Should I replace one Cv Joint ( Axle Shaft) or Both? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-16-2013, 07:08 PM   #1
phoopsta
My Ride: 02 330xi 3-pedal
I have a 02 330XI and for my christmas gift my brother-in-law in replacing my leaking axle shaft with a hole on the front left with a new one! I thought it is great because it would save me a good amount of $$.
I was kinda worried about the part purchased tho, It is coming from Napa Auto Parts.
Anyways hes done tons of cars DIYs and he knows a little bit about bmws.
Looking at videos and forums I think its a task we can conquer.
What I am worried about is if I get a aftermarket shaft for the front left when the front right OEM was perfectly ok, will they fight eachother? Like maybe vibration or weird wobble or should I not experience any difference? Thanks!
2002 BMW 330xi 135k miles.
phoopsta is offline   Reply With Quote
Old 12-16-2013, 07:20 PM   #2
jeepo23
My Ride: 2008 X3, 6 Speed
Well I replaced my front left in my 02 330xi about 2 years ago with a shaft from Carquest (same as Napa really..) and luckily I kept my OEM shaft and picked up a boot repair kit which I plan now to rebuild and install back as I believe that the shaft from Carquest is causing some shaking/wobbles..
If he's doing the repair and your shaft isn't clicking yet.. buy the boot repair kit ~$40 since he has to remove your OEM shaft anyways and just rebuild it and put it back in place. This will save you some money by not having to buy a new shaft unless you want to go OEM.. $$$.
And I don't think the shafts are interchangeable between sides.. their all side specific.
jeepo23 is offline   Reply With Quote
Old 12-16-2013, 07:30 PM   #3
autoAER
My Ride: 2005 325i 5MT
Definitely replace both (you will regret it later if you dont), and definitely get OEM or OEM spec BMW parts
Past: 2006 330i, 2006 325i 6MT, 2003 325xi
Current: 2008 335i E90 N54, 2005 325i 5MT
autoAER is offline   Reply With Quote
Old 12-16-2013, 07:37 PM   #4
phoopsta
Well it is definatly not the cheapest crap but also its not OEM. So I beleive its OEM spec.
I am deciding to do one side because the other side looks recently replaced. Its in fantastic shape. My drivers side is trashed.
^ for the boot repair. I had thought about it, but it was a suprise so he already purchased the part
Old 12-16-2013, 07:38 PM   #5
jeepo23
What axle shaft are you putting in and how much is it?
Old 12-16-2013, 07:43 PM   #6
autoAER
Up to you, but I was also in a similar situation and judging by the removed part, it was in much worse shape than i thought. It's better to replace both and know that you did than replacing one side and going off of sheer guessing on the other side.
Old 12-16-2013, 07:48 PM   #7
phoopsta
I think he said something around $250. I looked up the OEM and they are over $500!!! It would be the Front Driver side.
The cheapest aftermarket I looked up was $107. off of Bavarian Auto
Old 12-16-2013, 07:51 PM   #8
phoopsta
I had them all inspected at a dealership as well has 2 other auto shops ( full car inspections, I like to have different point of views). Thats how I figured that I needed a new one ( as well as looking at it while car was in air) I had lots of other parts looked at but thats a different subject.
I can also tell by just looking at them. The front left isnt torn or anything, just a huge hole causeing a leak.
Old 12-16-2013, 07:53 PM   #9
autoAER
Ah, that you didn't mention. I retract my previous statement
Old 12-16-2013, 08:01 PM   #10
phoopsta
My fault bro haha I am new to the forum.
I got this car REALLY cheap so dont be to suprised below lol
Other parts that need to be replaced soon:
Post o2 sensors.
Fuel Filter
Fuel filter cover
Front left axle shaft ( in progress)
Flex disc ( Guido or whatever u call it)
Front left rim
Oil level Sender
Front and back differential oil change
Radiator Flush. ( PREVIOUS OWNER HAD PRESTONE IN IT> CAN U BELEIVE IT)
What I have done so far:
MAF sensor clean
Headlamp install
Exhaust butterfly valve removal.
Clutch....($1,800... )
Oil changed, twice lol( apparently accidentally had a shop do it)
Complete engine cleaned ( my engine sparkles)
Old 12-16-2013, 11:17 PM   #11
autoAER
Post o2 sensors.
