Old 12-10-2013, 10:33 PM   #1
sdkirkland
My Ride: '05 330i
Headlight Reflector Bowl Burnout DIY
Problem:
Heat output from Xenon bulbs in 2001-2005 3 Series causes the reflector bowl in the Xenon Headlight Assembly to discolor (usually a burnt brown) that diminishes the light output, thus causing the entire headlight assembly to look very dark.
Apparently this is a rather common problem, and several have written other DIY articles for it. As the reflector bowls are not sold individually, a common resolution is to cover the burnt bowl in aluminum foil. I tried this myself and it worked to some degree, but had MUCH more success using an alternate method.
I found a spray paint made by VHT that is built for painting engine blocks, thus it is rated to withstand high temperatures. I purchased a can of their Chrome Plate paint, and simply repainted the reflector bowls. I put on a couple coats one evening on a single headlight, and the difference between the treated and untreated headlight was like night and day. Only tools necessary were those needed to remove the headlight assembly. A philips head screw driver, a T15 and T25 torx screw and a little patience while the paint dried.
Super easy solution, and much more evenly distributed than the aluminum foil route.
*** I also found a greasy residue on the inside of the lens. I simply wiped this off with a paper towel.
I will update in a few weeks to see if the reflective paint maintains its sheen over time.
sdkirkland is offline   Reply With Quote
Old 12-10-2013, 11:30 PM   #2
SoCaLe39
My Ride: 06 M5 & 03 325i
Definitely let us know how it works out. I ended up replacing the bowls with the ones from TRS and glad I did. My oem bowls where so burnt they were cracked.
SoCaLe39 is offline   Reply With Quote
Old 12-10-2013, 11:48 PM   #3
Wildon1
My Ride: 2004 330i
This sounds like a great and affordable solution to the problem. I know mine have dropped off drastically in brightness.
Thanks for the post!
Wildon1 is offline   Reply With Quote
Old 02-09-2014, 07:24 PM   #4
Skidoo03
My Ride: Wants a third pedal.
Any update on how they're holding up?
Skidoo03 is offline   Reply With Quote
Old 04-01-2014, 07:45 AM   #5
Skidoo03
Anything?
Old 07-12-2014, 01:21 AM   #6
Ceric
My Ride: 2005 BMW 325i
Any updates on this? I am considering taking this route.
Ceric is offline   Reply With Quote
Old 07-14-2014, 02:22 PM   #7
DOT.
My Ride: '04 ZHP Sedan
May I suggest this? 100% better than just "painting" the bowl.
http://www.theretrofitsource.com/com...ghts-only.html
DOT. is offline   Reply With Quote
burn out, burned projectors, dim lights, headlights, xenon headlights
