Sponsored by The Tire Rack
Old 12-11-2013, 08:10 PM   #21
imDerpz
My Ride: 2003 M3, 2002 330xi
Originally Posted by TallSkinnyMatt View Post
I agree with this. I wouldn't run a staggered tire setup with an AWD model. I would recommend a nice square setup. A friend of mine is running 255's on style 44's all around with his sedan. Even though thats exaggerated, you could easily run 245's all around if you wanted!
Cool of you to post your opinion. I was actually just checking out your build thread earlier today. Good stuff man, especially loving your brushed aluminum trim. I'm in the process of Suede wrapping mine.
instagram: BWrighten
imDerpz is offline   Reply With Quote
Old 12-11-2013, 09:48 PM   #22
bee-em-dougle-u
My Ride: 2002 BMW 325i
Hey imDerpz,
Your tires now have a diameter of about 25.1", so a good combo would be 18x8.5 wheels all around, a so-called square setup, and 225/40ZR-18 tires, like the Continental ExtremeContact DWS. Do this and your diameter will stay at 25.1" and your speedometer reading will be unaffected. I'm assuming you want to stay in the UHP all-season category.
Put that tire size into the search engine at the Tire Rack site, and it'll call up a lot of possibilities. For each tire, click on the "specs" tab and look at tire diameter for that size, just to make sure it's at or very close to 25.1"
Good luck!
2002 BMW 325i sedan
Manual gearbox, but of course!
Tasteful mods
128K miles and counting
bee-em-dougle-u is offline   Reply With Quote
Old 12-11-2013, 10:48 PM   #23
imDerpz
Originally Posted by bee-em-dougle-u View Post
Hey imDerpz,
Good luck!
Thank you so much for your help. I'm new to e46 fanatics and its helpful people like yourself that made me want to join.
Old 12-11-2013, 10:58 PM   #24
imDerpz
Sorry one aditional question. What does the zr mean in 40zr?
Old 12-11-2013, 11:23 PM   #25
bee-em-dougle-u
Thanks, I really appreciate that! The board is full of great info and helpful people, but also populated by a few mouth-breathing idiots as well. Luckily, they're easy to spot and avoid.
I had another thought about your wheel/tire setup. If it were my car, I'd live with a little speedometer error and go with a 245/35-18 tire and lower the car just a little. That size would look a little better on the 18x8.5 wheels. The 225/40-18s will be fine, though. Also, if you want sort of a staggered look with a square setup, you could always go with a small spacer (say, 5 mm) and longer wheel bolts on the rear wheels.
The ZR? The Z is the speed rating, and the R stands for radial construction. Zs are good to 150 mph; H is 130 mph, IIRC.
2002 BMW 325i sedan
Tasteful mods
Old 12-11-2013, 11:52 PM   #26
imDerpz
Wheel and Tire Question
How much speedometer error are we talking like 2-3 mph or what?
Old 12-12-2013, 12:02 AM   #27
bee-em-dougle-u
Probably in that range. If the tire's a little smaller in diameter than stock and the speedometer actually reads a little high from the factory, you might end up getting a more accurate speed! (I think I have the logic right on that one!)
2002 BMW 325i sedan
Tasteful mods
Old 12-12-2013, 12:11 AM   #28
YYCZHP
My Ride: 2005 330ci zhp
Honestly dude it's negligible. My dads Tacoma has 33's from the stock 27" tire size. At highways speed 110km/h or 70mph it's off by 8km/h or 5mph.
YYCZHP is offline   Reply With Quote
Old 12-12-2013, 12:31 AM   #29
YYCZHP
If your seriously concerned though check out this thread
http://forums.bimmerforums.com/forum...edometer-error
Old 12-12-2013, 12:46 AM   #30
imDerpz
Yeah I'm not too worried about 2 or
3 off because I'm pretty sure my car is
Already off by about that much. I had heard about the speedo corrector but I think their pretty expensive so we will see its worth it to buy.
Old 12-12-2013, 12:49 AM   #31
YYCZHP
It's $180
Old 12-12-2013, 02:22 PM   #32
bee-em-dougle-u
BTW, imDerpz, there's a thread on lowering the XI models on the XI forum right now. The car (and new wheels) will look a TON better if your drop it a little (and align it afterward). I'm not a fan of extreme lowering, as I like to retain the car's functionality.
2002 BMW 325i sedan
Tasteful mods
Old 12-12-2013, 02:50 PM   #33
dreiundzwanzig
My Ride: 2000 323i
Thanks for that. Why would my rear tore pressure be higher then front though if they are all same size?
Yes they can be different, even if the tires are the same size.
BMW factory specs the rear tire pressure to be slightly higher than the front, as it reduces oversteer. (Mitigating oversteer and a preference towards understeer is preferred by some manufacturers as it can be considered easier to control by the average driver.)
dreiundzwanzig is offline   Reply With Quote
Old 12-12-2013, 03:46 PM   #34
imDerpz
I would think that increasing the tire pressure which decreases surface area would lead to more oversteer due to the less surface area
speedometer, tire, vb3, vmr, wheel
