General Off-Topic
Old 12-16-2013, 05:13 PM   #21
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 12-17-2013, 11:18 AM   #22
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
http://www.theverge.com/2013/12/16/5...y-on-the-block
Old 12-17-2013, 04:12 PM   #23
WerksM3
My Ride: 2002 M3
What is a good Hashrate? I float between 1800-2400 hashes per second on a solo dig.
How long does this take?
I am a complete crypto noob
WerksM3 is offline   Reply With Quote
Old 12-17-2013, 06:53 PM   #24
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
edit: I thought you meant 1800Khashes.
I'm ~60khashes/second on one machine and ~24khashes/second on another, both CPU mining.
Old 12-17-2013, 07:15 PM   #25
WerksM3
My Ride: 2002 M3
Running this on an old mac I have not used in 5 years... figured I'd just run it 24/7 and see what happens. I cant find a pool that works. Tried dogepool.net and fast-pool.com neither worked for me.
Edit: dogepool.net
Old 12-17-2013, 07:51 PM   #26
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Re: Bitcoin? NO TY... im about that DOGECOIN
Edit: dogepool.net
I'm on cryptovalley and coin something, I can't remember the full name. Are you sure you're running the script correctly?
Old 12-17-2013, 07:58 PM   #27
WerksM3
My Ride: 2002 M3
Yeah, doing everything as stated in the "getting started" guides. My comp might be too old and not supported by miners like cgminer, etc.
Old 12-17-2013, 08:09 PM   #28
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
What error are you getting?
Old 12-17-2013, 08:17 PM   #29
WerksM3
My Ride: 2002 M3
Just says cannot connect to pool and then instantly closes. Just tried cpuminer/minerd and got same errors.
Old 12-18-2013, 08:52 AM   #30
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
It sounds like you're not entering your username/worker/password correctly.
http://motherboard.vice.com/blog/dog...cal-conclusion
http://investorplace.com/2013/12/sic.../#.UrGn3eI1nAk
http://www.vyralize.com/6020/goodbye...-dogecoin-wow/
Old 12-18-2013, 02:54 PM   #31
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
how the hell do i mine this with a mac? i used cgminer and it started up but did nothing. i want to mine with CPU
Old 12-18-2013, 03:24 PM   #32
WerksM3
My Ride: 2002 M3
cgminer runs in terminal so you kind of have to know what you are doing. I apparently don't know sh*t which is why I couldn't get it to work right.
Old 12-18-2013, 03:24 PM   #33
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
you'll need the minerd process, not cgminer. Or use Asteroid, follow the guide in the OP
Old 12-18-2013, 03:26 PM   #34
WerksM3
My Ride: 2002 M3
Might have figured out my issues. I had $ symbol in my password and it was throwing off the coding in terminal...
Old 12-18-2013, 04:55 PM   #35
peytonracer4
:D
My Ride: '00 328i
Asteroid can CPU mine? I've been using terminal to mine qrk. But I don't know how to mine anything else. I figured I could just plug in the values for doge but it didn't work
Old 12-18-2013, 09:18 PM   #36
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I don't know, I was just going on what the guide says for Mac. Just for sh!ts and giggles I pulled my OC back to the stock 3.4Ghz and I'm 20khash/s lower
Old 12-19-2013, 06:25 PM   #37
peytonracer4
:D
My Ride: '00 328i
how long does it normally take to solve a block? my miner is hashing away but i haven't solved a block yet so my activity is not showing up on my pool site
Old 12-22-2013, 09:57 AM   #38
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
http://www.stuffcoins.com/doge/
Old 12-22-2013, 09:57 AM   #39
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Are you part of the pool or doing a solo mine? I have no idea how big a block is.
Old 12-22-2013, 02:20 PM   #40
Shaban
My Ride: 2005 CBR600
It's no longer profitable to mine Dogecoin; http://www.coinwarz.com/
edit: well it is, but there are more profitable coins.
If you do want to keep mining and being profitable, you can join pools like www.middlecoin.com or www.hashco.ws, they automatically mine the most profitable coin and payout in Bitcoin.
- Alex
Shaban is offline   Reply With Quote
