Old 01-13-2014, 03:37 PM   #1
Cosmosmpower
Account Under Review
My Ride: 10' Nissan GT-R
Widest Wheels on ZHP without rubbing
What's the largest size wheel you can fit on a ZHP sedan without extensive fender rolling/rubbing, 17X9, 17X9.5, 18X9?
I have coilovers so I can adjust ride height and camber (to some degree). Thinking about making my daily driver into a mild STX build and maybe doing a few DE's in it.
Cosmosmpower is offline   Reply With Quote
Old 02-03-2014, 08:33 PM   #2
BZHP
My Ride: ZHP
Probably youre best option would be a 17x9. Cheaper tires, smaller rolling radius, lower ride height for better center. and the difference in optional brake clearance probably wont be affected unless youre running something nuts for brakes.
BZHP is offline   Reply With Quote
Old 02-04-2014, 12:33 AM   #3
bimmernate
My Ride: 2003 330i ZHP
im running 17x9 245 square on my ZHP sedan with no fender modifications (although I think I MAY be SLIGHTLY rubbing in the rear).
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Old 02-04-2014, 02:47 PM   #4
Riverbmr3
My Ride: MB E350 & BMW 325i
use 9.5x18 ET45 rear
Riverbmr3 is offline   Reply With Quote
Old 02-09-2014, 03:56 PM   #5
mko9
My Ride: '04 330i ZHP
You can run a square setup with the Style 135 ZHP rear wheels with a 255/35 tire. I also have a set of the ARC-8s (like above) in 17x9 with 255/40 Nitto NT-01s. I was advised to use a 5mm spacer in the front, and I have had no rubbing issues.
Mike
'04 BMW 330i ZHP
'11 BMW 535i
'13 Land Rover LR4
mko9 is offline   Reply With Quote
Old 02-10-2014, 06:22 PM   #6
Ghambino
My Ride: 330ci
Offset is what you want to pay attention to. I'm guessing you want to run wide tires also? In that case you want something with a +40 to +45 offset.
Ghambino is offline   Reply With Quote
Old 02-10-2014, 06:57 PM   #7
YYCZHP
My Ride: 2005 330ci zhp
I run 18x9 et45 with a 255/35/18 but could probably run a 18x9 and a 265/35.Click image for larger version
ID:	546088 I am currently on stock sport suspension, and have about 3/4-1" gap between my tire wall and my fender lip. My fenders are not rolled.
YYCZHP is offline   Reply With Quote
Old 02-19-2014, 02:50 PM   #8
sm240
My Ride: 95 240sx
18x9 +26 offset (style 67...4 x m3 rears) running 235/40/18. Slight rear rub and im lower than zhp
sm240 is offline   Reply With Quote
Old 02-19-2014, 04:04 PM   #9
Sedan Hussein
My Ride: e46
Originally Posted by bimmernate View Post
im running 17x9 245 square on my zhp sedan with no fender modifications (although i think i may be slightly rubbing in the rear).
<3
Sedan Hussein is offline   Reply With Quote
Old 03-10-2014, 01:01 PM   #10
murph1379
My Ride: 2006 M3
For STX, you're limited to 9" wide, so 17x9 or 18x9. Both work, but you'll definitely need to roll the fender in the rear, and pay attention to offsets. 265s will rub a little in the rear, but that was mostly when I had a lot of stuff in the car. (4-500lbs worth of autocross junk, wheels, etc)
I've retired my ZHP from STX, and have a lot of STX-related stuff that's for sale if you're interested, details here:
http://www.mnautox.com/forums/showth...%29&highlight=
murph1379 is offline   Reply With Quote
Old 03-10-2014, 05:06 PM   #11
sm240
My Ride: 95 240sx
FYI -Stx is flooded with brzs and ft86. I've been getting bitched lately
