///M3 Forum
Old 01-10-2014, 12:25 PM   #1
Grendelsbane
My Ride: M3
SMG 2nd to 3rd gear only, shifts slow
I tried looking for the answer to this...found something on m3forum.net, but the post was from 2012 and the last guy didn't seem to get any answer.
I got my SMG pump serviced, salmon relay replaces, and compression springs done, but when I drive more "spiritedly" from 2nd to 3rd and only 2nd to 3rd there is a LOOOOOOOONG lag before it snaps into gear. It does seem that if you take your foot off the accelerator and then put it down again that it finds 3rd much faster, but still slow compared to the other gears. The issue seems to happens regardless of setting on the drive logic.
I have tried the SMG reset and still no joy. Does anybody have any ideas what could be causing the issue and more importantly fix the problem?
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Mishimoto Aluminum Radiator / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune
Grendelsbane is offline   Reply With Quote
Old 01-10-2014, 05:07 PM   #2
Kyemaul
My Ride: 2006 E46 M3 Vert
My friend is experiencing the same problem ! He getting word its the gear position sensor
Kyemaul is offline   Reply With Quote
Old 01-10-2014, 06:20 PM   #3
Grendelsbane
My Ride: M3
I changed that thing though.
[EDIT]
Maybe not, I changed the crankshaft speed sensor. I will check out that Gear Position sensor.
Old 01-11-2014, 08:51 PM   #4
$ilent ///M
My Ride: 03.5 M3 smg lsb
how many miles do you have on the car
$ilent ///M is offline   Reply With Quote
Old 01-12-2014, 01:18 AM   #5
Grendelsbane
My Ride: M3
113k
Old 01-12-2014, 12:56 PM   #6
$ilent ///M
Try getting your clutch slip points and learning curves reset
Old 01-12-2014, 08:04 PM   #7
Grendelsbane
My Ride: M3
Yeah, I think that is what I am going to do.
Old 01-16-2014, 01:59 PM   #8
Kyemaul
Any updates ????????????? DID YOU CHANGE THE GEAR POSITION SENSOR?
Old 08-16-2015, 09:01 PM   #9
crazyazz
My Ride: 2002 M3
I have this issue, what is the likely cause?
crazyazz is offline   Reply With Quote
Old 08-16-2015, 09:15 PM   #10
Commando
My Ride: '02 325Ci MT '04 M3
Do the GPS and clutch adaptations with INPA.
While you are there look at the the pump pressure. Mine comes up to cut-off from zero in <6 seconds.
GPS.
Commando is offline   Reply With Quote
Old 08-17-2015, 12:14 AM   #11
crazyazz
My Ride: 2002 M3
GPS.
I have done the full adaption in INPA no change. Will look at the pump cut off time next time I run it, thanks
