E46 Convertible
Old 01-13-2014, 06:59 PM   #1
iq
My BMW e46 drivers door unlock but the door doesn't open
Hi guys I wonder if anyone can help my drivers door seems to be temperamental it will always unlock but the door won't open only do ruined it opens. I've taken of the door card and checked all seems fine even tighten the lock I'm stuck font know what to do help me please guys spent 2 days trying yo figure this out now.
iq is offline   Reply With Quote
Old 01-14-2014, 01:11 PM   #2
Trevor330Ci
My Ride: 2001 BMW 330Ci
Send a message via AIM to Trevor330Ci
Sounds like the Door actuator is bad.
My Driver side will unlock when I press the button but the door will not open unless I stick the key in the door and manually unlock it. My Pass side will unlock but will not open unless I open it from the inside. It sucks but the parts new are kinda pricey.
01' 330Ci Vert
-Angel Eyes
-Eagle Eyes
-HID Fogs
-K&N Intake
-Refreshed Cooling System
-Smoked Wheels
-LED Interior
-(2) 10" Pioneer Subs
-JBL Audio751Watts Amp
-Kenwood 6.75" Front Mid Bass
-Kenwood 5.25" Rear Mid Bass
-Infinity 1'' Rear Tweeters
-Smoked Side Markers
-Clear Corners
-Magnaflow Exhaust
Trevor330Ci is offline   Reply With Quote
Old 01-14-2014, 04:14 PM   #3
iq
Cheers trev but my won't open at all it will only open when it wants to. What's pricey mate?
Old 01-14-2014, 04:41 PM   #4
iq
Is that all that I need mate?
Old 01-15-2014, 08:34 AM   #5
R1200RT
My Ride: 2004 330CIC
Trevor, I had the same situation where the passenger door would only open from the inside. I found that the exterior handle cable had slipped out of the holder on the inside of the door. Just a matter of taking off the panel and snapping the cable back in the proper location.
Nick
'04 330CIC, 3 pedals, M Sports\Aerodynamics Packages
'05 BMW R1200RT
'00 BMW R1100S
'04 BMW R1200C Montauk
'95 BMW R100R Classic
R1200RT is offline   Reply With Quote
Old 01-15-2014, 10:53 AM   #6
Trevor330Ci
Thanks for that. I'm going to look at that today,because latly when I roll the window down I do hear a noise like it's hitting something. I'll let you guys know it that's what my problem is as well. But the driver side has to be the actuator because I have already taken the panel off of that side.
01' 330Ci Vert
-Angel Eyes
-Eagle Eyes
-HID Fogs
-K&N Intake
-Smoked Wheels
-LED Interior
-Clear Corners
-Magnaflow Exhaust
Old 01-19-2014, 07:09 PM   #7
SuperSleeper
My Ride: 2003 330CIC
Had this same problem with both doors. Oddly at different times. They magically started working again for the last several months and have not had a problem since. No idea other than expansion and contraction from weather changes? Don't spend any money on it just yet. Let the season pass and see what happens. Maybe try some wd40 on it?
SuperSleeper
SuperSleeper is offline   Reply With Quote
Old 01-19-2014, 07:20 PM   #8
AquilaBMW
My Ride: 325i Convertible
Having this same issue with my car - driver's side door. I can lock the door with the remote along with the other door, but it won't unlock. Makes me wonder about the actuator since it locks.
AquilaBMW is offline   Reply With Quote
Old 01-19-2014, 07:27 PM   #9
SuperSleeper
Yup, mine used to make the noise as if it unlocked, but it didn't. Just magically started working again one day.
SuperSleeper
Old 01-19-2014, 10:56 PM   #10
iq
Thanks sleeper it does open when it feels like hasn't for the last few days but when i lock it I can unlock the lock but not the door. It's starting to do my head in so difficult to get out have to climb out. Do you think it's worth me opening it up and checking behind the foam on the door.
Old 01-19-2014, 10:59 PM   #11
iq
Aquila if your door first open it's because the plastic must be loose in the holder and needs to be pushed in. It's easy to open the side panel.
Old 01-19-2014, 11:49 PM   #12
AquilaBMW
Hiya - Thanks for the tip. I will check that out. The door actually doesn't open, it only locks on the driver side.
Old 01-23-2014, 01:01 PM   #13
iq
Thanks aquilabmw cheers mate my doors doing well so far with the wd40 let's hope it stays that way.
Old 01-23-2014, 01:03 PM   #14
iq
Sorry thanks supersleeper for the wd40 tip mate..
Old 01-30-2014, 09:11 PM   #15
AquilaBMW
I opened up the door panel today and could not see anything loose, missing or disconnected. Starting to think I have a faulty door actuator. The driver's door locks with the remote and the rest of the car unlocks with the remote key EXCEPT the driver's door.
Old 10-10-2016, 11:21 PM   #16
Kymbb
My Ride: 2001 E46 330Ci
Sorry to revive a dead thread, but did you ever find a solution to this? I have the exact same problem and I've been searching all over for a way to fix it!
Kymbb is offline   Reply With Quote
Old 10-10-2016, 11:28 PM   #17
SuperSleeper
I ended up finding an E46 at a junkyard!!! Paid $15 for door actuator and it fixed the problem. You will need to bring a pair of wire strippers and jump the window motor with a battery to the yard if you find one. I shorted the wires on my 18v drill battery, and it raised the window right up.
SuperSleeper
Old 10-11-2016, 06:02 PM   #18
NorthernCAE46
My Ride: 01 330Ci Convertible
Where at in california are you!!! I.E; where is this yard!!! lol
NorthernCAE46 is offline   Reply With Quote
Old 10-11-2016, 07:04 PM   #19
SuperSleeper
Newark wrecking yard on Mowry
SuperSleeper
