The Showroom
Old 01-11-2014, 11:16 PM   #1
MikeL330
My Ride: 2004 330i SMG
A, B, and C Pillar re-wrap.
As many of you have experienced, my fabric on the pillars of the car had finally started to peel off and flap about while driving with the windows down. I decided rather than just replace, to upgrade a bit as well. After a quick trip up the road to a fabric shop, I had an awesome black suede that matched the interior pretty well. As you've seen from the DIY section, this is a pretty straightforward upgrade, but I think the color change has made a pretty significant change to the appearance to the interior, especially from the drivers pov. This was my first crack at any kind of upholstery so there are some rough edges here and there.
2004 330i SMG
1985 528e 5spd
MikeL330 is offline   Reply With Quote
Old 01-31-2014, 02:08 PM   #2
lennon31987
lennon31987's Avatar
My Ride: imolarot II M
Send a message via AIM to lennon31987
now you should do the entire roof piece, would look so much better.
Last of the best-
ILLm3 hates me cause im GGGOOODLOOKIIINN
seeking detailing perfection?
lennon31987 is offline   Reply With Quote
Old 01-31-2014, 06:11 PM   #3
lamsv
My Ride: 2001 325iT
^ That is a lot of work. Would have to cover the sunvisors, paint the light housings, hooks, grab handles, etc, to match the black. Maybe should have gone with a suede that matched the headliner color?
Nice work never the less. Not an easy job to do and not end up with no wrinkles or glue stains.
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 02-02-2014, 01:42 PM   #4
SkrApUNB
My Ride: 03 325i
nah you can leave the grey it doesn't look too bad especially since you have silver trim. it would look good.... i did my headliner as well as my pillars... you'll probably regret not doing it all at one time. but i will say that you can get the pillars out a lot easier now that you know how.. I've done 3 e46s and the second and 3rd time were both wayyyy faster. i have done trim like 5 times as well lol.
Looks good though.
-Brandon
SkrApUNB is offline   Reply With Quote
Old 02-02-2014, 02:14 PM   #5
BillB
My Ride: e46
I just did the exact same thing to mine. It turned out awesome and probably saved 250.00 if not more in buying new pilars. I was thinking about doing my head liner and then quickly changed my mind due to the amount of work involved. Also, the only thing I did different than the op was not painting the grey seat belt adjusters because I felt it would help tie it in to the grey headliner better
BillB is offline   Reply With Quote
Old 03-08-2014, 08:38 AM   #6
modjo
My Ride: 330XI
What kind adhesive did you use?
modjo is offline   Reply With Quote
