Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 01-16-2014, 08:37 PM   #1
ThreeOhFive
My Ride: 2002 330i
Best AR15 for cheap
Anyone had any luck with cheaper AR's? I really don't need to spend a lot considering how much I will get to use it. I'm seeing them going new for as cheap as $500-600. I realize if you want a seriously nice name brand one you can pay $1500+, but I do own an E46 and it regularly drains my wallet so I'm stuck with an entry level gun. Or used.
Sent from my SPH-L520 using BimmerApp mobile app
ThreeOhFive is offline   Reply With Quote
Old 01-16-2014, 11:52 PM   #2
Rush4theYehO
My Ride: XI fts(now)
Check out those S&W offerings. They tend to run pretty well, and can be had for fairly cheap.
Rush4theYehO is offline   Reply With Quote
Old 01-17-2014, 12:33 AM   #3
GuiltySpark
My Ride: 02 325xi
You could build your own.
GuiltySpark is offline   Reply With Quote
Old 01-17-2014, 01:47 AM   #4
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
If you're going to build your own, buying quality components is ideal. Going for the less expensive economy components right now still isn't a great idea. The market is still cleaning out the mass-produced low-QC components that a lot of companies started pumping out during the gun panic.
The cheapest option that is still worthwhile is the S&W M&P15 Sport @ $623. The next step up is a standard configuration S&W M&P15 in the $800ish price range. After that, it's up to the Colt 6920 and Sig M400 for the $1k price range.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 01-17-2014, 01:48 AM   #5
carcus
My Ride: 2006 BMW M5
M&P Sport
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 01-17-2014, 07:01 AM   #6
Sentaruu
My Ride: Xterra
m&p sport.
if you get more into shooting or your needs change you can always modify the rifle or switch out the upper with something else.
Sentaruu is offline   Reply With Quote
Old 01-17-2014, 07:16 AM   #7
unevolved
My Ride: 2003 325i
What about starting with an 80% lower?
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 01-17-2014, 08:56 AM   #8
NOVAbimmer
My Ride: E60M
good for someone who is planning on building something they'll keep for life. Bad for someone who's new to shooting and/or unsure of whether this is going to be a life-long hobby.
NOVAbimmer is offline   Reply With Quote
Old 01-17-2014, 09:17 AM   #9
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
M&P Sport
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 01-17-2014, 12:23 PM   #10
dan03833
My Ride: 2001 330xi
Last Summer I bought an ATI AR-15 for around $560 on sale. I have not had any issues with it functioning at all, and is more accurate than I am capable of. The only thing that has been an issue is the gas block. It came with a short gas block, which means if you want to add iron sights, you'll need a tall front sight or change the gas block so you can use a short front sight.
dan03833 is offline   Reply With Quote
Old 01-18-2014, 02:39 AM   #11
Reedo302
Reedo302's Avatar
Most quality receivers have a hard coat that goes 2mils into the metal to ensure hardness and durability. That, or a NiB coating. The problem with 80% lowers is that you don't have this in the areas you have to machine. Thus, you have to either have to coat it correctly on your own, or send it in. That just costs more money. In the end, the cost savings isn't there. Thus, the only reason to do an 80% lower is because you just want to try, and you have machining skills (besides nunchuck skills).
That, or you want something without a serial number or FFL transfer. But, that's sort of irrelevant when you own a boat and tend to forget where you lose things...
Glock Armorer
Old 01-18-2014, 10:59 AM   #12
unevolved
My Ride: 2003 325i
That's very true. I haven't looked into it for an AR lower, honestly, but I know anodizing shops around here in Houston have a $100 price for a minimum order for hard anodizing, and I've never come close to meeting the minimum.
Old 01-27-2014, 11:19 AM   #13
Redline
Redline's Avatar
My Ride: ///M3 Vert
M&P sport
Although I've gotten lucky with my DPMS upper and have had no issues contrary to what people may say, runs all day and have had 5k rounds through it so far. Accuracy is very good.
That said, I'd still go with the S&W
k.
///M
Old 01-29-2014, 11:53 PM   #14
BmwMan325
My Ride: 2011 Infiniti G37s
Just picked up this Windham, it's basically a bushmaster. It was on sale at cabelas for $750
BmwMan325 is offline   Reply With Quote
Old 01-30-2014, 12:13 AM   #15
Reedo302
Reedo302's Avatar
WW is better than Bushmaster. Most of the same people, but not working with the same parts sytem and controls (or lack therof) of the Freedom Group circus.
Glock Armorer
Old 02-24-2014, 08:43 PM   #16
Lexie330ci
ILCUTAWOOTIE
Lexie330ci's Avatar
My Ride: 330ci
Send a message via AIM to Lexie330ci
Id build w/ spikes.
Need brakes? Bother Anthony Here!
Lexie330ci is offline   Reply With Quote
Old 02-24-2014, 11:36 PM   #17
tailo
My Ride: 02 330I
I've got entry level rifles for 649
tailo is offline   Reply With Quote
Old 02-27-2014, 04:33 AM   #18
carcus
Last I checked, the M&P Sport was running $575 shipped.
Old 03-07-2014, 08:18 AM   #19
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Hurry up
http://www.impactguns.com/sw-model-m...188145663.aspx
JonJon is offline   Reply With Quote
Old 07-16-2014, 02:33 AM   #20
goosu94
My Ride: z3
Just picked up an M&P sport today for $560. Local gun shop sells them for $620 and magpul pmags for $22. I drove an hour away to get the gun for that price and pmags for $10.68. Can't beat it for the price.
goosu94 is offline   Reply With Quote
