Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 4.89 average.
Old 12-28-2013, 05:42 AM   #1
Davew
My Ride: 2004 330ci Msport
330ci ess ts2+
Hi all, I have been doing my build thread in the Australian forum of this site, and would like comments and suggestions from the wider fanatics community.
My car is a 2004 330ci Motorsport.
Probably a good time also to mention this is my daily driver
List of mods:
Stage 3 ported Technik head, 1mm Ferea oversize valves, double valve springs, titanium retainers, etc. Exhaust ports opened up past the original "stage 3".
262/252 solid profile cams
Arrow precision solid lifters
Raceware head stud kit
Raceware main stud kit
Arrow Precision Forged Connecting Rods
JE 8.5:1 Forged Pistons
VAC Coated Bearings throughout
Balanced and Blueprinted Bottom End, spec for added oil pressure
Custom Mains Girdle Plates
M3 chain tensioner
New cam sprockets, chains, guides, etc. Chain are iwis race grade chains.
ATI super balancer
1600 ATX Twin Screw charger
GTW6465R (GTW3884R with 64mm compressor wheel) Garret Turbo
Custom Turbo manifold, twin scroll/divided inlet to turbine housing, 3 inch dump and exhaust system. All 304 stainless steel
ESS Liquid intercooled Intake Manifold, with twin Setrab Intercoolers and reservoir.
Besian vanos seals
Samco radiator hoses
Tubosmart Eboost2 boost controller
Turbosmart 50mm Raceport BOV
Twin Turbosmart Compgate 40mm External Wastegates
Turbosmart Compgate 40mm external waste gate converted to supercharger bypass valve
Twin DW 350i fuel pumps and surge tank, twin DW200 in tank feed pumps to surge tank
Turbosmart 1200v2 Fuel Pressure Regulator
Johnsons High Performance dry sump pump, 4 stage
PWR coolant to oil heat exchanger for engine oil heating/cooling
Custom sump
BMW performance brake rotors
"E46 M3 location" custom expansion tank
Zionsville competition radiator kit
Zionsville billet thermostat housing
80 degree Celsius mechanical thermostat
EMP Stewart water pump
Custom 65mm supercharger pulley
Turner sways front and rear
Turner urethane engine and trans mounts
Bilstein ride control coil overs
Custom in bumper cold air intake (K&N 6x9 inch filter)
UUC Twin Disc Clutch and Flywheel Package
SSG to 6 Speed Manual gearbox conversion
2.93 to 3.15 diff ratio change
OS Giken LSD
Subframe reinforcement
Solid Subframe bushes
Modified diff carrier (twin mount at rear of diff)
Have probably left a few items out, I will edit as I remember lol.
Davew is offline   Reply With Quote
Old 12-28-2013, 08:53 AM   #2
jdny516
My Ride: Oxford Green M5
Really good numbers! ESS makes the perfect S/C for E46
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 12-28-2013, 09:44 AM   #3
jdjg
My Ride: e39, m52tub30
330ci ess ts2+
nice bro....
Im just waiting for my ESS T2+ SC, I need to wait 2 more weeks......
nice numbers, when I installed my SC, I will post my numbers......
regards,
jdjg is offline   Reply With Quote
Old 12-28-2013, 09:44 AM   #4
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
Running a "custom TSE3" myself (non-ESS supported), on a fully built M52TuB28 in my 328Ci w a 6MT swap from an 06 ZHP.
I have had the car since the first week of 2006, and it's gone through a number of transformations as I, and it, have aged and matured; suspension has been fully reworked 3 times, 5 brake kits, probably two dozen wheel sets, various exterior "setups", and the engine has goneffrom stock to mild bolt ons, to pushing it N/A As much as possible without getting into the bottom end (a new head with flow benching followed by porting, all new valvetrain from VAC/BW, Schrick cams, radiused valve job, etc) + the full bolt on monty, and finally a fresh ground up boost oriented build designed to support over 20psi @ 10.5:1 CR up to 7900rpm.
