Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 12-17-2013, 01:07 AM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
SpecE46: Harmonic Time Bomb Disaster
First I want to say I love the idea of this SpecE46 class, and big thanks to Jason Tower & James Clay for getting this going.
As a racer (SCCA) I have a few different concerns on a few things, but one major concern in particular; Harmonic Oil Pump Failure. I believe the first year or two will be a Very Expensive learning curve for both the racers & promoters in this new class.
From personal experience I can tell you that the aluminum block M54B30 is NOT well suited to long duration RPM pulls down a straight away in stock (SpecE46) trim as the current rule book is written. There is a well known & documented high RPM issue concerning Harmonics & Oil Pump Failure in the M54B30, that mostly happens in the 6700 to 6800 RPM range. This Harmonic OPF is greatly exacerbated by three (3) different issues.
1) A light weight flywheel & clutch, instead of the stock 38.5lbs (heavy) Dual mass flywheel & clutch. (the stock dual mass flywheel acts as an Extra Damper on the back of the motor)
2) Any ECU "tune" that extends RPM past the stock 6500 RPM limit. Namely a tune that goes to 6800 to 7200 RPM.
3) Any race track with a long straight away that allows the motor to sustain the dangerous 6700 to 6800 RPM Harmonic failure range. Typically multiple 8 to 12 second (or more) pulls in any gear, (namely 4th) that allows the motor to "stay" in this dangerous 6700-6800 harmonic window.
As the rulebook is currently written, the SpecE46 race community will probably see many Harmonically caused OPF engine failures.
SpecE46:
"Specifications & Rules"
Engine: Stock M54 motor, "flywheel and clutch may be upgraded". This rule should be changed to: Stock flywheel & clutch.
"A custom ECU tune may be specified in order to ensure compliance and maximize power/reliability." This rule should be changed to either: 1) A stock ECU must be used with NO tuning software.
Or 2) A custom "Tune" may be used, but with a Maximum 6500 RPM limit.
I would Strongly suggest a change to the rulebook allowing the use of either or both:
1) An upgraded oil pump, in the stock location.
2) The use of an upgraded engine balancer.
The money that would've been spent on a LTW Flywheel & Clutch, and the money that would've been spent on the ECU "Tune" would be much better spent on the upgraded Oil Pump & Engine Balancer. This change in thinking will not only provide the SpecE46 racer with a more sustainable motor, but will provide a more level playing field for every entrant. That of course is because the "guy" with the biggest bank account will be able to afford a custom Ultra LTW Flywheel & Clutch, not to mention the use of a "Super Tuner" that can extract every last ounce power out of his motor,.....at any cost.
Some things for SpecE46 to consider.......
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 12-17-2013, 10:59 AM   #2
jtower
My Ride: spec e46
appreciate the feedback rob. let me address your two concerns as best i can:
1. there are several reasons we may utilize a spec ecu tune (ensure compliance, fix various electronic issues, make more power, richen the mixture for safety, etc) but raising the rev limit is not one of them. engine longevity is absolutely something we're trying to preserve so a 6500 rpm limiter (6700 tops) is all this class will see.
2. we've gone back and forth on the flywheel/clutch multiple times, right now we've permitted light flywheel/clutch to make the cars as fun to drive as possible. we're expecting that the conservative rev limit will keep the motors in their safe range, and we are allowing oil pump modifications (and harmonic balancer replacement may be permitted in the future as well). plus the light flywheel is optional, not required. the performance gain is minimal, it's mostly about making rev matching easier. with a 3.46 diff i don't think these cars will spend any significant time banging against the limiter in 5th.
finally, i want to point out that Evan Levine has been part of the Spec E46 team from day one, in fact it was his suggestion to use the E46 platform (my original proposal was to use the E36 M3). he's in the final stages of buying a new house and hasn't been quite as active on the public side of things but he's as much a driving force behind se46 as james or myself.
jtower is offline   Reply With Quote
Old 12-17-2013, 12:05 PM   #3
JamesClay
My Ride: Any BMW with 4wheels
Thanks for the post and concerns - certainly well-presented and well-received. A few points (repeating Jason in some cases):
  • The software will have a conservative rev limit to prevent exactly the problem you mention. The rules have a big nod to enforcable compliance. We could say no software, but that is not something you can police and you just widen the gap from those that follow the rules (I know - all of us) and those that still have the money for custom tuning. We will improve the performance of the car to make people spending the money for it happy that they are getting something, but the reason this made the cut was purely for the compliance aspect.
