Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 12-31-2013, 10:54 AM   #1
lcpc78
My Ride: 2002 330XI
New to Forums
Thought I would post a hello thread to say hello the community. I have a 2002 330Xi 5-speed that I have owned since 2006 with about 104000 miles on it.
It's pretty much stock except for the DICE integration for my iPhone.
I normally took it to the shop to get worked on but the last 6 months have started to do some of the work myself. After reading these forums and a lot of the DIY posted by the many members I have ventured into doing more DIY. I've found a lot of useful information in these forums that has helped immensely.
Here is a list of stuff done thus far:
Shop
- All 4 Window Regulators
- Clutch
- Passenger front Control Arm
- ECU Replacement (Had a bad module that was burning my driver side door locks. Indy wanted to replace the module but had them replace the entire ECU)
- Rear Shocks
- Front and Rear Brakes (Made the mistake of having indy turn the rotors instead of replacing. Never make that mistake again. Front rotors warped after about 3 weeks and ended up replacing)
DIY
- Complete Cooling System Overhaul (Water Pump, Thermostat, Upper & Lower Radiator Hoses, Belts, Expansion Tank)
- Alternator
- Spark Plugs
- Emergency Brake Issue where it was not ratcheting. It was the tab that was blocking it and the clip came loose. Still need to replace the entire assembly.
Thanks!
Will post a pic later.
lcpc78 is offline   Reply With Quote
Display Modes