Needless to say, it has been anything but a cheap journey, and I would have saved tens upon tens of thousands had I done everything "right" the first time. Still, it's the journey, not the destination, right?
I can give you some advice, but know that this is based solely on my experience and may well conflict with others experience...
- At this level, maintenance is the difference between a perfect car and a junked $20,000 motor, and I personally have cut every single interval in half (oil every 3-5k, trans/diff every 15k, brake fluid every year and bleed every event, PS Fluid I do the turkey baster method and empty/fill reservoir every oil change, fuel filter every 15k, coolant in a 35/65 coolant/water ratio w a bottle or two RL WW every year, etc)
- I have saved thousands upon thousands by doing two things: first is that I always upgrade parts when they need replacing (for example, cooling system: Stewart pump, Samco/Stett/BW hoses, MS thermo, CR/Zionsville radiator, VAC Superlight U/D pulleys, etc), and second is to save up parts until you can have an entire section if the car worked on at once (suspension and drivetrain, for example, as my M3 ZCP is: dropped entire suspension, exhaust, both axles, and diff; JRZ 3-way coils, Hotchkis sways, OS Giken 3.55:1 28-clutch LSD w finned cover, TMS semi-solid diff mounts/bushings, RE RSM, AKG 75D subframe bushings, TMS full chassis weld in reinforcement kit, TMS Adj rear camber arms, RE RTAB + TMS limiter, TMS upper rear control arm bearings, Mahle HD FCA's + AKG FCAB's, GC Camber plates, BW Engine + Transmission "race" mounts, Meyle HD endlinks, Mason Engineering front steel strut brace + rear 3pt strut brace + rear brace to subframe X-Brace, custom front chassis X-Brace from TiG welded Chromoly steel tube, transmission tunnel and exhaust tunnel covered in "gold" reflective foil, AKG steering rack joint, custom CF single piece driveshaft, UUC EVO3+DSSR and ZHP 6spd knob, and a fair amount more; all the suspension parts not already properly finished were powder coated medium black, and the entire car underside was cleaned then resprayed Alpine White and it along with all components were film coat treated for anti-corrosion). Doing all that at once, at a friend'sshop and II have him "un-rush" it which, along with me actively working with him, resulted in a total labor charge of $1000 even, plus another $500 for paint and powder coating. It will be significantly more than that if you are not good friends with the mechanic, but it would still cost way more to split it into multiple jobs as you are disassembling the parts more times than necessary.
- DO NOT WAIT on the subframe reinforcements! And don't settle for anything less than weld-in done by a true professional! I had subframe cracking on my 328Ci just weeks after I gotit, and while BMWNA footed the bill ($9,800), I demanded that the repairs be done to the level that they're willing to warranty it for life, and that simply putting the same factory parts back I wasn't acceptable, because this is a major safety hazard. They ended up putting in an entire M3 rear end, and welding the trouble spots (the body shop doing the work said that was the only thing they felt comfortable with).
- Suspension, brakes, and wheels/tires should be upgraded to a level beyond what the engine is capable of, because in my opinion you can never have too much traction, brakes, or control.
- I would suggest at least a front, entry level big brake kit, and ideally a four-wheel StopTech/AP Racing/PFC setup. I would say that a Wilwood 4-wheel kit would be a great place to start, with the 6P/4P Superlight calipers. The StopTech ST60/ST40 is a step up, then AP Racing, then the StopTech Trophy kit, then PFC. 355mm front is the biggest rotor size to get, 380mm just adds weight and has no real benefits outside serious endurance racing. Regardless of what kit, always get 2pc floating rotors. I prefer slotted, avoid drilled. For a front only BBK, upgrade the rears w caliper rebuild kit, SS lines, brass bushings, slotted rotors, and equivalent pads to the front. For fluid, I have had ATE boil on me multiple times, with stock type brakes and even w my Trophy kit, but Motul RBF600/660 has never even gotten soft on me. It's a truly superior, in every way, fluid.
