Old 12-17-2013, 05:56 PM   #1
Rigmaster
My Ride: 02 325iT 01 330i
325iT cooling system question- manual trans-specific
I'm doing most of the cooling system on my wife's 2002 325iT 5 speed. I'm replacing most, if not all of the "normal" stuff (Rad, hoses, Water pump, etc).
The only thing I'm not replacing that most people probably would is the expansion tank- since it's only about 1 year old (I replaced just this tank when it blew out).
I'm having a problem getting the expansion tank to "seat" on the small connector on the expansion tank "bracket" that attaches to the driver's side of the radiator. I bought a new BMW bracket along with the other parts mentioned above.
I've searched and I've asked some friends about this, but no one has a definitive answer. The large port on the bracket is seating just fine (it's the one with the locking clip, the small port has no clip). I'm seriously considering buying a new Expansion tank, but wanted to see if anyone had any experience/advice about this issue first.
Thanks!
EDIT: To clarify, the "bracket" I'm talking about is 17111436250 or #1 in this pic:
Rigmaster is offline   Reply With Quote
Old 12-17-2013, 10:53 PM   #2
Rigmaster
Well, after looking at this thread (http://forum.e46fanatics.com/showthread.php?t=906997) I think I'm gonna order some o-rings for the bottom of the expansion tank and see if that does the trick.
I'll let you know how it turns out, but still interested in hearing any other theories.
Old 12-17-2013, 11:49 PM   #3
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
Lubrication will help immensely, silicon o-ring grease is best, in a pinch you could use a small amount of vaseline. Should snap together like a lego with the grease. A dry o-ring will grab and twist.
ddaniel1 is offline   Reply With Quote
