Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Old 12-12-2013, 02:07 PM   #1
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
FEELER: M54B25xi Supercharged Partout
The Car: 2003 325xi steptronic w/ 120k only 500 or so miles supercharged.
The ASA TM12 supercharger has bad oil seals and will require a rebuild. So far I have received confirmation that both HP motorsports in Chicago and I believe the other was superchargerrebuilds.com can handle the rebuild for about 1500 after all processing. I have spent too much to get and then keep the thing running. I had my modding fun and learned more than I could've imagined building it, but now it's time to spend my money more wisely.
Again, this is currently a feeler. If I sense that there is enough interest, I'll start pulling the motor apart.
What Is Available
Everything m54b25 (I may hold on to the oil pan and oil pickup tube), you think of any other part, just ask
Steptronic Transmission
TCU/EGS
Transfer Case
Modified PS pump bracket for supercharger bracket
Supercharger bracket from Technik Engineering ASA TM12 kit
Various belts that unfortunately I cannot tell you what SC pulleys they should fit
ASA TM12 Supercharger with 10.5 psi pulley in need of rebuild
A pretty ridiculous assortment of charge piping, metal, rubber, and hi temp silicone
Though this is all I can think about right now, I'm sure yall will come up with something else. I'll try to keep up with all the questions in this thread but if it seems like that won't work I'll post my email up. Well....Let's feel it out, shall we? What do you guys want?
drumbum624 is online now   Reply With Quote
