The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 12-10-2013, 12:03 PM   #61
m3dragon
My Ride: CSL M3
Send a message via AIM to m3dragon
I have two pairs of splitters. The splitters are super light and seem to be a thin carbon fiber. I will do a write up OE vs VS splitters.
NorCal drive organizer guy
Drive database and photo locations
NorCal CSL build thread - US to CSL Conversion
E46 M3 GTR Street Car - Build Journal
m3dragon is offline   Reply With Quote
Old 12-10-2013, 12:03 PM   #62
m3dragon
My Ride: CSL M3
The final piece of the intake puzzle. Only bummer part with this order is you can only order it with the servo. I am going to see what it might take to get it to work. Nice thing about having a mechanical / electrical engineer as a father =)
Old 12-10-2013, 12:03 PM   #63
m3dragon
My Ride: CSL M3
Today's parts entry was a woohoo and a damit moment. The Recaro Profi XL seats are at the shop along with the install brackets. We installed the drive side seat and epic fail. The seat with the bracket sits taller than the stock seats so my head was holding the roof up. We are looking into either new brackets or having to make custom ones to drop the seat low enough. So I have seats but not in the car.
While at the shop I wanted to get a base dyno before all the big moods. Again another damit moment. We were only able to get to 2nd gear for the dyno test. We were able to at least use all the revs so we got a descent set of numbers. Max power was 317 and the consistent number was 312.4. Not too bad for a starting point.
Old 12-10-2013, 12:03 PM   #64
m3dragon
My Ride: CSL M3
I did something stupid. I made it so I do not have to smog the car anymore but in order to do that I needed to so one last smog test. Well because of a minor oversight on my part, I was thrown into the idle and 2500 idle test group. In years past, I was able to pass the smog text because of yee old friend pictured below. The test was the rolling 20mph and 30mph tests. I passed with race software, 100 cell race cats and all the other intake / engine mods. All you need it the blue and orange can to make any car pass the sniffer =)
Old 12-10-2013, 12:03 PM   #65
m3dragon
My Ride: CSL M3
Finally, after almost a year the replacement cam arrived WOOHOO. Took a long time and I started to think I would never get it but at least it showed up.
Car hit a milestone in October and reached the 59,000-mile mark. Thought I should take a picture of it for history sake.
Old 12-10-2013, 12:03 PM   #66
m3dragon
My Ride: CSL M3
In order to pass smog now I had to make a custom mid-section with new cats. While being rather annoying in the fact I had to do it, it needed to be done so I could register the car. Now I have it if I ever need it again.
I had an O2 go out just before I had a test section made. This was just another hurtle to overcome before I could start all the major upgrades on the car. I have had to drive the car around with a test section in that is bouncing around a little under the car. It is freaking me out a bit that it is going to break something as there none of the brackets are installed. Car hates having to work through 100 cell race cats and two high efficiency cats.
Old 12-10-2013, 12:03 PM   #67
m3dragon
My Ride: CSL M3
In order to fit the Recaro seats I had custom seat brackets made so the seats sat low enough. The reason I need them low is I am 6'5 but I also have the Recaro sliders to adjust seat position. I installed these so the wife and other could drive the car. The goal of choosing Recaros was to drop weight and sit lower so I could wear a race helmet and not have to bend my neck. Sadly I only gained a little height drop in doing these seats but it is still a tad more than the power seats.
Old 12-10-2013, 12:04 PM   #68
m3dragon
My Ride: CSL M3
Next task was to get the car smogged so I could get it registered. I was able to pass with flying colors after doing all the work to make it pass for sure.
Immediately after I passed the smog test I drove straight over to the fabrication shop to have the rear sub frame done as well as have the differential upgraded to 3.91 gears. A note on the Subframe is my car had started to show signs of spider cracks on both sides. The frame had not "completely cracked" but if I had not done the reinforce kit it would have eventually done so.
From what I have found the reason the frames are cracking is fatigue failures. Same issue with aircraft hulls and the pressure changes. The metal eventually begins to fracture with the constant pressurization and un-pressurization.
The fatigue part on a E46 m3 is the loading and unloading going around turns. This constant flexing causes the area to fail. Bad job by BMW not to beef this up as this is a performance car. Stiffer suspension only acerbates the issue faster. As the car has 59000 hard miles on it from back roads driving and being on CA roads I guess I am not surprised to know I would potently have the issue.
Last of the changes at this point in time was the 3.91 gears installed. These were an immediate change I could feel when driving the car home after all the work was done. I took an image of the old 3.61 stock gears for history sake.
Old 12-10-2013, 12:04 PM   #69
m3dragon
My Ride: CSL M3
By December 2012, the day has finally come to take the car to the shop and install all the remaining parts. This was a good day as I was getting tired of all the parts taking up space in my office. Before I loaded all the parts into the car, I went through and took images of each item so I had a record of what was being installed.
Old 12-10-2013, 12:04 PM   #70
m3dragon
My Ride: CSL M3
As the E46 M3 CSL is such a popular car, most BMW enthusiasts have seen the following parts images. As most of these parts would never been seen individually again I wanted to document them and take images of different angles I had never seen. My hope is by sharing these that fellow enthusiasts see things they have never seen before. An example in my case was the flares on the CSL Center console, which in images I had never notices, as the angles never caught the subtleness of the flare.
First group is miscellaneous parts needed for the CSL intake install.
Old 12-10-2013, 12:04 PM   #71
m3dragon
My Ride: CSL M3
Old 12-10-2013, 12:04 PM   #72
m3dragon
My Ride: CSL M3
Old 12-10-2013, 12:04 PM   #73
m3dragon
My Ride: CSL M3
CSL Splitter and SMG expansion tank
Hidden air ducting and air filter
Old 12-10-2013, 12:05 PM   #74
m3dragon
My Ride: CSL M3
CSL Un-Filtered Housing
Old 12-10-2013, 12:05 PM   #75
m3dragon
My Ride: CSL M3
CSL Snorkel Intake
Old 12-10-2013, 12:05 PM   #76
m3dragon
My Ride: CSL M3
CSL Center Console
Old 12-10-2013, 12:05 PM   #77
m3dragon
My Ride: CSL M3
CSL Cams and Followers
Old 12-10-2013, 12:05 PM   #78
m3dragon
My Ride: CSL M3
CSL Main Filtered Housing
Old 12-10-2013, 12:05 PM   #79
m3dragon
My Ride: CSL M3
Old 12-10-2013, 12:06 PM   #80
m3dragon
My Ride: CSL M3
I did want to share one image that proves the fiancée / soon to be wife at this point is allowed to drive the M3. Granted she does not like that much because it has the SMG system. She preferred to drive the 1M as it is a proper manual car. Images was taken and a social event in August at a parking garage in Down town Sacramento.
It is not December 2012 and I loaded all the parts into the M3 and the fiancé's Subaru. This is the last image of the car in its current configuration all be as it is transformed into a US Spec CSL car.
