E46 320CI Climate Control Mystery-Help Pls - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 12-11-2013, 12:20 PM   #1
Kazabian
My Ride: E46 BMW 320CI
Exclamation E46 320CI Climate Control Mystery-Help Pls
Hello
I have recently purchased a E46 320CI and am very pleased with it overall, however we noticed the climate control only blew hot air no matter the temperature setting on the climate control panel.
I did some digging and found some answers to my problem. I was told it's either the 1) Climate unit itself ( apparently very unlikely) , 2) the Heater control valve (Probable) or the Final Stage Resistor (Hedgehog? Also probable).
We have had both 2) Heater Control Valve & 3) Final Stage Resistor, replaced with genuine parts and we have had mixed results.
We still get only hot air from the footwell and window vents, however now we can actually get colder air from the middle vents (just above the climate unit) but only when set to cold on the actual vent.
Although better than before we replaced the parts, it still isn't working properly and the only thing left would be the climate unit itself, but this I have been told is unlikely to be causing the issue we have.
Can anyone suggest what we do next?
Kazabian is offline   Reply With Quote
Old 05-19-2014, 03:50 PM   #2
welshmark
My Ride: 318
mines doing the same did you ever sort this issue out
welshmark is offline   Reply With Quote
Old 05-21-2014, 01:46 AM   #3
Shaun1970
My Ride: 318i SE 2000
Send a message via MSN to Shaun1970
Did you try the Water Valve? That is also common heating issue if stuck open.
Shaun1970 is offline   Reply With Quote
Old 06-14-2014, 02:14 PM   #4
Daz 320Ci
My Ride: 320 cI E46
Iv just replaced Final resistor after blower stopped altogether. It solved the issue and was quite an easy fix.
Daz 320Ci is offline   Reply With Quote
