Sponsored by The Tire Rack
Old 01-17-2014, 08:22 PM   #1
sjacoby112
My Ride: 2002 325ci
Little fitment help on pre facelift 325ci
Hey guys, about to order ccw classics. Fronts I'm not worried about. Rears are 9.5 et15. My previous set were 9.5 et35 with a 5mm spacer so et30. Rolled rears out to credit card fitment. Wondering if anyone has opinions on fender pull/rear camber set ups. Any help would be much appreciated. Thanks!
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 01-17-2014, 11:58 PM   #2
caliscrizle
My Ride: 02 M3
Alot is going to depend on your ride height and that will determine how much camber you will need or not need, if you plan on slamming your car then camber arms should be in order but if you go with a more modest height you may not need to run that much negative camber. I'm not sure about the 325 and how deep the wheel wells are etc, I have an M3 so I'm able to go pretty aggressive, I have ccw classics also, so if you have any questions pm me.
caliscrizle is offline   Reply With Quote
Old 01-20-2014, 01:43 PM   #3
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Wow, that's significantly more aggressive. Without more camber, I don't think it's going to work very well. We had a car on 19x9.5 ET22 square here, and the rears were shaved down significantly, and the rim still hit the fenders.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-20-2014, 04:07 PM   #4
sjacoby112
My Ride: 2002 325ci
I'm guessing challenged accepted then haha.