Fuel Filter
Fuel filter cover
Front left rim
Oil level Sender
MAF sensor clean
Headlamp install
off the top of my head, definitely double check your cooling system, VANOS,and ICV. I can't stress enough how much preventative maintenance is important on these cars. Trust me man, I spent 3 grand fixing everything up when i got the car 2 years ago. Before owning it, I had no idea what the hell was going on inside. Now, i can say I've replaced enough parts to know exactly whats going on with the car. be very careful, things add up quick with these cars
most of all, enjoy the bimmer
Old 12-17-2013, 06:31 AM   #12
phoopsta
Yeah I definatly want to do a coolant flush and put in BMW coolant in and get rid of that yucky green stuff. for the ICV, I could definatly check it and clean it. for my vanos? well im not experiancing any leaks around there nor any engine problems, yet. So That isnt number 1 priority haha.
Old 12-17-2013, 09:08 AM   #13
SamDoe1
My Ride: 4cyl of fury
If one is bad and the other is not, replace just the one.
Why are you replacing the fuel filter cover?
Are you sure you need to replace the flex disc, post cat O2, and front rim or are you just guessing?
Why aren't you replacing the pre-cat O2 sensors?
Don't replace just the coolant, replace the thermostat, water pump, explosion tank, and hoses while you're in there.
Old 12-17-2013, 10:47 AM   #14
phoopsta
[ QUoute]1;15894266]If one is bad and the other is not, replace just the one.
Don't replace just the coolant, replace the thermostat, water pump, explosion tank, and hoses while you're in there.[/QUOTE]
I am replacing the fuel filter cover due to it being super rusted, I may try to do some abatement to see how much rust can be taken off first.
Yes flex disc is soon needed to be changed, the rubber is all torqued ... tho I could probably wait awhile before I do that.
Post cat o2 is because im getting heateng o2 sensor circut fail codes and other codes that lead to bad o2 sensors. Precat are ok as they were replaced before purchase.
Front rim has crack next to tire that creates an air leak. I will pay you money if u can find me that rim style!
Coolant system seems fine,not to worried yet, this car isnt as bad as im saying it is. Lol explosion tank
Old 12-17-2013, 10:59 AM   #15
SamDoe1
I am replacing the fuel filter cover due to it being super rusted, I may try to do some abatement to see how much rust can be taken off first. Don't bother, you're wasting your time and money on this.
Post cat o2 is because im getting heateng o2 sensor circut fail codes and other codes that lead to bad o2 sensors. Precat are ok as they were replaced before purchase. Are you sure they are for the post cat O2 sensors and are they both of them?
Front rim has crack next to tire that creates an air leak. I will pay you money if u can find me that rim style! What style, the ones in your picture?
Coolant system seems fine,not to worried yet, this car isnt as bad as im saying it is. Famous last words
See above.
Old 12-17-2013, 12:27 PM   #16
Busy
Location: Guys, stop spraying your wheels black; it looks awful.
My Ride: 01 330xi
NEW axles from NAPA come with a lifetime warranty and cost a fraction of OEM axles, so use those.
Replacing both sides is a preventative measure and if $$ and time allow, by all means do it.
Busy is offline   Reply With Quote
Old 12-17-2013, 02:54 PM   #17
phoopsta
Cool
Originally Posted by SamDoe1 View Post
See above.
Fuel filter cover : I dont mind abatement and its free
O2 sensors: cause the reader told me the bank and the sensor??
Rim: Yeah that style
Coolant: you might be right. Im not a car noob tho... why u asking me this stuff as if I am a noob with cars?
Old 12-17-2013, 03:39 PM   #18
autoAER
nothing wrong with being a noob. hell, I'm still a noob and I've owned my E46 for long enough to know better.
Better take SamDoe1's advice
Old 12-17-2013, 03:50 PM   #19
SamDoe1
My apologies, most people who just start out on this forum are total n00bs who couldn't tell you the difference between an O2 sensor and a MAF sensor.
I've been around the block and back with this car so I'm just throwing out my opinions and advice.
Old 12-17-2013, 03:54 PM   #20
SamDoe1
Also, I believe these are pretty close to the wheels you're looking for without having better pictures than the one you posted:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
