General Off-Topic
Old 12-30-2013, 02:46 PM   #61
KwhyLE
My Ride: 2.5
If youre still having problems, dont restore until after you JB.
KwhyLE is offline   Reply With Quote
Old 12-30-2013, 06:34 PM   #62
shwagon
My Ride: 325it 5-speed
Need some help guys... I purchased an AT&T iPhone 5 (running ios7) off of ebay to use on the straight talk plain. I see that AT&T has apparently stopped 3rd party unlocking. Is there a way to get this phone working on ST using the jail break option?
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 12-30-2013, 06:46 PM   #63
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
I didn't have to switch anything from my AT&T 4s? I just literraly cut the sim card to mini sim and it worked. Att network changed to HOME on the carrier side of the iOS but back then it was iOS 6.
I've had straight talk about 2 years now, but every since I updated to iOS 7 my carrier shows TFW as in tracfone wireless since their affiliates, just like simple mobile I think.
when iOS 7 told me to upgrade some carrier settings I put yes, and that messed up my Inet through tracfone, so luckily I restored my phone and everything is working fine.
Besides all the jailbreak stuff.
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 12-30-2013, 06:56 PM   #64
shwagon
iOS 7 Jailbreak released.
This is what I'm getting when I insert the SIM card and try to complete the set upClick image for larger version
Old 12-30-2013, 07:15 PM   #65
b0bab0i
My Ride: x
Find a friend that has an AT&T sim and put it into activate phone. Switch sims after. See if that works. Or call AT&T CS and have them unlock the phone.
b0bab0i is offline   Reply With Quote
Old 12-30-2013, 07:26 PM   #66
nojoda
Ok so here's an update how I fixed the jailbreak problem. and the cause.
Cause: upgraded from iOS 6 to iOS 7 through wifi. ( not really caring )
Fix: backed up my iphone, restored Iphone ( forces you to automatically update through Itunes. hence iOS 7.0.4 )
Cause: Jailbreak through OSX Mavericks through same computer I used to back up and restore phone. - somehow jailbreak wouldn't work.
Fix: restored Iphone through Itunes on PC, switched over to my MacbookPro after for the backup, then switch back and jailbroke on the PC.
voila, cydia is working correctly, no carrier name is working.
Old 12-30-2013, 07:33 PM   #67
nojoda
This is what I'm getting when I insert the SIM card and try to complete the set upAttachment 540586
Im not sure if this guide will help, but
swapping sims to fix straight talk problem.
I got around that screen because iOS let me continue, i updated carrier settings and I was set. unfortunately I think iOS7 is restricting for a reason. which makes no sense since iphones generally could be sold unlocked
Old 12-30-2013, 11:33 PM   #68
shwagon
OK thanks for the idea of switching SIM cards, this got me to the home screen and I was able to reload all my data from I tunes. My ony problem is, now when I insert the straight talk SIM it automatically sends me back to the set up screen with the same message I posted earlier... If I take the SIM out it brings up the home screen again. Any suggestions?
Old 12-31-2013, 12:20 AM   #69
awesomechinz
My Ride: 1999 BMW 323i sedan
Call AT&T and tell them that you would like to unlock your iphone (even though the servers should have automatically unlocked it when the 2 year contract was completed/properly terminated)
awesomechinz is offline   Reply With Quote
Old 12-31-2013, 12:36 AM   #70
w0w
My Ride: '02 M3 Vert
im still on ios5 on my 4s believe it or not and i want to upgrade to the ios7 untethered version. do i need to update on itunes first then run the evasion software or can i just jump straight to jailbreak?
daron
w0w is offline   Reply With Quote
Old 12-31-2013, 02:30 AM   #71
b0bab0i
My Ride: x
Update to iso7 on iTunes, then run evasion.
Old 12-31-2013, 02:32 AM   #72
KwhyLE
My Ride: 2.5
Backup, Restore on iTunes, Select the 7.0.4 update, close iTunes, Open Evasi0n, Jailbreak.
Old 12-31-2013, 03:54 AM   #73
w0w
thanks guys! everything went smoothly, just need to find out a tethering app and ill be content for now
daron
Old 12-31-2013, 11:58 AM   #74
KwhyLE
My Ride: 2.5
Mobile Substrate is not updated and called "Cydia Substrate." There should be less problems now with tweaks. Devs are still trying to update all the apps and tweaks and then we should be good.
For tethering, there's tetherme or PDAnet. Everyone has their positives and negatives for both.
Old 12-31-2013, 12:44 PM   #75
bry330i
My Ride: 2002 330i
took out hiddensettings7 since it does not save the settings when you respring.
i use noslowanimations now to speed up the animations. works fine so far, no settings to configure.
bry330i is offline   Reply With Quote
Old 12-31-2013, 04:19 PM   #76
w0w
PDAnet doesn't work (which is what i was using before), ill try tetherme now and report back!
daron
Old 12-31-2013, 04:57 PM   #77
bry330i
My Ride: 2002 330i
i use "tether". always worked, regardless if it's jailbroken or not. just have to connect your phone via USB to the computer.
if you need wireless hotspot, get mywi. well worth it.
Old 12-31-2013, 05:01 PM   #78
aldeghij
My Ride: 2003 330i
Jailbroke my iPhone 5 Xmas eve and all was working fine. Did today's update now google plus, Facebook, Twitter, Instagram are all crashing. Wtf? Reinstalled mobile substrate as well. Dammit.
aldeghij is offline   Reply With Quote
Old 12-31-2013, 05:06 PM   #79
bry330i
My Ride: 2002 330i
that happened to me, i dont know what the culprit was, but i restored my phone and re-jb'd it. works fine now without any reboots so far.
Old 12-31-2013, 05:20 PM   #80
w0w
i heard people with att have had issues with mywi. im contemplating purchasing tetherme now or waiting for pdanet support
daron