- IDK what wheels you have, but recommend spending some money on quality 18's or 19's, and honestly for Street use, the only downsideto 19s is a very aslightly harsher ride and more expensive tires, but they do look so much better in mostcases. I hhave 18s for track, 19s for Street. I would recommend a setup along the lines of 19x8.5-9 et32 to et38 front and 19x9.5-10 et38 to et45 in back, with 235-255 width front and 255-275 width rear tires. You can fit this w a bit of fender pulling, and the extra traction and wider track is worth it (I have my fenders cut, pulled, welded, formed, etc; extra 1 3/4+ inch per corner, bit less front, bit more rear).
- A Limited Slip Differential is a must have upgrade, IMO, for these cars when putting down the kind of power our TS setups make. I tried the 2-3 clutch setups, but I would only recommend an OS Giken unit anymore. The difference is huge, with progressive and smooth breakaway and lockup.
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 12-28-2013, 09:58 AM   #5
jdjg
330ci ess ts2+
Nice write up bro...
can you please tell me more about your "custom" TS3 setup?
Im planing in buy the TS3 from ESS but Im wondering if with just only a more thicker head gasket its fine....
regards,
Old 12-28-2013, 10:04 AM   #6
nleksan
I didn't use the ESS pistons, instead went with a full bottom rebuild and worked over head.
Some quick specs:
Carillo rods
JP pistons
ARP hardware
Blueprinted and knife edged crank (later went to dry sump, but the loss in weight still beneficial)
RWC treated bearings
86.5mm bore
Combustion chamber all Swain Tech coated
Flow benched and ported head
VAC Springs and Ti retainers
262/254 cams
RR BBTB
VAC Dampener
(Temporary Sig)
GARAGE:
Old 12-28-2013, 10:10 AM   #7
jdjg
330ci ess ts2+
Some quick specs:
Carillo rods
JP pistons
ARP hardware
86.5mm bore
262/254 cams
RR BBTB
VAC Dampener
nice, thanks bro...
do you have dyno graphic? you have torque/hp numbers?
regards,
Old 12-28-2013, 10:36 AM   #8
nleksan
Somewhere, not on my phone tthough (I am actually at my grandmother's funeral, she finally lost her battle with lung cancer). I didn't r eally document my build as I wasn't active on any of the forums for a few years, got tired of the way E46F and BFc had become. I will look on some of my old hard drives when I get home (have built a new PC since; custom water cooled 3930K @ 5GHz 1.376v, RIVE, 16GB DDR3-2400 9-10-10, 2x 670FTW + 2x680Lightning for benching now 2x 780Ti Classifieds, Samsung 830 256GB, Plextor M5P-Xtreme 512GB, 2x WD10EZEX 1TB, 2x WD VR 500GB RAID0, 3x WD RE 3TB, Titanium HD, etc).
(Temporary Sig)
GARAGE:
Old 12-28-2013, 11:51 AM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Wait!!?? What!!!???
You have a dry sump on your street car?
Old 12-28-2013, 12:02 PM   #10
nleksan
No, it's a track car.
(Temporary Sig)
GARAGE:
Old 12-28-2013, 12:29 PM   #11
unevolved
My Ride: 2003 325i
Damn, I wish you had a build thread on that thing.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 12-28-2013, 04:06 PM   #12
Davew
330ci ess ts2+
Nleksan
Thank you for your reply!
Lots of good info for me to take on board!
I am hoping to do things once only, hence why I am asking for advice/ direction. I need to keep a lid on the expense, and although I am not working to a budget, I wish to save through others experience and buy once
At the moment it is only running oem 17's lol.
I jumped on an opportunity to purchase a lot of the items second hand, but unused, which is why I have started a little backwards.
Totally agree on maintenance, I am onto this already, I should also mention that I am both a mechanic, and fitter and turner, and do all my own work.
Will read through your post a few times, and if you don't mind, will ask a few questions from time to time
Dave
Old 12-28-2013, 04:23 PM   #13
nleksan
I am very glad that my post was of some help to you!
