Sponsored by BimmerWorld
Old 01-05-2014, 03:05 PM   #1
Phrygian
My Ride: 2000 323i
Subframe Reinforcement and Bushings
Used subframes seem to be fairly inexpensive, so I'm considering buying one to save time by prepping it in advance before I drop the rear end out of my car. Does anyone with experience doing this job know how much time this might save?
Phrygian is offline   Reply With Quote
Old 01-05-2014, 05:39 PM   #2
Flop
My Ride: '04 330Ci 6MT
I just did both the subframe and diff bushings. They come out easier than you think. The hardest one to do is the large rear diff bushing. You will need a puller, a STRONG puller.
I have pics of removing my bushings in my build thread.
Probably took me 3-4 hrs to remove the old bushings, and another hour to press in the new ones.
Flop is offline   Reply With Quote
Old 01-05-2014, 10:48 PM   #3
Phrygian
My Ride: 2000 323i
Nice build thread. I'll probably be sticking to rubber, unless someone can convince me otherwise. I'm not really looking for performance, just a solid daily driver. I just recently did my front end and kept it stock, although I'm kind of regretting not going with sport springs and struts while I had the opportunity.
Old 01-05-2014, 11:33 PM   #4
Flop
Going to poly subframe bushings will not increase any NVH. See the thread below for an enthusiasts review of AKG's poly 90a subframe bushings.
http://m3forum.net/m3forum/showthread.php?t=411517
Going to poly diff bushings, however, WILL increase NVH (mainly increased gear noise).
Old 01-06-2014, 02:52 AM   #5
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
I have PowerFlex subframe bushings in one car, AKG 75D in another, and zero problems with either. The latter are stiffer, but theformer are ffor my DD and fit the need perfectly.
I went with TMS semi-solid diff mounts/bushings, and very happy.
One benefit of swapping in a new one is that you can do the work without being pressured by time.
If I were you, I would get it powder coated, a nice black. It would look nice, but also prevent rust.
Are you doing weld in plates? If so, it's worth it to get the full chassis kit from TMS, which really tightens up the car. It was still cheaper than buying individual components, for me, even though I wasn't going to use the rear control arm reinforcements (installed TMS adj RCA's at the same time).
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 01-07-2014, 10:42 PM   #6
Phrygian
My Ride: 2000 323i
The plates will be arc welded. I have a friend that can help me with that.
Old 01-17-2014, 04:30 PM   #7
Phrygian
My Ride: 2000 323i
I've got a subframe and OEM/Meyle HD diff bushings on the way. Now, after much reading, I'm considering going with Powerflex 70A subframe bushings. I only want to do this job once.
Old 01-17-2014, 07:51 PM   #8
nleksan
Go with AKG 75D for subframe and differential. While I've had zero problems with PF, I believe that the Quality Control may have declined of late, and with the newest bushings from them on any of my cars at around 2yrs (oldest 5yrs), I can't guarantee the current batches are as good. AKG I have used within the last few months, just before mid Fall, and the consistency is as good as ever.
I also believe that having a consistent durometer rating across all heavily loaded suspension (ie subframe) parts, as wellas drivetrain parts, wwould be better than significant variations between mounts. I am a biochemical engineer, not mechanical, so far froman eexpert, it isjjust what makes sense to me.
(Temporary Sig)
GARAGE:
Old 01-17-2014, 10:20 PM   #9
Flop
75D diff bushings will be pretty noisy. I have the 90a AKG bushings and am considering swapping at least the front mounts back to OEM. 75D might as well be solid aluminum.
My recommendation would be solid subframe bushings coupled with OEM diff bushings. Best of both worlds without the added NVH. No sense in "matching" durometers.
Old 01-18-2014, 05:53 PM   #10
Phrygian
My Ride: 2000 323i
As I said, I have already ordered OEM front diff bushings and a Meyle HD rear.
nleksan, what makes you question the quality of the Powerflex bushings? I'm having a hard enough time justifying roughly $215 on what is simply some plastic and a little bit of aluminum. I'm not paying $250 for the AKGs. I'm actually considering the Revshift subframe bushings which are $189.99.
My subframe arrived today. I started a new project thread here.
Old 01-18-2014, 06:06 PM   #11
nleksan
I personally have had ZERO problems with ANY Powerflex products, I have just noticed an uptick in bashing them. Thought it best to share.
(Temporary Sig)
GARAGE:
Old 01-18-2014, 07:52 PM   #12
Flop
Those revshift bushings look fine. Pretty good deal too. Get the 95a ones
Old 01-19-2014, 12:47 AM   #13
Phrygian
My Ride: 2000 323i
The 95As in my lowly little 323i with non-sport suspension?
I searched for some examples of the Revshift subframe bushings in E46s, but I haven't found any. There are lots of posts about the flexdisc/guibo though. Maybe I'll be a guinea pig.
Old 01-19-2014, 01:18 PM   #14
Flop
I bet you won't notice a difference between the 95a and the 80a ones. Both are much firmer than stock. The reason I'd recommend you go with the 95a ones is that you stated you don't want to ever have to replace them again. 95a will be less prone to wearing out.
Anyway, either one would be good. And the community would sure appreciate you giving them a try, too! :thumb up: Subframe bushings are pretty hard to screw up... just a round slug of polyurethane with an aluminum center. I wouldn't be worried about them not fitting.
Good luck!
Old 01-24-2014, 12:04 AM   #15
Phrygian
My Ride: 2000 323i
I ordered the Revshift bushings today ... the green ones
Old 01-24-2014, 01:47 AM   #16
Flop
Good man.
Old 02-03-2014, 07:50 PM   #17
Phrygian
My Ride: 2000 323i
I ordered the Revshift bushings on the 23rd. The only thing I've received so far is a payment confirmation. As of this evening, no bushings, no e-mail or indication they have shipped, no tracking number, and no response to the e-mail I sent them over the weekend asking for a status on the order.
Update: The bushings were shipped 1/7 and I received them on 1/11.
