Old 12-08-2013, 07:41 PM   #1
bimmerchick2
My Ride: 02 320i
HELP!!! Massive amounts of white smoke & milky fluid in tailpipe.
So I went outside today to start my e46 early since it's -10 outside here. Started fine and ran fine, went inside and when I came back out (5-10min later) the car had stalled out and there was massive amounts of white smoke.....
Pulled it I to the garage to look at a few things...opened the oil cap & there was yellow gunk on the cap, smelt slightly sweet (coolant?), went to the back of the car & looked in the tail pipe..... White thick milky fluid was seen in the tail pipe. (Picture below). Spark plugs had a small amount of fuel, looked used(replaced 4 months ago), nothing seemed to be wrong there. Tested the ccv with running the car without the oil
Cap, car started idling funny which is suppose to happen? That's as far as we got tonight...
Little more history.... Car has been burning oil since we did a motor swap in August, approx 1 litre between oil changes, engine codes will sometimes pop up, I always read them right away they have said misfire in cylinder 5. Turn the car off without clearing the code and the code goes away for weeks with no issues. Car doesn't seem to have a lot of power? Coolants never been low, regular oil changes with proper Castrol
Synthetic oil, air filter is clear, MAF is clean.
So I'm thinking the head gasket??? Can anyone else give me some insight on what this may be? Thank you.Click image for larger version
bimmerchick2 is offline   Reply With Quote
Old 12-08-2013, 08:19 PM   #2
JDez
My Ride: 2001 330i
Re: HELP!!! Massive amounts of white smoke & milky fluid in tailpipe.
The yellow mayo is fairly common during winter months. Check your expansion tank for milkiness. If it is a head gasket you should have milky stuff in there and on your dipstick. Best of luck.
JDez is offline   Reply With Quote
Old 12-15-2013, 03:30 PM   #3
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
So I'm thinking the head gasket??? Can anyone else give me some insight on what this may be? Thank you.Attachment 537743
Head gasket is most likely. Not sure if u have anti frieze in ur radiator. If not crackled block or head.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 12-15-2013, 04:16 PM   #4
jfp2999
My Ride: 325ci
maybe your burning oil unhook hose that goes to the dipstick maybe sucking up oil from this.
jfp2999 is offline   Reply With Quote
Old 12-15-2013, 04:27 PM   #5
bimmerchick2
My Ride: 02 320i
Wasn't the head gasket, it was the ccv valve, replaced it and the egr system, cars running great. Ps.... Car never over heated
Old 12-17-2013, 06:37 PM   #6
genius328i
My Ride: 328i
Blown head gasket bro
genius328i is offline   Reply With Quote
Old 12-17-2013, 08:12 PM   #7
Loaded325i
My Ride: bmw 325i
You dont pay attention do you
A mechanical hobbyist and car enthusiast
1971 Datsun 240z Devil Z red
1999 740il Titanium Silver
2004 BMW 325i CW,PP and Sports Package
1996 toyota avalon-263,000-Sold
2003 Lexus Is300-Sold
2000 Acura TL-Sold
2000 Accord 5 speed-Sold
Loaded325i is offline   Reply With Quote
Old 12-17-2013, 09:14 PM   #8
genius328i
My Ride: 328i
Surely didn't see that last post
Old 12-17-2013, 09:37 PM   #9
wildirish317
My Ride: 2004 325Ci vert
Might want to re-think your choice of usernames too.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 12-17-2013, 09:50 PM   #10
genius328i
My Ride: 328i
And why would I do something like that
Sent from my HTC_Amaze_4G using BimmerApp mobile app
Old 12-17-2013, 09:56 PM   #11
wildirish317
You were responding to bimmerchick2. You got to give up the genius on that one, bro!
Old 12-17-2013, 10:38 PM   #12
jfp2999
My Ride: 325ci
I was right yeah yeah its a genius idea other than this sucking oil from dipstick problem but other than that genius I mean I challenge you to diy a better ccv. I tried and blew another motor by just running a vent hose to the ground and my dummy but didn't remember
It sucks too so it sucked up enough water over a two three week period leaked into a cylinder and boom water doesn't compress hole in the block again h2o is your enemy with cars
Old 12-17-2013, 11:01 PM   #13
genius328i
My Ride: 328i
Ok I was at work and should have been paying more attention. I think I can get a free pass on this one don't you agree op
Old 12-18-2013, 02:17 AM   #14
VishTheFish
My Ride: Ex M54B30 ZHP
H2O helps keep the car cool, so its not all bad
Then again, if you're running a ccv hose to ground level......
VishTheFish is offline   Reply With Quote
