Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 12-29-2013, 05:33 PM   #1
Mazor TAzor
My Ride: 323i
Coolant leak problem.
Hello I just bought a 1999 323i about a month ago and I discovered a coolant leak. It looks like a crack at the bottom of the expansion tank. It also looks like the clips are off set or it's been set back because one of the belts is just rubbing on the tank itself. Any advice? I'm going to a buddies today to take it apart. I'm pretty sure I just have to replace the expansion tank and the rubbing belt. Any advice would be appreciated
Mazor TAzor is offline   Reply With Quote
Old 12-29-2013, 05:41 PM   #2
oldzilla
My Ride: 2006 330 CI Vert ZHP
Several schools of thought on this one, some say replace the expansion tank (do it ). Others say do a coolant system overhaul. Look for Mango's posts about full replacement and search the threads on just replacing what is broke. Bottom line is no matter what path you take the expansion tank has to go. And welcome to the forums.
oldzilla is offline   Reply With Quote
Old 12-30-2013, 11:08 PM   #3
Mazor TAzor
My Ride: 323i
Thanks friend just ordered it along with a new water pump. I had to replace water pump on my old 325i e46 and it's actually quite easy.
Display Modes
