///M3 Forum
Old 01-09-2014, 08:17 PM   #1
xsxpxhx
My Ride: 2002 M3
e46 02 M3 occasionally turns off at a complete stop
Has anyone encountered this? Solution?
xsxpxhx is offline   Reply With Quote
Old 01-09-2014, 09:39 PM   #2
sakumaxp
My Ride: 02 M3 convertible
when was the last time you had an inspection done? any lights?
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 01-09-2014, 09:44 PM   #3
msane3
My Ride: 2007 335i
Smg?
msane3 is offline   Reply With Quote
Old 01-09-2014, 10:11 PM   #4
stuntin325
My Ride: 2001 325
Any codes?
Sent from my SPH-L710 using BimmerApp mobile app
stuntin325 is offline   Reply With Quote
Old 01-09-2014, 10:33 PM   #5
xsxpxhx
My Ride: 2002 M3
Inspection was done about 2 years ago. No indicator lights, when it turns off you just see the dash lights then the car starts normal again when I try to start it up. Its not SMG, I just replaced the pump a year ago. I havent read the codes yet, im taking it in this weekend to get it checked out.
Old 01-09-2014, 10:40 PM   #6
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Camshaft position sensors (aka rpm sensors )don't always throw codes ...
But that is most likely the issue
Bimmer4Lyfe is offline   Reply With Quote
Old 01-09-2014, 10:41 PM   #7
Christina330i
My Ride: 2003 BMW 330i
Vanos
Christina330i is offline   Reply With Quote
Old 01-09-2014, 10:42 PM   #8
msane3
My Ride: 2007 335i
I'm just asking if it's an smg car. They occasionally like to stall when they come to stops just like human error. If it drives like normal besides that, I wouldn't be too worried about it. Unless it's more often than occasional like you stated.
Old 01-10-2014, 09:04 AM   #9
xsxpxhx
My Ride: 2002 M3
Vanos really? Can you state the reason? Or are you just throwing that out there?
Originally Posted by Christina330i View Post
Vanos
Old 01-10-2014, 09:09 AM   #10
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If it happens to do this more reliably when, say, you're braking harder at a stop...being in third moving at pace, braking harder and dropping into neutral (in a manual), then consider ICV. Did this for months in my non-M.
Cleaned the hell out of ICV...also removed and clean TB (though you'd have 6 to clean)...replaced intake boots while there anyway.
But, get your codes read...no reason to suspect most sensors unless you're seeing a code for them. When you get codes (for free at Autozone) translate them into English, search thread titles for them here, then write back and someone will be able to point you in some plausible direction.
hth
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-10-2014, 10:45 AM   #11
Christina330i
Sorry. I assumed you knew what the vanos was,so I thought no explanation would be needed once stating that could be the problem. But the vanos affects emission,torque,idle,and fuel economy. Couldn't really find the words myself to explain it in a way that could be understood,so I pulled this out of a book : "Overall loss of torque and power, particularly in the lower RPM range, < 3k. Bogging then surging at 3k RPM. Uneven power distribution and RPM transition. Engine hesitations in the lower RPM range, < 3k. Louder idle and intermittent idle RPM hiccups. Difficult takeoffs. Loss of power and bogging when AC on. Increased fuel consumption. Vanos fault codes.
Double vanos cars with the M52TU engine (98/99-00) experience cold weather cold start idle jolts and possible stall."
Hope this helps
Old 01-10-2014, 11:13 AM   #12
xsxpxhx
My Ride: 2002 M3
Hope this helps
I knew what you meant when you said VANOS, I just didnt know what the symptoms were of VANOS. Thanks though. I hope its not.
Old 01-10-2014, 11:14 AM   #13
xsxpxhx
My Ride: 2002 M3
hth
Thanks man, yea I'm definitely going to check it out. Before that happen, I actually got a SES light but then it went away. Im sure the codes are still there.
Old 01-10-2014, 11:41 AM   #14
Christina330i
You're welcome
Old 01-10-2014, 12:53 PM   #15
taylor192
My Ride: 2003.5 M3
Does your idle drop when coming to a stop? and sometimes this leads to a stall? If so search for "idle drop", the issue has been discussed at length, unfortunately there is no definitive solution.
Old 01-10-2014, 02:06 PM   #16
xsxpxhx
My Ride: 2002 M3
I will take note of that next time I drive. I have not checked. But I will now. Thank you Taylor192. Im getting the car checked this Saturday to run the codes to see if anything comes up and will share here.
Old 01-11-2014, 12:18 PM   #17
xsxpxhx
My Ride: 2002 M3
P0128 was the code. Engine temperature sensor. It's odd though, that would make my car stall at a complete stop. :/
Old 01-11-2014, 01:35 PM   #18
taylor192
My Ride: 2003.5 M3
I'll bet you $5 it won't. Probably unrelated.
Sent from my Nexus 5 using BimmerApp mobile app
Old 01-11-2014, 02:19 PM   #19
xsxpxhx
My Ride: 2002 M3
I have been braking hard many times and now it doesnt stall. So..idk..I guess I have to wait till it drops another code or something else. Having read into the vanos I def want to do the vano kit and replace the seals.
Old 01-11-2014, 02:54 PM   #20
Christina330i
I'll bet anything that it is the vanos. Another thing,did you reset the diagnostics then run it again? I say it was a fault code.