I do kinda wish I'd done a build thread as well, but at the time the whole project was more or less a whole bunch of different ideas (a thank youto PEI330CI, wwhose absolutely incredible knowledge of the platform was invaluable assistance!) , taken and thrown together and shaken really hard until a car fell out lol. Oh, and the other two ingredients were cash (measured by the fi****l), and the enduring help of awesome and talented friends (a retired BMW Master Mechanic who was trained in Germany and worked for BMW M Gruppe for 7 years, nd a vvery talented body and paint guy who runs his own shop and has won a lot of local car shows for his paint and metal work).
Having one of the people who was on the team that developed the S14 series engines, the S50B30/32, and the S54 was the only way my car turned out as well as it did. I can honestly say that he might as well be a wizard, watching him work, but he does love building engines with me becausehhe's "not held back by any restraints, like emissions or having to cater to the poseur crowd of M buyers". I simply lethhim build the head as he thought best, knowing the parameters I was wanting to work within. The cams were custom billet grinds, the valve jobs are "radius free", and despite the oversized valves, they sit flush like stock. The valvetrain is supposed to be good for 8600-9000rpm but even with a larger than ESS spec blower, it'd be out of its efficiency range.
The entire reciprocating mass of the motor is down by about 7Kg, about 240g per rod!
While I don't have a dyno chart handy, and it's been about a year and a half since it was on one, I believe that the last time it was run it put down 422rwhp @ 7550rpm and 392rwtq @ 4680rpm with 90 percent of torque available from 1920rpm to 6500rpm. There's no "VANOS/DISA" Bump either.
(Temporary Sig)
GARAGE:
Old 12-28-2013, 04:47 PM   #14
Davew
330ci ess ts2+
That is excellent power and torque!
Definitely will take your advice on board
Coincidently, I believe PEI330CI was influential in recommending the parts I purchased from their previous owner, whether directly or through research I am not sure. Either way, the top end has worked well for me as far as a street car goes!
Now I have a lot of upgrading to do to bring the rest of the vehicle up to spec!
Old 12-28-2013, 05:28 PM   #15
jdjg
330ci ess ts2+
nleksan, one question, what are the diameter of your SC Stage 3?
regards,
also, so sorry for your lost ;(
Old 12-28-2013, 05:31 PM   #16
Davconelectric
My Ride: 2 dog powered sled
330ci ess ts2+
Looking forward to seeing progress on this one Dave, I'll let you do all the research:-) and when it comes time for your bottom end build, I'll jump on board with mine.
Davconelectric is offline   Reply With Quote
Old 12-28-2013, 06:10 PM   #17
Davew
330ci ess ts2+
Lol
Old 12-28-2013, 06:51 PM   #18
Davew
330ci ess ts2+
Bottom end is a bit of a dilemma at the moment, I don't like the idea of spending the money required without gaining power/ torque. Where myself and davcon live, we cannot find anyone so far that can do a custom tune ( Melbourne, Australia ).
In my case, if I go ts3 with arrow rods, balanced crank, etc, the tune would be ok, if I get rid of the ssg and go manual, plus surgery to both knees lol
Would love to do what nleksan has done bottom end wise, but without a tuner, I would be in trouble!
Old 12-28-2013, 07:07 PM   #19
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I'm a firm believer that the stock M54B30 bottom end can handle 350 to 400 plus WHP (Dynojet / CF SAE) any day of the week*' **.
* Street use, where high RPM pulls are quick & short.
** Bolt-ons like an ATI Damper & Super Oil Pump are a must.
SUMMIT POINT WV 1:24:229 SCCA
Old 12-28-2013, 07:18 PM   #20
Davew
330ci ess ts2+
The bottom end is holding up well, and it is for street use, not track, but with work I have put 30, 000 km on the clock in a little over 12 months, so to keep things optimal, I would like to start planning, purchasing in readiness for the bottom end. At the same time, if I can, I would like to add a little more power as well as (bottom end) reliability.
My plan has been to do the bottom end at around 200,000 k, which with the Klm's I drive will come round quicker than not.
I have loctited and torqued the opn, but do plan on upgrading the pump ASAP. I do have the ati dampener and M3 chain tensioner already fitted
Rate This Thread
