Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 12-11-2013, 04:30 PM   #1
jtower
My Ride: spec e46
323/325/328 allowance
this has been asked multiple times so i'm making a dedicated thread for easy reference.
spec e46 is 330 non-zhp coupes and sedans only. reasoning for this is at http://spece46.com/faq. you're free to argue why this shouldn't be the case but it's not going to change.
people also ask about converting a 323/325/328 to 330 specs so it can race. that's doable but the burden is on you to figure out how to make it happen. everything that is different between the two models must be converted, and no we don't have an exhaustive list of what those things are. if someone wants to pursue this avenue and is willing to make a list of everything that must be done please create a thread on the subject. i'm sure other members of the community will find it helpful or at least interesting.
jtower is offline   Reply With Quote
Old 07-02-2014, 10:55 AM   #2
BMWinLinE6
My Ride: E46 sedan
I'm considering to convert a 325 to specE46 because:
1. Nostalgia - it was my first BMW and I wanted to keep it..
2. Engine - I already swapped a 330 engine in
From my understanding, here's a list of major components that differ between E46 325 and 330:
- Engine
- Transmission, clutch, and shift linkage
- Drive shaft
- Diff
- Brakes
From the list, obviously the engine, diff, and brakes have to be homologated. However, do we need to swap the tranny + drive shaft for 330? The transmission gear ratios are identical. There's no performance gain with original 325 tranny and drive shaft. Looking to swap those parts sounded some money waste, for no obvious benefit either way.
Any ideas?
BMWinLinE6 is offline   Reply With Quote
Old 07-02-2014, 02:49 PM   #3
jtower
My Ride: spec e46
you will need to have the same trans, driveshaft, diff housing, etc as a stock 330. and the rest of the engine management must also be 330 spec, not just the m54b30 itself.
Old 07-02-2014, 02:57 PM   #4
BMWinLinE6
My Ride: E46 sedan
Thanks. I already reflashed DME to 330 spec. But swapping trans, drive shaft, diff housing, etc seemed to be quite a bit of money wasted. There's no performance gain by re-using original 323/325 tranny or driveshaft. If those have to be homologated, I guess people would be discouraged to convert other E46's to spec 330.
Old 11-23-2014, 11:54 AM   #5
autodoctor911
My Ride: 330i
The gear ratios are very close, but not the same, and the getrag(323/325) is lighter. The ballast and transmission are in the same area of the car, so I don't think weight would matter. I would agree there should not be any advantage to the 325 transmission, maybe it could be allowed for any car to help with spares availability as well as to make it easier to do a conversion.
I was wanting to do a conversion on a 328i I have available that already needs an engine. I can get the engine with a harness. I am still checking what else I might need as far as wiring, ABS/DSC, etc. It should already have the 330 transmission and brakes though.
autodoctor911 is offline   Reply With Quote
Old 11-27-2014, 11:06 AM   #6
wanganstyle
My Ride: e36 M3 / E30 GTS1
323/325 is also dirt cheap and plentiful - you might have one sleeping on your driveway as a DD to build up to spec
Virtually identical ratios between the gearboxes but not the same; No real advantage though as overall car weight will be mandated and RHWP/torque monitored like SpecE30 etc. The Getrag G250 gearbox is also a lower rated for torque than the ZF 5 speed in 328/330 so there will be a durability dis-advantage running it; nobody will gain any significant advantage with a gearbox change of ZF320->G250
seems that the final drive / Limited Slip unit is unlimited; so this makes the rear end setup comparison moot between 323/325/328/330
technically if one showed up with a 2500cc engine and just lied that it was a 3000cc it would have 0 advantage and nobody would contest logically; just make less horsepower and have less torque.
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 01-05-2015, 03:43 PM   #7
evanlevine3233
My Ride: Racecars
Hi everyone, I wanted to wrap this thread up with an archived official answer. The class requires that you be racing a 2001-2005 (2006 coupe) E46 330 non-ZHP. Given how cheap these cars are, there is very little merit to anyone wishing to start with a different E46 just because they already happen to own one. That said, we will not be checking VINs on race cars, and if you choose to build a car from a non-330 chassis, that is acceptable, but it's on you to ensure that every part on that car is identical to what would be on an eligible 330 chassis. You cannot run the smaller 323/325 transmission, you will be changing drive shafts, axles, rear arms, motor, trans, brakes, and many other parts. If you go this route it is ultimately your own responsibility to ensure you are building a compliant car. All we can assure you is that VIN itself is not a reason for disqualification.
evanlevine3233 is offline   Reply With Quote
