Go Back   E46Fanatics > Everything Else > The Off-Topic > Photography
Photography
Old 01-05-2014, 10:24 PM   #1
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
200mm vs 300mm quality
Hey guys, looking to possibly sell my nikon 55-200mm VR lens for a 300mm to get more range for my shots at work (airport). Just curious is the quality will drop at full zoom.
Might get this
http://www.bhphotovideo.com/c/produc..._4_5_5_6G.html
or
http://www.bhphotovideo.com/c/produc..._70_300mm.html
Old 01-06-2014, 11:45 PM   #2
trj
My Ride: 325Ci
From what I read, I would go with the VR version. On that full range you will definitely need VR if you are shooting handheld.
I am also contemplating on these two, but I saw a 80-210mm f4 on Craig's list. Very tempted to buy that one but I don't know if I should buy used one not knowing much about it.
How much are you planning to sell the 55-200 VR for? I might buy it if I don't like that one.
Old 01-07-2014, 06:31 PM   #3
Andy2108
My Ride: SpecE46 & E46 M3
That 70-300 is probably one of nikon's worse lenses sold in the past decade, imo. At 300 its properly bad...
De gustibus non est disputandum.
Old 01-09-2014, 05:43 PM   #4
tachi1247
My Ride: '04 330i
Can't find the review right now, but the af-s with vr version of that 70-300 is pretty good. Don't know anything about the version posted though.
Check out photo forums for better deals on used gear. Fred miranda and dpreview are two.
Sent from my Galaxy Nexus
tachi1247 is offline   Reply With Quote
Old 01-13-2014, 10:56 AM   #5
SamDoe1
My Ride: 4cyl of fury
Probably a bit late to this party but here's some light reading:
70-300 - http://www.photozone.de/nikon_ff/620...70300f4556vrfx
Can't find a similar review on that site for the 55-300 but to answer your question, no. If you hold the quality of both lenses equal, a lens at 300mm will have the same quality as one at 200mm. Obviously if you change the quality of the lens, your image quality will improve or degrade accordingly as well. Lenses with a larger range between wide and telephoto will typically have worse quality than one with a smaller range (again, holding quality equal) as there are more compromises in lens design with a larger range.
