Old 12-30-2013, 07:09 PM   #21
Davew
My Ride: 2004 330ci Msport
Ess ts2 tune
Originally Posted by 330i ZHP View Post
hasn't Adam been clear in his experience that the M52 and M54 engines cannot go much higher than 7200
Was trying more so to "diplomatically" tell davcon to leave it for now, and change the intake cam the next time he takes the motor apart! Lol
Davew is offline   Reply With Quote
Old 12-30-2013, 07:13 PM   #22
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
gotcha
/_________\
O==[][]==O
Old 12-30-2013, 07:20 PM   #23
Davew
Ess ts2 tune
plus - the ess tune changes the cut out to 7200
I would assume then also that the 248/256 cams are "optimal" to 7200rpm and not beyond. I personally have no intension of going past 7200rpm, but I have struggled to find little info on these cams.
Old 12-30-2013, 07:34 PM   #24
MSportBMW
My Ride: E46 325, EVO8 MR
It would be a good idea to do a preliminary run on a dyno to check some basic details and go from there (being in Melbourne and all). As for the custom tune, your individual set up e.g. aftermarket cams, will be taken into consideration and the tune adjusted accordingly. It is a proper tune, suited for your car and not a reflash. Best thing would be to firstly touch base with SAS and see how you go.
MSportBMW is offline   Reply With Quote
Old 01-08-2014, 06:31 PM   #25
Davconelectric
My Ride: Mainly cars
Attachment 541758
Got a chance to run her up on a dyno today, running very very lean.
Davconelectric is offline   Reply With Quote
Old 01-08-2014, 07:03 PM   #26
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I turned it so it's easier to look at.
Agreed, poor AFR curve. A good tuner can fix it.
EDIT: 229KW to HP = 307WHP
SUMMIT POINT WV 1:24:229 SCCA
Old 01-08-2014, 09:09 PM   #27
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
So lean after 5k :O
E46 Coupe is offline   Reply With Quote
Old 01-09-2014, 02:45 AM   #28
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Before doing anything with the tune, I would want to know that the fuel pressure is stable all the way through the RPM range. You can check this by connecting to the schraider valve on the fuel rail. (Most rapair shops have the tool for this) Of note, you want to make sure that whatever tester you use, that it doesn't have a check-valve installed. I recently had a fuel filter issue with my Tahoe, where the fuel pressure gauge installed had a check valve to measure peak pressure. So when fuel pressure dropped as RPM increased, it didn't show....
Old 01-09-2014, 05:48 PM   #29
jdjg
My Ride: e39, m52tub30
jdjg is offline   Reply With Quote
Old 01-10-2014, 12:50 AM   #30
Rob43
Rob43's Avatar
One of the "Top 3" Smartest guys here on E46Fanatics !
I spent a few hours re-reading through some of your old threads last night, it's Really Good Stuff.
Rob
Old 02-13-2014, 09:27 AM   #31
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Originally Posted by Davconelectric View Post
Attachment 541758
Yeah, mine was similar to yours on my TS2. Except mine started really rich 11.7 at 2,500, droping to 10 at 5,500 then all the way to 14 at 6,750.
cosmos328Ci is offline   Reply With Quote
Old 02-14-2014, 07:06 AM   #32
cosmos328Ci
Dyno, sorting out problems.
Attachment 541758
Not running very well.
Temp when dynoed was 35+ deg celcius (95+ deg Fahrenheit)
