Old 01-15-2014, 03:56 PM   #61
GeorgeGG
My Ride: 323
so we changed clutch and went to dyne
with same boost we got more power and leaned out at the end due to proper load.
i did not like water temp under heavy load, looks like HG is leaking a bit, so i will upgrade to JE Cut rings or just Oring block. then i will tune and push it for more. (input about this would be highly appreciated)
keep in mind that this is dyno dynamics where 778HP would be 855ish on Dynojet
engine HP graph
GeorgeGG is offline   Reply With Quote
Old 01-15-2014, 05:33 PM   #62
Sedan Hussein
My Ride: e46
So awesome. Make another video man, really enjoyed the one you posted
Sedan Hussein is offline   Reply With Quote
Old 02-22-2014, 03:52 PM   #63
GeorgeGG
My Ride: 323
small update on project
i got 10J Alpina B10 wheels that did not fit in stock Arches with 285 rubber, so i decided to make wide arches myself (first time ever)
other side
Old 02-24-2014, 02:36 AM   #64
GeorgeGG
My Ride: 323
Old 02-24-2014, 08:51 AM   #65
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Engine Timing
Hi,
What engine timing were you using when at 515 whp and pump fuel?
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 02-24-2014, 09:25 AM   #66
GeorgeGG
My Ride: 323
Originally Posted by cosmos328Ci View Post
Hi,
Hello
if i remember correctly it was 10-ish or so but it was completely different setup.
Old 02-24-2014, 10:51 AM   #67
cosmos328Ci
Originally Posted by GeorgeGG View Post
Hello
I ask as I am currently setting up a ESS Twinscrew (15psi) on E85 and a PS2000 ECU.
So I should be able to run more timing safely.
Thanks GeorgeGG.
Old 02-24-2014, 05:16 PM   #68
GeorgeGG
My Ride: 323
Thanks GeorgeGG.
i was running stock internals and very conservative tune.
so you should be fine.
you are welcome
Old 02-25-2014, 11:44 AM   #69
wertyu78
My Ride: '04 ZHP
Glad to see you made it over here George. This is a treat for the others. As always great progress. Looking forward to the next video.
Regards,
Wyatt
wertyu78 is offline   Reply With Quote
Old 03-01-2014, 09:18 PM   #70
GeorgeGG
My Ride: 323
Today's progress
M11 x 1.5 thread for new HSK
Old 03-07-2014, 09:02 AM   #71
wertyu78
My Ride: '04 ZHP
Today's progress
I did this to my block too. **** sucks. Especially the back ones. Longest 1 1/2 hours ever.
Old 03-07-2014, 06:53 PM   #72
GeorgeGG
My Ride: 323
actually it was easy to do, did not took me more than hour to do all of the,
Old 04-16-2014, 02:23 AM   #73
GeorgeGG
My Ride: 323
latest update of project
time to find "budget" solution for a while until i will be able to afford billet or some stronger shafts.
Old 04-16-2014, 09:35 AM   #74
Twin_Turbo_S54
My Ride: M3
Cheapest, strongest solution: E46 M3 rear end. axles, diff, carrer...
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 04-17-2014, 12:42 AM   #75
GeorgeGG
My Ride: 323
thanks for input.
Old 04-18-2014, 04:23 PM   #76
johntrhodes81
My Ride: 2004 325i Wagon
Depending on your tools a late model ford expedition 9.75" IRS diff shafts and cv's would be very strong and cheap.
John
John
DIY BMW Performance Style Extra Air Intake
http://forum.e46fanatics.com/showthr...6523&highlight
johntrhodes81 is offline   Reply With Quote
Old 04-19-2014, 06:12 PM   #77
GeorgeGG
My Ride: 323
John
now transmission broke
3rd gear took vacation
Old 04-20-2014, 12:11 PM   #78
323tom
My Ride: 2 turbo e46's
M3 tranny/rear end and your good to go
323tom is offline   Reply With Quote
Old 04-20-2014, 04:33 PM   #79
GeorgeGG
My Ride: 323
it is very hard to find any of them over here so ill try Getrag 260 now which has tall gear ratios. hope it will work for a while
Old 04-23-2014, 03:55 AM   #80
GeorgeGG
My Ride: 323
does anybody know exact size of e46 m3 input shaft and how many splines does it have?
