E46 M50 Turbo 700HP+ - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-28-2013, 12:36 PM   #41
Twin_Turbo_S54
My Ride: M3
Originally Posted by GeorgeGG View Post
neither is easy to source, i have to import any of them.
so better do it once and do it right.
we do not have Drag strip with glue, only pure asphalt, so sticky tire is preferable that will do a good job for Highway racing and good job for drag race.
what you guys think about those wheels
Aero 50 Series Black Roll-Formed Wheel 15"x12" 5x4.75" 50-124720
it has -114mm offset, center bore is bit big but its not an issue ill machine ring for alignment in center
does anybody know anything about aero wheels?
Test a set of 275 tires on 9,5"-10" wheels.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 12-29-2013, 06:00 AM   #42
GeorgeGG
My Ride: 323
I can not get 275 tires and 10j wheels locally i have to import and it is not cheap to spend money just for test
I thought to get 325 50 r15 tires and 12j wheels
GeorgeGG is offline   Reply With Quote
Old 12-29-2013, 08:34 AM   #43
Twin_Turbo_S54
My Ride: M3
325-50-15s did not have good traction on street asphalt, I dont mean VHT'ed track, they dont work on regular asphalt.
Put a set of 275-40-17 Hoosiers (A6 or R6) with very little hammering on the Wheel arches. They may fit w/o hammering depending on suspension height.
They grip & grip on regular asphalt. I went 100-200 in 3,61 s with Hoosiers.
If you can find rear wheels of E34 M5 they will work with 275 hoosiers.
Old 12-29-2013, 10:26 AM   #44
GeorgeGG
My Ride: 323
Can u post picture of e34 m5
We have them here but not sure which one are u talking about
And can u post exact model of hoosier?
Old 12-29-2013, 11:06 AM   #45
Twin_Turbo_S54
My Ride: M3
Google throwing star Wheel E34 M5. this is what came on most of the e34 m5s.
hoosier r6 and / or a6 is the exact model.
Old 12-29-2013, 11:09 AM   #46
GeorgeGG
My Ride: 323
Are you talking about this?
Old 12-29-2013, 11:18 AM   #47
Twin_Turbo_S54
My Ride: M3
yes, but you nee the REAR wheels: 9 x 17
these are cheap and work well.
test Hoosier A6 / R6 and you will thank me
Old 12-30-2013, 11:13 AM   #48
dragosid
My Ride: HPF 2.5 M3
Been using A6's (295/30/19) for street and even occasional drags, they worked way better for my power level than R888 (just a piece of advice from my experience)
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 12-30-2013, 11:50 AM   #49
Twin_Turbo_S54
My Ride: M3
Dragos welcome back
Old 12-30-2013, 02:37 PM   #50
GeorgeGG
My Ride: 323
thanks guys for input, i'm looking for wheels and as soon as i find them ill go for Hoosiers
Old 12-30-2013, 05:14 PM   #51
Twin_Turbo_S54
My Ride: M3
Pleasure,
No need to cut/weld Wheel arches.
Other than tires, focus on suspension components.
Which suspension do you have?
Does your ECU offer "boost by gear"? Try to increase boost in 2nd gear up to point where there will be no Wheel spin.
Lets say, with 275 hoosiers in 2nd gear, tires fully warmed up, traction is very good @18 psi. But over 19 psi wheels spin badly.
This means you will have to limit boost to 18 psi @ 2 nd gear.
If your ECU allows boost by gear, you can run more than 18 psi @ 3rd gear...
Old 12-30-2013, 05:25 PM   #52
GeorgeGG
My Ride: 323
Pleasure,
well, ECU has that function and thats the way i have set it up except one thing. i have no traction at all.
when it comes on boost, it feels like somebody is jumping on clutch pedal.
on less power 500ish whp car used to go sideways but now all it does is:
for instance boost comes to 4500rpm, it will hit 7500rpm, then back to 5000, then again rev limiter, again 5000
suspension is pretty stiff rear, i'm not sure about spring rate but springs are more strong than shocks can dump.
when i get wheels and tires i will setup boost levels again, but now there is no point to try even slicks because its dry and cold outside. +2 -2c deg outside
Old 12-30-2013, 06:58 PM   #53
Twin_Turbo_S54
My Ride: M3
do you have LSD?
chek your spring rates, they may tell us about the spin...
hoosiers will stick and stick.
Old 12-30-2013, 11:38 PM   #54
GeorgeGG
My Ride: 323
do you have LSD?
sure man, first thing what i did on the car was LSD conversion
i managed to make custom mount for E36 M3 diff to fit E46 chassis
LSD is modified to 80%
Old 12-31-2013, 03:22 AM   #55
Twin_Turbo_S54
My Ride: M3
Originally Posted by georgegg View Post
:d sure man, first thing what i did on the car was lsd conversion
i managed to make custom mount for e36 m3 diff to fit e46 chassis
lsd is modified to 80%
+ 1
Old 01-01-2014, 03:19 AM   #56
GeorgeGG
My Ride: 323
Happy new year to all of you!
Old 01-10-2014, 06:25 AM   #57
GeorgeGG
My Ride: 323
interesting thing happen since i converted car RHD to LHD, i'm not able to open trunk when ignition is on, or when engine is running, when i shut it off, then it is possible to open trunk.
any suggestion where to look for problem?
i don't think there is something missed in wiring as i cut and solder one by one each wire so nothing should be messed up.
thanks
Old 01-10-2014, 05:02 PM   #58
Twin_Turbo_S54
My Ride: M3
thanks
Too much boost at idle
Old 01-10-2014, 06:58 PM   #59
GeorgeGG
My Ride: 323
i bought 10J alpina r17 discs today
now its time for hoosiers
Old 01-10-2014, 08:59 PM   #60
d'ray18
My Ride: E90 335
Man this is sick, nice setup!
2008 E90 335i
d'ray18 is offline   Reply With Quote
