride: 2004 330ci Msport
A little off topic, but when comparing the two, I can't help but think of a hybrid of the two, TT setup as is, with the long runner laminova cored ESS manifold to keep that air extra dense
Davew is offline   Reply With Quote
Old 01-06-2014, 06:51 AM   #33
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I've thought of going 1 further: Both kits (Compound FI) running with a stand alone ECU.
Old 01-06-2014, 08:36 AM   #34
mdrobnak
My Ride: 04 330i SMG TT STG1
Yeah, I think they might have taken that comment from my initial review thread - what they missed was that the lack of smoothness was due to wastegate contact with the body.
The kit starts and idles BETTER then stock on MS45.
-Matt
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
