///M3 Forum
Old 01-18-2014, 12:13 AM   #1
XKR
My Ride: 2001 M3 Convertible
Bumper removal pre 10/01
I'm having hard time finding info how to remove a bumper on a m3 produced before 10/01. I need to do some work behind it so it has to go for now. Mine was manufactured on 07/01. There are two screws in each fenderwell and a few underneath. Do I have to take the bumper mesh off to get at the connecting to the bumper? they aren't torx, they are phillips heads.
These diagrams don't do much help
~SGT catless headers|Full BW 3.5" Resonated Race Exhaust w/ diffuser | Epic Motorsports Race Tune | BAC Filter | BW Intake Elbow
~Tein S-Tech Lowering Springs | Sebion CF hood | CF Kidneys | ▄mnitiza Predator Orion V4
XKR is offline   Reply With Quote
Old 01-21-2014, 01:54 PM   #2
Nelson
Nelson's Avatar
My Ride: Alpin wei▀ ///M
You don't need to take off the mesh. Jack up the car, there are two holes with two long torx screws hanging down which will need to be removed.
///M
| eBay mod'ing sUUCks
Nelson is offline   Reply With Quote
Old 01-21-2014, 01:58 PM   #3
XKR
That's it? I thought that was how to take off the bumpers on the 02+.
I know there are some screws in the fenderwall and underneath it but someone said it was a little more involved
Old 01-21-2014, 06:42 PM   #4
Laguna01///M3
OG PapaSmurf
Laguna01///M3's Avatar
My Ride: Grigio Medio E46 M3
the 01 uses an aluminum carrier. after removing all screws from under the bumper and the fender wheels from the bumper... there are 2 long ASA bolts (about 6") under the bumper. there are 2 round holes (about 1.5" diameter). remove these long bolts with a 10mm socket (i think). now your bumper should pull right off. but be careful, as there are still wires and water hoses attached to the bumper.
http://www.m3forum.net/m3forum/showthread.php?t=76456
Instagram@WBucco
Laguna01///M3 is offline   Reply With Quote
