Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 01-03-2014, 11:09 PM   #1
Swiff
My Ride: 2002 330xi
Hazard / Door lock switch replacement 2002 330xi manual transmission
I just purchased this car @ 2 weeks ago
I noticed the Hazard / Door lock was not working. The buttons will light up but did not work. So I decided to pull the console to check the switch and document it.
1: Remove the cup holder.
2: Remove coin holder pulling forward and up.
3: Pull the shifter boot by either squeezing the sides or front and back and pull straight up.
4: Remove 2 screws holding the window switch bezel and pull back first, then lift up a little to see the window switch plugs. The wires are short so don't pull it up too much.
5: Remove 2 plugs for window switches, tilt shifter boot and remove bezel.
6: For the parking brake boot, squeeze the boot on either side and pull up.
NOTE: If your brakes needs adjusting, now is the time to do it.
while holding brake pedal, wheels chocked, or in gear (not running) pull parking brake 2 clicks and tighten each adjusting nut the same amount of turns. one is for the left and one is for the right. Release and recheck and redo procedure if lever is too high. If the car still rolls then you may have to adjust your parking brakes at the wheels.
7: Open the rear ashtray door and remove the ashtray. Remove 2 plastic screws and remove lower ashtray holder. Unplug light from ashtray holder. Remove 2 lower console screws.
8: Turn armrest up and lift front of center console so that you can get your fingers under the switch to push it up and out. Unplug the connector. Put new switch in and reinstall everything.
This is why it wasn't working. The clips were broken.
The other side was good.
All back together again.
Name:	2002 BMW 330xi 3.jpg
ID:	541110   Click image for larger version
Name:	2002 BMW 330xi 6.jpg
ID:	541111   Click image for larger version
Name:	2002 BMW 330xi 7.jpg
ID:	541112   Click image for larger version
Name:	2002 BMW 330xi 7A.jpg
Name:	2002 BMW 330xi 8.jpg
ID:	541114   Click image for larger version
Name:	2002 BMW 330xi 9.jpg
ID:	541115   Click image for larger version
Name:	2002 BMW 330xi 10.jpg
ID:	541116   Click image for larger version
Name:	2002 BMW 330xi 11.jpg
Name:	2002 BMW 330xi 12.jpg
ID:	541118   Click image for larger version
Name:	2002 BMW 330xi 13.jpg
ID:	541119   Click image for larger version
Name:	2002 BMW 330xi 14.jpg
ID:	541120   Click image for larger version
Name:	2002 BMW 330xi 15.jpg
Name:	2002 BMW 330xi 16.jpg
ID:	541122   Click image for larger version
Name:	2002 BMW 330xi 17.jpg
ID:	541123   Click image for larger version
Name:	2002 BMW 330xi 18.jpg
ID:	541124   Click image for larger version
Name:	2002 BMW 330xi 19.jpg
Name:	2002 BMW 330xi 20.jpg
ID:	541126   Click image for larger version
Name:	2002 BMW 330xi 21.jpg
ID:	541127   Click image for larger version
Name:	2002 BMW 330xi 22.jpg
ID:	541128   Click image for larger version
Name:	2002 BMW 330xi 23.jpg
Name:	2002 BMW 330xi 24.jpg
ID:	541130   Click image for larger version
Name:	2002 BMW 330xi 25.jpg
ID:	541131   Click image for larger version
Name:	2002 BMW 330xi 26.jpg
Swiff is online now   Reply With Quote
Old 01-03-2014, 11:14 PM   #2
Swiff
My Ride: 2002 330xi
Oh the part cost me only $25.00
Old 01-07-2014, 07:43 AM   #3
TitanSilverE46
My Ride: 2001 318i & 325i
I had to change mine recently but I didn't bother with all the work you did on the console, just steps 3,4 than 8. The front of the console lifts enough to pop the switch out. Unplug and plug in the new one ($40 from local wrecker). Mine had failed in the same way, the clips had broken.
TitanSilverE46 is offline   Reply With Quote
Old 09-24-2014, 10:11 PM   #4
Epidemike
My Ride: 2004 330i
Thanks for the great write up. While I didnt replace the switch, I just used some duct tape to secure the bottom part. tested and it seems to have worked.
Epidemike is offline   Reply With Quote
Old 09-25-2014, 09:03 AM   #5
markusmarkus
My Ride: 2001 330Ci
This switch unit has a history of failing as the OP's did. My solution: Gorilla glue!
Old 09-24-2015, 04:37 PM   #6
EDWAGON
My Ride: 2004 325xiT
need to do this thanks for the write up
EDWAGON is offline   Reply With Quote
Old 10-19-2016, 07:55 PM   #7
Swiff
My Ride: 2002 330xi
I was bored so I made the pictures bigger.
