E46 Xi Forum
Old 12-19-2013, 12:05 AM   #1
volcom772
My Ride: e36 325is+e92 M3
possible opg or rms leak
ok i cleaned up the underside and degreased everything. now this is the leak im left with. It really likes to drip when parked with engine down hill, I mean like a silver dollar puddle in about 20 minutes. also in the past few months I have replaced ofhg and vanos oil pipe. also had a major vacum leak from vcg because the po or po's mechanic forgot to put one of the nuts back on the cover so maybe now the system has the proper pressure it is forcing the oil out from the leak more?????? I was thinking ccv could be busted and leaking but it doesnt feel wet and also i looked at the dipstick oring and no leak there either. I suppose i could drop the tranny and know for sure where the leak is coming from but just wanted to see what everyone here thinks.
this is a 325xi touring manual with 215k on it so i guess it could be anything.
3rd pic this is the center where the transmission meets engine it comes from the Left side of the car and pools on one of the 2 oil pan screws on the rear. it is dry infront of this area the only other part that looks a little wet is further up on the oil pan but on the RHS which is slanted down.
ID:	539309   Click image for larger version
ID:	539310   Click image for larger version
volcom772 is offline   Reply With Quote
Old 12-19-2013, 09:16 AM   #2
sfcjetjr
My Ride: 2002 BMW 325i
Mine looked the same so did OFH seal and oil pan gasket. Thankfully was not rear main. But those too cleared up all oil leaks underneath at the exact same spots.
sfcjetjr is offline   Reply With Quote
Old 12-19-2013, 12:22 PM   #3
JDUTHIE
My Ride: 2003 325xi
Pan gasket... Have fun
JDUTHIE is offline   Reply With Quote
Old 12-19-2013, 08:57 PM   #4
volcom772
ya i think i would rather a rear main.
If i have to yank all this stuff im thinking of buying a lower mile m54b30 and doing a swap. anybody have experiance with that, i think i can just flash my dme with ncsexpert but im worries about smoging it after if the dme has a different vin number or somehting.
Old 12-20-2013, 10:23 AM   #5
SamDoe1
My Ride: 4cyl of fury
Tighten the pan bolts before you try and change out the gasket. Sometimes they loosen up and can just use a little tightening to snug them back up. Make sure you use a torque wrench when you do this and be careful to not strip anything out.
Old 12-20-2013, 11:28 AM   #6
JDUTHIE
My Ride: 2003 325xi
Smog will be fine... The techs there arent that bright lol. It would be cheaper to just to the gasket, but the ammount of work thats involved, if you can afford the b30 then might aswell while your in there..
Old 12-21-2013, 12:18 AM   #7
volcom772
got under the car with an in/lb torque wrench tightened the bolts up got to the last few and wouldnt you know it but one was already stripped by the PO or PO mechanic. luckily (i guess) its on the passenger side just rear of where the axel goes through the pan. so should i just timecert the hole and put a fresh bolt in? could i do this through the oil pan or should i remove everything re tap and replace?? this is kind of starting to turn into worst case scenario for me.
anybody out there ever tap one of these holes with the motor still in the car?? advice would be appreciated
