jtower se46 build - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 12-24-2013, 03:52 PM   #1
jtower
My Ride: spec e46
jtower se46 build
picked up a halfway decent 2002 manual sedan near parkersburg, va a couple of weeks ago. 170k miles, runs and drives great, a couple of trivial warning lights on the dash but not CEL so don't care. will document the build as it happens, the goal is to have the bulk of the mechanical work done (including cage) by feb so i can get it on track and start dialing it in.
jtower is offline   Reply With Quote
Old 12-24-2013, 04:07 PM   #2
jtower
My Ride: spec e46
had way too much energy last night so i started pulling apart the front end. between the xenon headlights, HID fogs, and angel eyes there were a lot of wires and ballast that came off. A/C removal was next, not only is the compressor heavy but the mounting bracket and tensioner isn't exacy tiny either. radiator drain plug broke off as soon as i tried to unscrew it, and holy crap are some of those hoses difficult to remove, the "quick connect" system that bmw uses isn't my favorite. then it's a simple matter to pull the bumper, the bumper supports, and the whole front clip slides off easy. looks like i have nearly new front control arms too, bonus!
ID:	539842   Click image for larger version
Old 12-24-2013, 04:19 PM   #3
jtower
My Ride: spec e46
today i spent an hour or two on the trunk and interior strip. man there is a lot of sound deadening on these cars. fortunately it all comes out quite easily, there's a little bit of tar on the unibody that i still need to remove. next is headliner, front seats, and carpeting.
ID:	539846   Click image for larger version
ID:	539847   Click image for larger version
Old 12-25-2013, 07:53 AM   #4
rsrdan
My Ride: 1991 Bmw 2001 325ci
Are you weighing any of the material you removed?..getting ready to tear into mine....see you at VIR
2001 325CI
1991 325ix
rsrdan is offline   Reply With Quote
Old 12-25-2013, 08:09 AM   #5
AudiEtr
My Ride: 330i
^ yeah, your car has prob lost close to 350-400 lbs!
Good to see another car getting built for this series!
AudiEtr is offline   Reply With Quote
Old 12-25-2013, 05:57 PM   #6
jtower
My Ride: spec e46
i don't have a lot of room so once something is removed it goes into the trash or recycle bin, no chance to weigh stuff. but i can tell you that it's a lot.
more progress today - airbags are out, stereo and hvac controls gone, sunroof assembly removed, plus lots of little misc stuff items. holy crap is the sunroof heavy, the complete assembly has to be 60# or so, and it's at the highest point on the car, losing that is a huge benefit. the airbags aren't light either, especially the passenger side one which is probably 20#. next comes the fun part - dash removal. not looking forward to that, although it will permit removal of the heater core and a/c evaporator, and it has to come out for the cage anyway.
ID:	539959   Click image for larger version
ID:	539960   Click image for larger version
ID:	539961   Click image for larger version
Old 12-27-2013, 10:53 AM   #7
jtower
My Ride: spec e46
took a bit of doing but the dash i got the dash removed, exposing the metal support frame and hvac system. removing the frame was easy enough but the hvac stuff was a pita, i'm just glad that i don't have to put it back in. while i was at it i yanked the seats too, bloody hell are those things heavy. tonight it's carpeting, misc trim, and start working on the doors. pretty soon i'll drop it on the scales to get a sense of where we are.
ID:	540099   Click image for larger version
ID:	540100   Click image for larger version
Old 12-27-2013, 11:28 AM   #8
unevolved
My Ride: 2003 325i
Nice. Subbed.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 12-27-2013, 06:51 PM   #9
jtower
My Ride: spec e46
carpet and sound damping material out. up next is tar removal, ugh.
Old 12-27-2013, 07:01 PM   #10
unevolved
My Ride: 2003 325i
Make sure and use dry ice!
Old 12-27-2013, 11:41 PM   #11
badfast
My Ride: A car
really? is that a trick for removing that tar crap? If so, I wish I would have known that! Stuff sucks.
badfast is offline   Reply With Quote
Old 12-28-2013, 09:00 AM   #12
unevolved
My Ride: 2003 325i
Yeah, it pops off in chunks. It only works on horizontal surfaces where you can let it sit, but it still saves a ton of time. It's much easier if you put it in a pillow case so you can pick it up easier, and don't forget to wear welding gloves!
Old 12-28-2013, 06:45 PM   #13
jtower
My Ride: spec e46
car weighed in at exactly 2600# as pictured. there's still more to remove, and then more to add back, but the target weight of 2900# w/ driver is very much achievable. might even come in under that.
ID:	540317   Click image for larger version
Old 04-12-2014, 05:26 PM   #14
jtower
My Ride: spec e46
sorry, i haven't been keeing this tread up to date. i won't post all of the intermediate steps but here's the finished and painted cage.
ID:	553706   Click image for larger version
ID:	553707   Click image for larger version
Old 04-12-2014, 05:44 PM   #15
jtower
My Ride: spec e46
the first batch of parts, mostly brakes and suspension, that were installed prior to the first track day. bimmerworld did a great job putting this all together and making sure i had everything needed to finish the job.
ID:	553709   Click image for larger version
ID:	553710   Click image for larger version
ID:	553711   Click image for larger version
Old 04-12-2014, 05:57 PM   #16
jtower
My Ride: spec e46
today i started another big round of work. pulled the exhaust, driveshaft, guibo (severely worn), differential, rear subframe, and rear suspension off the car.
ID:	553714   Click image for larger version
ID:	553715   Click image for larger version
ID:	553716   Click image for larger version
Old 04-23-2014, 12:22 AM   #17
Sedan Hussein
My Ride: e46
Nice updates, car is coming along great. Do you have a shop in Raleigh?
Sedan Hussein is offline   Reply With Quote
Old 06-20-2014, 07:41 AM   #18
Spece46Racer
My Ride: e90
Any updates? It's been about 2 months since your last post. Just curious if you've weighed the car since the cage was installed too. I saw you had it on scales, but didn't comment on the weight.
My buddy and I are going to be building a Spec E46 in the near future.
Spece46Racer is offline   Reply With Quote
Old 06-20-2014, 03:07 PM   #19
Sedan Hussein
My Ride: e46
check out the spec e46 group on facebook. Its alot more active
Old 06-20-2014, 04:45 PM   #20
Spece46Racer
My Ride: e90
TY! Will do.
