DIY: Fitting 6.5 front midbass speakers - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-05-2014, 08:13 PM   #1
orb
My Ride: 325Ci
This was done in an '02 non HK coupe, not sure if it's the same for sedans, wagons, or verts.
To start, the speakers I used were the Infinity reference 6032SI. They sound pretty good, not as much bass as stock but they sound and fit nicely. SI means shallow, which is what you need need (unless you want to get crazy with fabrication).
Step 1: Remove your door panel. Unscrew the T-20 bolts on the armrest, behind the airbag cap, and on the door pull handle behind the round black cap. Then simply pull it off and disconnect everything. If you still here need help there's some good pictures in this DIY:
http://forum.e46fanatics.com/showthread.php?t=689127
Step 2: Now that you've removed the panel, unscrew the phillips head screws holding on the original speaker.
Step 3: Using some kind of shears, cut your homemade bracket out of the original speaker, yes, this will ruin your old speaker, but it was likely already ruined.
Step 4: Put some kind of foam on the speaker, the speakers I used came with some precut. Drop the speaker into the "basket" on the door panel. I don't know about other speakers, but these fit in perfectly.
Step 5: Place your homemade bracket over the new speaker. You're going to need longer screws. Be sure to tighten down all screws evenly. I had to use washers. Everything should be solid. Be sure the terminals are facing UP.
Step 6: Crimp new connectors onto the speaker wire in the door.
Step 7: Plug in all connections, and reinstall your door panel. I took the liberty of replacing all of the plastic clips to prevent any future possible rattles.
After a few days so far, they sound pretty good for the price. There are no rattles.
ID:	541388   Click image for larger version
ID:	541389   Click image for larger version
ID:	541390   Click image for larger version
ID:	541392   Click image for larger version
ID:	541393   Click image for larger version
ID:	541394   Click image for larger version
orb is offline   Reply With Quote
Old 01-05-2014, 08:18 PM   #2
Avetiso
My Ride: 2003 ZHP 6MT
Re: DIY: Fitting 6.5 front midbass speakers
Awesome. I've been looking at infinity.
Avetiso is offline   Reply With Quote
Old 01-05-2014, 08:27 PM   #3
Sansho
My Ride: 2001 325i
Nicely done!
Sansho is online now   Reply With Quote
