///M3 Forum
Old 01-17-2014, 10:33 PM   #1
Mikem6
My Ride: E46 m3
E46 M3 Smg clutch slippage
So long story short.. My clutch failed on me so I installed a new clutch kit and before I did that my car shifted perfectly. After I did it my car would slip at high rpms so I recalibrated it.. Same thing, installed csl software then recalibrated again but same thing.
The smg lights up when It gets pushed hard and slips, reads code 59 clutch actuator. When it slips it just cruises I can apply gas but no power and still shows the gear I'm In but will catch onto the gear in like 10-20 seconds or sometimes never, if that happens I restart my car and it works fine again.
Is my problem the clutch actuator so I would need a new one or? If anyone has some insight please let me know, thanks!
Mikem6 is offline   Reply With Quote
Old 01-19-2014, 11:52 AM   #2
$ilent ///M
My Ride: 03.5 M3 smg lsb
Did you do the compression springs when you had the tranny down? when recalibrating did you do all all service function i.e. curve characteristic relearn, clutch slip, actuator calibration and think last one was inclination sensor.
$ilent ///M is offline   Reply With Quote
Old 01-30-2014, 03:47 PM   #3
driftking187
My Ride: M3 SMG2 convertible
i get a clutch slip every now and then when driving hard and changing up into 4th but no codes come up. ive recently been driving a c63amg 2014 and this does the same thing when driving hard maybe its just what they do
driftking187 is offline   Reply With Quote