  • The V2 rules do allow oil pump modification - agreed on this point.
  • Agree on the harmonic range and track issues - have experienced it a lot before. The stock piece is great, but the goal was light (you can drop 25# here) and fun (a revvy motor is fun - as is a clutch that doesn't break). I was on the side of keeping the stock flywheel and allowing a performance clutch (that is about $600). We discussed normal lightweight flywheels and I agree that is not appropriate or not what I would use because of the clutch demands and loss of damping (which also cushions the clutch). Then I worked with a company to come up with a true race clutch, aluminum solid basket, 7.25", 0.236" discs (5 year typical service life), steel flywheel but light and low MOI, and all for about $1250 - same price as the aluminum flywheel/stock-style clutch on the table. When you get that end of the engine light things get better that they are when they are a little lighter than stock (minus the DM). This should be a solid, cost-effective solution.
  • The balancer is on the table, but we think we can avoid the expense in the rules by containing the issue with the above steps. I am working hard on our car and it will be the test dummy. The goal is to have a solid, robust driveline and if we have issues after some hard running, we will take this step. I think everyone hates adding to the build price by adding it now, but I suspect that is still debatable.
At the end, Jason and Evan are making the decisions and I helping to provide answers and options, so this is one for them to expand on or discuss as needed.
James Clay
Race Proven Performance
www.bimmerworld.com
www.bimmerworldracing.com
Bimmer World
JamesClay is offline   Reply With Quote
Old 12-17-2013, 12:54 PM   #4
evanlevine3233
My Ride: Racecars
Agreed - Excellent feedback thanks. I hope the considerations we've made will address this, and I think we all support a low enough rev-limit to avoid problems. That extra couple hundred RPM really don't make the cars faster enough to justify it in a Spec class, especially if not having them makes the cars more reliable.
The balancer is really the only remaining piece, and it's not off the table as James mentioned. But my hope is that we get a few test cars running, built by people willing to experiment a bit, and see if that's truly necessary. Prices on these things have crept up and anywhere we can help keep that down would be preferable at this point. Ultimately though we won't sacrifice reliability if it comes to that.
evanlevine3233 is offline   Reply With Quote
Old 12-17-2013, 03:26 PM   #5
Rob43
Rob43's Avatar
I'm very happy with these excellent responses, they show that all of you are on top of these issues & are open minded to addressing this "Harmonic" problem.
I really like the idea of the LTW flyweel & clutch James Clay has come up with, it will make the SpecE46 car more fun to drive and add definite life to the clutch package simply because it won't wear out quickly.
I also really like the Idea of "Spec" software that everyone would use. I do believe that a maximum of 6500 RPM should be utilized, this 6500 RPM limit really will help with motor longevity, and will offset any negative effects of using a LTW flywheel & clutch.
On to the Damper; As an owner of a highly modified N/A 2003 330Ci that currently has a ATI Super Damper mounted on it, all I tell you is there is a VAST difference in the amount of harmonic (Greatly Reduced) vibration in the 6700 to 6800 RPM range. Now when I run my Bimmer at the track, or down some empty highway in 4th gear between 6600 to 7000 RPM the "Buzz" or Harmonic vibration is virtually gone. My thought on something like the ATI Super Damper is this: BimmerWorld would purchase a large supply (10-20) of these from ATI at a discounted rate, and then pass the savings on to the SpecE46 racers. I am a FIRM believer that this one piece will add great longevity to any M54B30 race motor.
The oil pump: There's a reason why BMW sells a $3000 dollar oil pump upgrade kit for a racing M54B30, that's to solve the issue of the aluminum block vibrating like a tuning fork at 6700 to 6800 RPM and in some form or another destroying the stock oil pump. I certainly don't think anyone should spend 3K to help solve this issue, but I do believe the SpecE46 rulebook should be written to allow either:
1) A stock oil pump with a welded or wire tied oil pump nut.
2) A stock oil pump with a VAC Motorsports oil pump kit installed. (about $200)
3) A "Super" oil pump like the one I run. Cost is about $750, its a TC Kline/ Greg Smith - vaio76109 pump. There are several threads on this pump, here's a link
http://forum.e46fanatics.com/showpos...56&postcount=1 lots of pictures thanks to Adam (PEI330Ci).
Again, Good luck,
Rob
PS, Jason I responded to your PM.
Old 12-17-2013, 11:26 PM   #6
Rob43
Rob43's Avatar
Two more very inexpensive motor saving/longevity aids should be added to the list of helping a M54B30 race motor stay together.
1) S54 Timing Chain Tensioner.
This M3 timing chain tensioner is a Direct fit and will "firm up" the timing chain from thrashing around as much as it currently does with the stock M54 part. The motor will feel smoother at high RPM with this tensioner.
2) INA (Over-Running) Alternator Clutch Pulley.
Again, this will help smooth out the motor. With the stock M54 solid Alt. pulley, the ribbed belt "whips" back & forth under deceleration from high RPM causing a lot of unneeded vibration.
Both of these parts are Super easy to install, and are cheap insurance at holding a M54B30 motor together under the extreme environment of racing.
Good luck,
Rob
Old 12-18-2013, 05:55 AM   #7
rsrdan
My Ride: 1991 Bmw 2001 325ci
Does the m54b25 suffer from harmonic balance issues?? I plan on tracking my 2001 325ci in nasa time trial 2014.thx
2001 325CI
1991 325ix
rsrdan is offline   Reply With Quote
Old 12-19-2013, 12:15 AM   #8
TerraPhantm
My Ride: M3 & ZHP
Worth noting 2003 M54s have a different harmonic balancer (albeit also a smaller rib count). From what I understand, these don't fail as frequently. Maybe best to just have everyone run the 2003+ damper?
Old 12-29-2013, 08:17 PM   #9
Harry330
My Ride: 330Ci
Is this harmonic issue really true?
Should i be worried if i supercharge or chip my 330 for street driving.
One Of Many Goals.
Harry330 is online now   Reply With Quote
Old 11-28-2014, 03:58 PM   #10
KCPBMW
My Ride: 325Xi W/Rob43 Susp.
Whats the Official ruling on the use of the ATI damper?
Is it legal or is it illegal?
KCPBMW is offline   Reply With Quote
Old 12-01-2014, 08:07 PM   #11
jtower
My Ride: spec e46
not legal
Old 12-13-2014, 10:02 AM   #12
KCPBMW
Originally Posted by jtower View Post
not legal
Why ????
my own *personal* definition is:
performance advantage = lower lap times
competitive advantage = enhanced durability/reliability
in spec e46 any modification that provides a competitive advantage without a performance advantage is fine, and will generally be permitted provided it has no other negative impact. the current rules permit many parts to be replaced for this very reason. in other series like chumpcar (which i am also intimately familiar with) where races are much longer and durability plays a larger role, such a modification may not be allowed or will affect your valuation. however, a modification that increases both performance and competitiveness is far less certain and will be rigorously scrutinized by the rules committee.
I find it absurd that the ATI damper in deemed illegal in se46. There is NO performance advantage to this device, it just keeps motors together.
Old 12-13-2014, 11:43 AM   #13
jtower
My Ride: spec e46
multiple cars have raced in long endurance races this year (from memory there were a few at a six hour in the PNW, 4-5 at the portland eight hour, three cars at the 25hr of thunderhill) plus several weekends of racing on the east coast with 3-4 cars each. to my knowledge there has not been a single engine failure attributable to the harmonic balancer, therefore no reason to change the rules.
Old 11-27-2016, 07:26 PM   #14
blance18
My Ride: e46 330Ci
Good luck,
Rob
Hey Rob,
Can you elaborate on the S54 timing chain tensioner a little more? I'm planning to follow your advice here and get both but haven't run across any threads on this. I'm planning on tracking my car next season after an M3 LSD swap. The only thing worse than a subframe ripping out is a motor exploding...
Is this the one you are talking about***********:
https://www.turnermotorsport.com/p-3...or-s54-engine/
blance18 is offline   Reply With Quote
Old 11-27-2016, 08:12 PM   #15
Rob43
Rob43's Avatar
Originally Posted by blance18 View Post
Hey Rob,
Yep, that's it. Here's the best price I see: https://www.ecstuning.com/b-genuine-...r/11317838675/
In order of importance:
1) ATI Damper, VAC is the Only place you can buy them from, wait for vac to have a 10% off sale so you can save ~$80 dollars.
2) GSR Super Oil Pump (1 & 2 together give the best overall protection)
2a) Wire tie or weld the OE oil pump nut on.
3) S54 M3 Timing Chain Tensioner
What are you doing for your suspension ? I build (Consult & end up saving you $$) race suspension setups for the E46 chassis.
Rob43
PS, Get your used E46 M3 2.10 LSD diff Re-built, 99.97% says it's currently worn out for tracking purposes & will let you down when you need it the most.
Old 11-29-2016, 11:27 AM   #16
BigBill
My Ride: 01 330ci
Rob43. Great advice but the ATI is not SpecE46 legal.
BigBill is offline   Reply With Quote
Old 11-29-2016, 02:50 PM   #17
Rob43
Rob43's Avatar
Yes Bill, & it's purely because of POLITICS; let me explain...
Years back when ATI Dampers of Baltimore MD built the original 10 units that were offered in the E46Fanatics Group Buy, they were contact by VAC Motorsports because VAC realized the enormous potential in what ATI had developed. VAC Motorsports quickly locked in an exclusive lifetime deal with ATI allowing only VAC to sell any future ATI Super Dampers for BMW applications. Since companies like: 1) Bimmerworld, 2) Turner Motorsports, 3) Bavarian Autosport, 4) BMP Design and on and on Missed Out on locking in this deal, they have to go through VAC at retail pricing to purchase these great working dampers.
Since VAC & Bimmerworld are competitors in the global BMW performance aftermarket arena, Bimmerworld who controls SE46 racing is Not about to use a product like the ATI Super Damper which is controlled by VAC.
So politics once again is dictating what should be a simple decision: The use of the ATI Super Damper for SE46 Racing. Anytime throughout the USA when a SE46 race motor dies due to oil pump failure, this can be instantly attributed to the horrible political decision to Not use the ATI Super Damper.
Rob43
Old 11-30-2016, 01:23 PM   #18
Ass Fault
My Ride: CTS-V
It doesn't address the class issue, but ATI frequently dumps excess inventory on eBay as blems, for much less than retail. Maybe if enough people inquired, they might push some inventory through that channel.
http://stores.ebay.com/ATI-Performance-Products
Ass Fault is offline   Reply With Quote
Old 12-12-2016, 03:00 PM   #19
JamesClay
Rob43
I don't want to pick a fight, but that is inaccurate on several fronts.
We do not control SE46 racing, or even parts - I am a consultant to the program, the group makes decisions to allow parts as needed, even if BW doesn't have them. As a business owner, I do work to carry the best parts for the series-allowed specs - for this and all classes.
The damper for this specific M54 application (I don't agree across all applications) solves a problem. But so does a lower rev limit, not having big cams, headers, etc. The powerband for a SE46 configuration doesn't reward revving them out, and the goal was a long-life understressed engine.
Adding "allowed" parts that are often seen as necessary adds to the perceived cost of building a car. We were extremely conscious of the price tag we were creating, and I was overruled on several suggestions under $150. Adding an $800 part that wasn't deemed necessary would be irresponsible. And to date, two years since this thread was active, no failures to my knowledge, so the proof is in the pudding.
James Clay
www.bimmerworld.com
Bimmer World
